Check if your IP is banned
viewtopic.php?t=7286
STFM Keyboard Remake
Re: STFM Keyboard Remake
MasterOfGizmo wrote: Mon Oct 14, 2019 7:44 am
keli wrote: Mon Jul 22, 2019 5:39 pm How are you going to do the controller?
The IKBD has been implemented in HDL and a small FPGA or a big CPLD could be used to get 100% compatibility without the need to source HD6301's. See https://github.com/harbaum/ikbd.
Thanks for the info / pointer. Will take a look.
agranlund
Post by agranlund »
Wow! This is a great project, I'd love to have cherry mx switches on my ST eventually :)
Finally got the LED, Switch and Key all assembled to see if it all works.
i don't like the colour :P
PhilC wrote: Tue Oct 15, 2019 4:47 pm i don't like the colour :P
Typical, I had a 1 in 3 chance of picking a particular colour for the test and I chose the one you don't like :lol:
PaulJ
Post by PaulJ »
Not an issue, Phil will test it till it fails... and then there all the same color! :mrgreen: :mrgreen: :mrgreen:
Still plugging away at this one. A lot of my time on this is project is on placement, getting all the locations of the keys and other components is key, excuse the pun.
Latest fitting job is the joystick / mouse connectors. There will be the need for a raised pad to cover all the keyboard pins and the mouse / joystick connectors need to be extended down slightly in this rendered image to sit on that pad.
Screenshot 2020-03-24 at 09.00.31.png (351.15 KiB) Viewed 7713 times
Modified my 3D print Function Key object to fit the cherry switches. Did a quick and dirty print to see if it fitted.
Looks ok, needs a slight tweak on the fitting and print in higher quality.
After the tweaks I can print F1..F10 out :)
tzok
Post by tzok »
Any chances that key caps models will be published on Thingiverse anytime soon? Even as a WIP project?
Continuing with the 3D model of the function key.
A bit of jigging around and printed out on the finest setting on the printer with a different orientation to have the print lines flow with the key top and it doesn't look half bad. Need to find an F1 stencil :)
