Getting WFI Working on TF3xx with ESP Module
Re: Drivers for ESP modules
theq wrote: Tue Mar 31, 2020 11:16 am Was testing this yesterday, but with no success. Need to confirm that my ESP-01S is working properly. Will test this today.
Just ordered stuff from Digikey to help troubleshoot the port during Easter.
Does the port act like a normal serial Tx/Rx on the Amiga with the normal serial.device (except it's TTL obviously)? No need for any fancy wrapper or workaround?
Yup that should work. You'll need to flash it with esp_slip_router and set the baud rate
theq
Post by theq »
terriblefire wrote: Tue Mar 31, 2020 11:19 am Yup that should work. You'll need to flash it with esp_slip_router and set the baud rate
Yeah, flashed it with the default .bin's and with self-compiled .bin's but nothing.
Wasn't able to Putty it or make it connect to my wifi.
Will use my Raspberry Pi to troubleshoot it tonight. More reliant that way... :roll:
theq wrote: Tue Mar 31, 2020 11:45 am
You wont be able to putty. You need to SLAttach to it via linux and then telnet to port 7777 like the instructions say here.
https://github.com/martin-ger/esp_slip_router
matt020
Post by matt020 »
terriblefire wrote: Mon Mar 30, 2020 1:26 pm a 3.3v usb serial breakout will work with the TF330.. but i'm not going down the road of supporting it etc. otherwise i'll get nothing done.
This might be easier, and at this stage the only working option. I'm not concerned if its at 19200 or 115000 baud, as long as there is a way to send files to/from the CD32, it would be more than what is running at the moment: no way of sending files to/from the CD32
I might start a new thread on it, if there is no objection.
I tried following this guide and using WinUAE...
https://blog.nootch.net/post/amiga-bbs-online-2019/
I get this error...
Setup is here
https://mega.nz/#!cZREzILK!-0nAO4vUltxi ... zRBANsIcao
Smyckers
Post by Smyckers »
@terriblefire Can you try disabling "carrier detect" on the PPP tab of the interface in genesis Prefs?
Smyckers wrote: Tue Mar 31, 2020 5:24 pm @terriblefire Can you try disabling "carrier detect" on the PPP tab of the interface in genesis Prefs?
That got it in fs-uae on macosx!
Screenshot 2020-03-31 at 17.31.34.png (137.92 KiB) Viewed 7046 times
So this hard disk set of file...
https://mega.nz/#!RJ4xkQSA!hKA6ZNLKkpfF ... tw1yhZF_LU
Plus the standard ESP SLIP ROUTER firmware
settings are
ESP SLIP Router V1.1.0 (build: Sun Feb 23 23:34:52 2020)
SLIP: IP: 192.168.240.1 PeerIP: 192.168.240.2
STA: SSID: BTHub4-WXYZ PW: ******** [AutoConnect:1]
External IP: 192.168.1.80
DNS server: 192.168.1.254
Clock speed: 160
Serial bit rate: 38400
theq
Post by theq »
I got mine working!
Default setting (as in the walkthrough) + it's running at 115200 :)
Only thing I know I changed is Modems/TAs setting: Device-tab: Ignore DSR.
Not gotten DNS* working yet, but getting there is easier now that I have the basics working.
Oh! I swapped my ESP-01S with a Adafruit ESP8266.
Edit: Got DNS working :D
tried it in a TF330?
S
