Aros on TerribleFire
supaduper
Re: Aros on TerribleFire
Yeah it`s strange that Winimage does not write it, and the image definitely exactly the same size or smaller than the CF you are using ?
- Admin sponsor
I'm using a 16Gb card an the file is 1Gb.supaduper wrote: 15 Sep 2019 10:18 Yeah it`s strange that Winimage does not write it, and the image definitely exactly the same size or smaller than the CF you are using ?
- Admin sponsor
OK i got it ...
I'm guessing nobody will know what this is all about but i'll post it anyway
supaduper
How did you write to the CF in the end bud ?
- Admin sponsor
I used WInImage... i wasnt convinced it had worked but it was ok in the end.
supaduper
Sweet !!
If you want a laff , this depressive guy on the tube faffs about installing AROS over OS 3.1 , the first part is funny because he reminds me of the depressed robot on` hitch hikers guide to the Galaxy` :)
arkadiusz.makarenko
- Moderator Team
I have been looking for this information for over a week on the web!go0se wrote: 14 Sep 2019 21:45Is it failing to write or just not picking the file up?terriblefire wrote: 14 Sep 2019 21:01
i havent found a way to make it write HDF.. only seems to like VHD
Version 9.0 :
Run as Admin.
"Disk" menu.
Restore virtual Hard Disk image on physical drive.
Choose device from list.
Change file extensions to *.*
Choose and open .hdf
Yes to begin writing straight away.
*Edit* No 'happy' message when writing completes, just returns to main window.
And I did find it on this forum (obviously)
~ Stanislaw Lem
~ Stanislaw Lem
Users browsing this forum: CCBot and 3 guests
