That's good idea since these are tested and working for sureterriblefire wrote: Sat Oct 12, 2019 1:34 pm
You would be better implementing Mike Stirling's SPI VHDL here and use the K1208 drivers.
Agranlunds TF534 Build
- 8 Bit Dreams
- Moderator Team
Re: Agranlunds TF534 Build
Brilliant, thanks! I had no idea about that card or Mike Stirling's work in general.You would be better implementing Mike Stirling's SPI VHDL here and use the K1208 drivers.
Yes this is by far the most sensible choice, and porting parts of his Amiga driver to Atari will surely save me a bunch of time
Always nice when PCBs finally arrive in the mail.
It fits like a glove, no more messy IDE cable
Nice indeed. Very clean!
nice
Atari V4sa / Lynx I / Mega ST 1 / 7800 / Portfolio / Lynx II / Jaguar / TT030 / Mega STe / 800 XL / 1040 STe / Falcon030 / 65 XE / 520 STm / SM146 / SM124 / SC1435
Antonia 2 / ATW800/2 / SidecarTridge / ACSI2STM / Mach64 VME / Mach32 VME / ET4000 VME / Atari 1050 / DDD HDD / AT Speed C16 / TF536 / SDrive / PAK68/3 / Lynx Multi Card / XCA12 / SkunkBoard / CosmosEx / SatanDisk / UltraSatan / USB Floppy Drive Emulator / Eiffel / SIO2PC / Crazy Dots / PAM Net
http://260ste.atari.org
I have recently bought 68060 rev.6 and 68882 from China and they're genuine working chips. I guess I'm lucky, but I also selected reputable sellers from Ebay and avoided cheapest items and obvious scams.8 Bit Dreams wrote: Mon Sep 30, 2019 1:08 pm That's true, China is getting worse, have bought 20x FPUs -none of them is working. some of the chips have pin1 mark on the left corner - that's crazy...
I think I finally have a single easy-to-use FastRAM "driver" solution that I am happy with, regardless if you're running EmuTOS or Atari TOS
MAPROM.PRG:
It copies the contents of your TOS Roms into FastRAM and then continues on execution from there. No restart required.
You need a 68030 with MMU, and that your ROMs are 256Kb or larger (Ie: it does not work with TOS 1.xx)
When necessary, it takes care of detecting and installing TT-RAM, the DMA buffer, and the initial MMU configuration.
Tested with Atari TOS 2.06 and EmuTOS 0.9.12. Together with NVDI.
I recommend putting MAPROM.PRG as the first item in your AUTO folder.
And then NVDI for a very snappy TOS experience
The binaries, and sourcecode, can be downloaded from here:
https://github.com/agranlund/tftools
While I've only tested it with my TF534, I'd expect it to work fine on other accelerators as long as the FastRAM is at 0x01000000 (TT-RAM) and the CPU is a 68030 with MMU.
MAPROM.PRG:
- 8 Bit Dreams
- Moderator Team
Wow! This looks very promising!
What do You think, will this work on STe with Kludges plcc adapter?
Here are also the latest Atari firmwares:
(No changes for the TF534, but it includes an *untested* TF530r3 build)
Source is here: https://github.com/agranlund/tf534
Technically the Blitter works fine with the TF cards as long as you only blit to-and-from ST-RAM, the issue is being able to make certain that is always 100% the case..
Perhaps it would be an idea to make the TF firmware hide the Blitter so that it cannot cause issues.
But even then, if something assume it exists just because the machine is an STE then it will probably freak out.
It would be really cool if we could find a way to be able to use it though..
Either by having to run some program to unhide it before running a blitter-enabled game, or something more elaborate like letting the TF firmware act as some kind of man-in-the-middle. It could allow the blitter hardware for ST-RAM blits but generate an exception if it tries to blit to/from FastRAM, which would then perform the blit in software instead. In theory anyway... I have no idea if it would actually work
On the STE, I assume you probably don't want to play DMA samples from FastRAM either..
Thanks, yeah this is a much nicer and easier setup than those individual ram-loaders I did earlier for 2.06 and EmuTOS.Wow! This looks very promising!
I think the main obstacle would be the Blitter, so for general use it would probably not work that great.What do You think, will this work on STe with Kludges plcc adapter?
I agree with Agranlunds, there is no reason to turn the BLiTTER off.
There are some badly written applications which have a problem with TT-RAM and try to place ACSI/Sound-DMA/the BLiTTER buffer outside ST-RAM.
There is a dedicated TOS tool - "PRGFLAGS", which informs the TOS that application should have access to e.g. the ST-RAM only.
The latest EmuTOS deals with the BLiTTER and 68030 card with its RAM (actually with ROM placed inside 68030 RAM):
https://sourceforge.net/p/emutos/mailma ... nth=201909
