TF360 Fan Header
- Admin sponsor
TF360 Fan Header
Before i order the rev 1 I want to quickly look at adding a header for a fan.
We need to use 12V so it will need to be close to the edge connector.
What header component should I use?
EDIT: Is Molex KK 3 pin still the standard? https://uk.rs-online.com/web/p/pcb-headers/1707102/
Re: TF360 Fan Header
two or three pin are the most used it seems on cooling fans, obviously three pin has the extra signal pin for fan speed measuring, I would still go for the three pin as options are always good and you can always hack a two pin to fit
- Admin sponsor
Ok here is the dilema.. the only place left to fit this is in the top left of the board. But to do that i need to bring 12V right across the board... I... i dont wanna.supaduper wrote: Sun Sep 15, 2019 10:15 am two or three pin are the most used it seems on cooling fans, obviously three pin has the extra signal pin for fan speed measuring, I would still go for the three pin as options are always good and you can always hack a two pin to fit![]()
Is 5V fan header useless?
Why bother adding that , you will have a spare 5v and GND from the power reg circuit so it just means cutting and adding a couple of connectors onto the cable, what do you think ?
- Admin sponsor
Yeah more or less what I’m thinking
terriblefire wrote: Sun Sep 15, 2019 9:57 am Before i order the rev 1 I want to quickly look at adding a header for a fan.
Remember: #SiliconNotSilicone
My lack of focus:
[ 8 * A500 ][ 2 * A500+ ][ 2 * A600 ][ 2 * A1200 ][ 2 * A2000 w/ A2386 ][ A4000 w/ TF4060, CyberVision 64 3D, FastLane SCSI Z3 ][ CD32 ][ VIC-20 ][ 4 * C64 Breadbin ][ 5 * C64C ][ 2 * C128 ][ C128D ][ C64 DTV ][ 3 * Mac Classics of different types ]
My lack of focus:
- Admin sponsor
Went for a 3 pin .1 header with 5V in the center and ground on each side.
Is the fan limiting option based on limiting current supplied to the fan or am I missing something? Would love to get the fan noise down a bit.terriblefire wrote: Sun Sep 15, 2019 1:45 pm Went for a 3 pin .1 header with 5V in the center and ground on each side.
- Admin sponsor
There is no fan speed regulation on the 360.. no space to do it. Its just a 5v header.
Cheers, need to play with some resistors then I guess.terriblefire wrote: Wed Jul 08, 2020 12:02 am There is no fan speed regulation on the 360.. no space to do it. Its just a 5v header.
