derkom's attempt
Re: derkom's attempt
Nice work @derkom.
Before you put your BAD DMA socket in read this https://www.exxosforum.co.uk/forum/view ... =20#p28984
derkom
Post by derkom »
Icky wrote: Sat Nov 23, 2019 7:29 pm Before you put your BAD DMA socket in read this https://www.exxosforum.co.uk/forum/view ... =20#p28984
Heh, precisely why I skipped that resistor for now. Figured I would want to check how well it plays with that socket first. :)
derkom
Post by derkom »
DTACK FIX
Edit: Fixed before anyone else notices! :oops:
Not sure that is right.. I flipped the image to see better....
derkom
Post by derkom »
Hah, whoops, you're right. :oops:
Edit: Fixed above. :)
@derkom - I had the same problems on the ALPHA. I can never tell my left from my right so I got into the habit of flipping the image like @exxos did.
derkom
Post by derkom »
Icky wrote: Sun Nov 24, 2019 1:44 pm @derkom - I had the same problems on the ALPHA. I can never tell my left from my right so I got into the habit of flipping the image like @exxos did.
I used to be good at this stuff. I seem to be losing my spatial relations skills in my old age. :roll:
@exxos, did you see my question about TOS ROM above? Can I reuse the ROM from the alpha, or will I need to acquire a different one for H4?
derkom wrote: Sun Nov 24, 2019 2:13 pm
You can re-use the one from the ALPHA :)
derkom
Post by derkom »
Icky wrote: Sun Nov 24, 2019 2:22 pm You can re-use the one from the ALPHA :)
Super. Thanks.
derkom
Post by derkom »
A question about QG1 ("CRYSTAL 32MHz"): I have a 32.00000 MHz oscillator in DIP-14 package, but I notice the link to @exxos's store is for a 32.084988 MHz unit. What's the difference going to cause here? Is my 32 MHz appropriate?
