27C400/27C800 EPROM emulator
- Admin sponsor
Re: 27C400/27C800 EPROM emulator
Great work. This is what all my Amiga's need.
- GadgetUK164
Looking very cool!!! Super useful if it can be programmed easily enough!
I did a PCB to adapter to an Acorn Master MOS (1Mbit 128Kx8 mask ROM). Just sent the PCB order off.
Working well in a rev 5 Amiga 500. The data buffers are HCT so 5v CMOS output levels - won't require pull ups like a 27C400 does in a rev 5... The wire goes to the _RESET signal to get ROM swithcing from the keyboard with ctrl+A+A. (ROM switching can also be done via the USB which might be useful for synths, drum machines and other non-computer gear)
Firmware is functional. I have features to add but the core functionality is proven working
Shut up and take my money!
Hi!
Great product in the making!
Is it possible to mix rom sizes? 4 x 256K images (1.2, 1.3, DiagRom) and 2 x 512K images (2.04, 3.1.4) ?
Again, great to have people like you and others making new hardware for the machines we grew up with and still love and use
EDIT: I am using an A500 Rev 6a motherboard.
JanHolbo
I know that you seem to have Amigas covered. I would like to help out as well if you need though. I would pay the cost of both kit and P&P to Denmark, if it is not too expensive.cmorley wrote: Tue Jul 16, 2019 6:57 am I think if TerribleFire and Chucky test then the Amigas are covered.
JanHolbo
Amiga 500 Rev 8a
Only with manual switches. You need A17 connected to the Amiga for 512K image but controlled by the switching for a 256KB image.JanHolbo wrote: Wed Aug 28, 2019 9:43 am Is it possible to mix rom sizes? 4 x 256K images (1.2, 1.3, DiagRom) and 2 x 512K images (2.04, 3.1.4) ?
Chris
Thank you for the answer. Checking on my 2.0 Rom it is a 2.04 (37.175) that does not support IDE boot.cmorley wrote: Fri Aug 30, 2019 2:59 pmOnly with manual switches. You need A17 connected to the Amiga for 512K image but controlled by the switching for a 256KB image.JanHolbo wrote: Wed Aug 28, 2019 9:43 am Is it possible to mix rom sizes? 4 x 256K images (1.2, 1.3, DiagRom) and 2 x 512K images (2.04, 3.1.4) ?
Would putting DiagROM and 1.3 on 512K images together with 2.04 and 3.1.4 (4 x 512K images total) work?
Any preview on price and date of release for either a prototype or RC board?
Jan
Yes that works. I have tried (4 of) 1.2, 1.3, 3.1, 3.1.4 & DiagROM.JanHolbo wrote: Sat Aug 31, 2019 11:47 am Would putting DiagROM and 1.3 on 512K images together with 2.04 and 3.1.4 (4 x 512K images total) work?
If you set the module up as 4x 512KB ROMs and program a 256KB image my firmware programs it twice (so either high/low on A17 is the same ROM image). It also handles byte swapping at program time.
I know there is space in the memory map on an Amiga for an extra ROM but not what you can use that for. In 1MB mode with a flylead from the CPU or Gary you could use this from one module. Is this useful on an A2000 I don't know?
I have a few more of the prototypes. Some are destined for testing in other systems. Terriblefire isn't testing so I sent 2 to Chucky. I don't know how much they will be yet because I am going to get these assembled - batch size and economy of scale will make them cheaper but then I need to pay more money up front and greater risk if there is a fault with them. My aim is that these will be cheaper than the existing multi EPROM/ROM switchers that are for sale now.
Chris
Working in an 8-bit machine. This is an Acorn Master using the ROM emulator/switcher to replace the 128KB MOS mega chip (contains MOS, ROMs & character set). ROM switching working from the BREAK key
I will send this off to a friend who uses his Master daily (he did Y2K fixes and assembled MOS images for various versions/configs including a OS 1.20 for better model B compatibility).
