Getting WFI Working on TF3xx with ESP Module
quantum8
Re: Getting WFI Working on TF3xx with ESP Module
Post by quantum8 »
Does any esp8266 module work, or does it have to be the ESP01 type board?
I have a couple spare wemos D1 mini pro clones laying around from other projects.
The header is for the ESP01... given they cost $2 I’d just get another one
quantum8
Post by quantum8 »
Yeah I probably will. It'll just take 2 months to get here.
I'll give the wemos a go in the meantime and see if it works.
OHROM
Re: Drivers for ESP modules
Post by OHROM »
theq wrote: 02 Apr 2020 18:43
terriblefire wrote: 01 Apr 2020 12:06 Simple AmigaDOS script to set everything up for you. You need to have installed roadshow (maybe also with roadshow demo?) and downloaded http://aminet.net/package/comm/net/cslip-sana2.lha into the same folder as the script... see the zip attached.
Caveat is that it wipes your current settings clean and uses 8.8.8.8 for DNS resolution. You can update that if needed.
; (C) 2020 Stephen J. Leary
echo "Removing old slip.device"
IF EXISTS DEVS:Networks/slip.device
	delete DEVS:Networks/slip.device
EndIf
echo "Installing slip.device"
lha -q x cslip-sana2.lha ram:
copy QUIET ram:slip/slip.device DEVS:Networks/
IF NOT EXISTS ENVARC:Sana2
	echo "Creating SANA2 Config folder"
	MAKEDIR ENVARC:Sana2
ENDIF
echo "Creating slip0.config"
echo >envarc:Sana2/slip0.config "# Auto generated file"
echo >>envarc:Sana2/slip0.config "serial.device 0 38400 192.168.240.2"
echo "Create network interface"
echo >devs:NetInterfaces/Slip "# $VER: SLIP 1.1 (1.4.2020)"
echo >>Devs:NetInterfaces/Slip "interface=Slip"
echo >>devs:NetInterfaces/Slip "device=slip.device"
echo >>devs:NetInterfaces/Slip "unit=0"
echo >>devs:NetInterfaces/Slip "address=192.168.240.2"
echo >>devs:NetInterfaces/Slip "netmask=255.255.255.0"
echo >>devs:NetInterfaces/Slip "requiresinitdelay=no"
echo "Create routes file"
echo >Devs:Internet/Routes default 192.168.240.1
echo "Create name_resolution file"
echo >Devs:Internet/name_resolution nameserver 8.8.8.8
literally unzip the zip file and type "Execute install_script" at a cli.
Your install_script worked perfectly.
Only thing I had to change was:
To:
echo >>envarc:Sana2/slip0.config "serial.device 0 115200 192.168.240.2"
Thanks! :D
Omg! i been trying to get mine going for little over a week now and i thought i had everything correct until, i saw this post about editing the script from 38400 to 115200 and i thought got nothing to lose at this point and it worked for me also, thanks so much for posting this info i never would have thought to change that :)
DDNii
Post by DDNii »
Just got a TF330 and ESP module.
Followed the YouTube video from 32Bits and this great thread.
Could not get the thing to connect. No errors during set up. Fiddled for a couple of days. No joy.
Turned out my ESP01 is a 1MB version and all I needed to do was change the flashing command in the set up video to 1MB from 8MB. So simple, however my assumption that all the ESP01 modules were the same was my undoing.
DDNii wrote: 11 Feb 2022 11:21 Just got a TF330 and ESP module.
Thanks for that. I wonder if there is a simple way to detect.
DDNii
Post by DDNii »
Hi Stephen, not sure if sarcasm because I missed something obvious?
Seems some are marketed as 8MB (I guess megabit?) and some as 1MB (megabyte?) So I presume same size flash mem.
I checked for an 8 megabyte version but didn't see one.
Mine has a blue led, whereas the one in 32Bit video is red - I know, not a very technical approach ;)
The Flash chip on mine is labelled T25S80 XM20d2 PPA489.
DDNii wrote: 11 Feb 2022 12:12 Hi Stephen, not sure if sarcasm because I missed something obvious?
No sarcasm. I've had a few people struggle. Just wondering if there is an easy way to check this.
DDNii
Post by DDNii »
terriblefire wrote: 11 Feb 2022 12:37 No sarcasm. I've had a few people struggle. Just wondering if there is an easy way to check this.
Ok :)
Unsure, seems that command esptool.py flash_id could interrogate the chip and report the flash size https://docs.espressif.com/projects/esp ... d-flash-id .
edit.
Just tested on my device with the programmer in "prog" mode esptool.py flash_id spits out the flash size as 1MB and manufacturer details.
TheCorfiot
Post by TheCorfiot »
Good Evening everyone
Got my ESP flashed, programmed, verified using the show command and plugged into my CD32
Run the install script and checked driver and scripts are all in place
I'm trying to configure MiamiDX as I have a licensed copy but there are so many options I'm really struggling.
Prism wireless is easy lol.
Has anyone got it working with MiamiDx, if so please be kind and share the details.
Cheers
Update..... sussed it, heres the details
Create a point to point interface using the slip.device driver
Create hardware profile using above ptp interface and set static ip to 192.168.240.2 and Gateway to 192.168.240.1
Create DNS entry 8.8.8.8 in Database.
Thats it :)
Users browsing this forum: alenppc, CCBot and 35 guests
