PaulJ wrote: 27 Jan 2020 17:44
Don't have a second set of connector pins for second. I was assuming view command read out binary but it hangs. Is there a command to read binary out and display as hex?
Yes that is what view should do. The number is terminated with a carriage return as I read it with fgets. e.g. i0<CR>
e.g.
Command: view 27C160 (2048KB)
Offset into ROM? [0x]digits[K|M]
000000 11 11 4e f9 00 fc 00 d2 ..N.....
000008 00 00 ff ff 00 22 00 05 ....."..
000010 00 22 00 02 ff ff ff ff ."......
000018 65 78 65 63 20 33 34 2e exec 34.
000020 32 20 28 32 38 20 4f 63 2 (28 Oc
000028 74 20 31 39 38 37 29 0d t 1987).
000030 0a 00 00 00 ff ff ff ff ........
000038 0d 0a 0a 41 4d 49 47 41 ...AMIGA
000040 20 52 4f 4d 20 4f 70 65 ROM Ope
000048 72 61 74 69 6e 67 20 53 rating S
000050 79 73 74 65 6d 20 61 6e ystem an
000058 64 20 4c 69 62 72 61 72 d Librar
000060 69 65 73 0d 0a 43 6f 70 ies..Cop
000068 79 72 69 67 68 74 20 28 yright (
000070 43 29 20 31 39 38 35 2c C) 1985,
000078 20 43 6f 6d 6d 6f 64 6f Commodo
000080 72 65 2d 41 6d 69 67 61 re-Amiga
000088 2c 20 49 6e 63 2e 0d 0a , Inc...
000090 41 6c 6c 20 52 69 67 68 All Righ
000098 74 73 20 52 65 73 65 72 ts Reser
0000a0 76 65 64 2e 0d 0a 00 00 ved.....
0000a8 65 78 65 63 2e 6c 69 62 exec.lib
0000b0 72 61 72 79 00 00 4a fc rary..J.
0000b8 00 fc 00 b6 00 fc 32 76 ......2v
0000c0 00 22 09 78 00 fc 00 a8 .".x....
space for more
You can use DUMP to dump the whole hex file as well. I suspect that module is damaged.
