TF536 Experiment
alenppc
Re: TF536 Experiment
Post by alenppc »
If you do a production run, do 50 of them, I will buy 15-20 pieces.
Crumb
Post by Crumb »
Hi
It looks like a great idea. I'd like to build and test one (and if there are remaining boards, two of them). I have successfully built TF530, Matze's cdtv-ram-ide board that uses a package with the same format, a3660, and repaired various pieces of Amiga hardware with a similar pin sizew like Deneb or ACA620. I understand that it would be without support. I have some of the required components but some kind of list of components could be handy.
Best regards
Jaime
FluffyRedLobster
Post by FluffyRedLobster »
I'd gladly stump up for one (or two if there are enough available). Happy with no support - I think I've learned enough from my 530 and 534 builds to be self sufficient now. :) That reminds me, I need to post my cooling solution in the 534 forum :D
As Crumb says above ^ a bom would be good.
TF536 full copper top 030, Amigakit SD adapter, A500 Rev6a, KS3.1, Boobip 2MB w/ Gary Adapter
8 Bit Dreams
Post by 8 Bit Dreams »
alenppc wrote: Mon Sep 16, 2019 2:04 pm If you do a production run, do 50 of them, I will buy 15-20 pieces.
Same here, ready to take 20 boards without any support. Have here some users who are open for experiments
nikoskon
Post by nikoskon »
Would love to have one too if available, this would be the first TF board i will be making :)
Cheers :)
ube
Post by ube »
I'm in.
master of the bare pcb
kludge
Post by kludge »
I’d like one. Too bad you already sent my TF330 PCB’s or you could have held on to them and shipped them together.
But I’m in for one. At least.
My lack of focus:
PaulJ_2.0
Post by PaulJ_2.0 »
Same here, I'm confident I could shift a few into the world of amigans.
redhawk668
Post by redhawk668 »
Could you put me on the list too? I'd like 2 boards, so I can built one for Atari ST too,
robban
Post by robban »
I'd love to build one as well. So far i've managed to make working copies of all of your designs except the TF520. If someone finds a particular hardware/software combination (of A500 or ST) that behaves oddly, there is a good chance that i could build the exact same setup and see if it is repeatable.
