alenppc wrote: 22 Aug 2019 13:28
Hmm you are right... I dug up a bit more, and you are right, the mufastrom doesn't reboot, but I still get 2 reboots with the mutools enabled. I have to figure out what's causing it.
It may have more to do with where in the startup-sequence it is than anything else. The installer puts it in user-startup, I always move it right behind setpatch.
With 3.1.4.1, I have 0 reboots and my system is up in seconds (NODRIVELEDPATCH) .
Buy a Witcher 500 if you want a simple A500 experience.
EDIT: if you pm him here you may be able to get it without ebay taking their cut.
xraynorm wrote: 08 Sep 2020 08:37
Great. I'm planning to use a short IDE cable (10-15cm). Will I need the IDE buffers?
Thanks
15cm is a long cable. The answer is unknown at that length.
Chucky uses a TF360 with almost a 1M cable with no buffers. Other people say 5cm doesnt work.
