Icky's H4 Mongrel edition build x 2
Re: Icky's H4 Mongrel edition build x 2
@Icky Its not even midnight yet, still a good 2-3 hours left in the day yet ;)
exxos wrote: Thu Nov 21, 2019 11:04 pm @Icky Its not even midnight yet, still a good 2-3 hours left in the day yet ;)
Yes but I am playing with other projects. Finally got the Giant Panda to print a test print properly. @PhilC no more lumps of ABS popcorn :)
Yes, the panda did seem to print pretty good popcorn
All the sockets are fitted. As you can see I am going for the SIMM slot version as I know the Falcon RAM board works in the ALPHA and want to test the SIMM slot.
Also as mentioned by @exxos be careful when soldering in the battery it goes in nicely but dont get solder across the other track that is missing the solder mask.
Someone fitted the PLCC52 for no reason @Icky ;)
exxos wrote: Fri Nov 22, 2019 6:56 pm Someone fitted the PLCC52 for no reason @Icky ;)
Icky wrote: Fri Nov 22, 2019 7:23 pm
Well if there is something pointless to do, I might do it myself too ;)
I think I may of found the first minor issue. The XTAL around the YM and MFP chips sticks up around where the floppy drive goes. I placed a Gotek there to see if it will be a restriction but it depends on the floppy drive feet height.
Worst case will move the XTAL out the way.
Icky wrote: Fri Nov 22, 2019 8:24 pm I think I may of found the first minor issue. The XTAL around the YM and MFP chips sticks up around where the floppy drive goes.
oops, I guess it should be lay flat :roll:
derkom
Post by derkom »
Would that even be a problem? The floppy drive leg, minus the bottom foot portion, is around 18.4 mm, and the crystal, at least the one on the BOM, is only 13.46 mm tall. It'll be close, but it seems like it should fit okay.
