Maximum 520STfm TOS version Etc
Re: Maximum 520STfm TOS version Etc
good news, it works, loads up 1.04 without issue, although there seems to be something strange with the floppy disk. It'll stop refreshing the disks i put in, and doesnt check for new disks, also the little orange light is flashing rapidly at super low brightness.
The light flashing is normal. AFAIK all tos versions do that.AtariFox wrote: Thu Aug 15, 2019 11:04 pm good news, it works, loads up 1.04 without issue, although there seems to be something strange with the floppy disk. It'll stop refreshing the disks i put in, and doesnt check for new disks, also the little orange light is flashing rapidly at super low brightness.
As for refresh, you should always press ESC to refresh the floppy contents. Media change has always been buggy . I added a fix onto my 1.44 floppy kit to help with just that. But when you change a floppy, its just good practice to press ESC to refresh it. In fact it should be less buggy with 104 than other for versions. Then flashing floppy light is TOS polling then drive to see if a disk has changed. Even the floppy drive itself could be a cause.
I hardly used tos1 or 102, but I half recall pressing ESC didn't even refresh the disk. Are you sure your for board is set to 104 ? If you see a animated rainbow in desktop info then its 104. If its black, its 102.
I dont have a colour monitor, but im pretty sure this is running in 1.04 mode, as sys-info says it is.
but yeah, even ESC doesnt work checking to refresh the disk contents, oh well.
- Attachments
- photo_2019-08-15_23-22-58.jpg (103.42 KiB) Viewed 6054 times
Can't really comment on that issue, I've never had any issues with 104.
I would suggest you do this mod. https://www.exxosforum.co.uk/forum/viewt ... f=12&t=428
I'll keep that in mind for future reference.exxos wrote: Thu Aug 15, 2019 11:40 pm I would suggest you do this mod. https://www.exxosforum.co.uk/forum/viewt ... f=12&t=428
Thank you for your help!
Did the floppy drive work before the TOS upgrade?
Also worthwhile rechecking the data cable to the FDD in case it was disturbed during the ROM swap.
I have seen these cables appear to be plugged in, yet only have one row of pins actually plugged in.
Do you have another FDD you can test with?
rubber_jonnie wrote: Fri Aug 16, 2019 8:49 am Did the floppy drive work before the TOS upgrade?
Yeah the floppy works fine. It formats and reads floppys.
Just does'nt refresh or something for some reason. I never knew about the esc to refresh before i changed the two rom chips, so i don't know, it works fine however, since it'll boot from the language disk no problems and read other atari disks like cubuse. I've not really got any other actuall atari disks.
I have a bunch of DSDD 720k disks and such. It'll just go "cant read disk or such" if its not the right format. It is a 720k drive.
Didnt 1.04 give support for standard windows FAT?
Floppies formated on the PC will work on 104. I swap them all the time while testing stuff out.
