Arek's TF534 build
Re: Arek's TF534 build
arkadiusz.makarenko wrote: Tue Sep 17, 2019 2:57 pm Yup. Works all right on orginal CPU.
What you’re seeing sounds like you have the clock jumper on the wrong setting?
arkadiusz.makarenko
Post by arkadiusz.makarenko »
I got it set up wrong!
I don't get any output at all on other setting. :(
~ Stanislaw Lem
arkadiusz.makarenko
Ok. Ordered CPU and 33 MHz oscillator. I hope this will solve my mystery.
~ Stanislaw Lem
PaulJ_2.0
Post by PaulJ_2.0 »
Maybe post a clear pic of your board, maybe one of us can spot something amiss?
arkadiusz.makarenko
It starts at 7mhz but doesn't at 40mhz.
CPU is unknown, so I assume it may be bad. I will get tested CPU in 2 days, and 33mhz oscillator.
~ Stanislaw Lem
arkadiusz.makarenko
Yeyeyyeyeye!! Got it boot Diagrom. It was fu*king oscillator. It runs at 50mhz!
~ Stanislaw Lem
arkadiusz.makarenko wrote: Tue Sep 17, 2019 7:55 pm Yeyeyyeyeye!! Got it boot Diagrom. It was fu*king oscillator. It runs at 50mhz!
Well done.
Dodgy oscillator choice or just a duff one?
arkadiusz.makarenko
PhilC wrote: Tue Sep 17, 2019 8:08 pm
Well done.
Genuine source. I had to kill it somehow.
~ Stanislaw Lem
At least it's fixed and 50mhz at that, well done.
arkadiusz.makarenko
It appears that there is still ram issue but this can be sorted. :)
~ Stanislaw Lem
Return to “TF534 (OBSOLETE)”
