Check if your IP is banned
viewtopic.php?t=7286
Arek's TF534 build
- 8 Bit Dreams
- Moderator Team
Re: Arek's TF534 build
4-layer lis a bit different to 2-layer boards, middle layers do obsorb much heat
As said - use preheater to avoid lifting pads,
If you do it right you don't need high temperatures, board is heated from bottom and removing such komponents like cpld is a pice of cake...
- arkadiusz.makarenko
- Moderator Team
Preheater is on my list things to buy.8 Bit Dreams wrote: Fri Sep 13, 2019 5:33 pm 4-layer lis a bit different to 2-layer boards, middle layers do obsorb much heat
If you do it right you don't need high temperatures, board is heated from bottom and removing sych komponents like cpld is a pice of cake...
~ Stanislaw Lem
~ Stanislaw Lem
What kind of preheater are you using?
- 8 Bit Dreams
- Moderator Team
I have one like this:
https://rover.ebay.com/rover/0/0/0?mpre ... 3071718018
- Moderator Team
I started working on board nr 2.
Should I install R2 ? I did find a note on schematics note about some resistor, and now I am confused a little.
~ Stanislaw Lem
~ Stanislaw Lem
- 8 Bit Dreams
- Moderator Team
All resistors and caps should be installed
- Admin sponsor
My soldering iron is decent enough. I do need to put the temp up to to the ground pins i guess.
- Moderator Team
I completed build of second board, and I get EXACTLY the same output garbadge on serial output. This makes me think that I mostl likekly have bad CPU.
I have not installed RAM yet, but this shoudn't matter ? I still should see clear Diagrom output.
~ Stanislaw Lem
~ Stanislaw Lem
Have you checked that your serial link is working correctly using a standard board (e.g A500 with 68000) fitted with DiagROM?
- Moderator Team
Yup. Works all right on orginal CPU.
~ Stanislaw Lem
~ Stanislaw Lem
