The 5V ISSI and 5V alliance chips don't work without clock buffer. Apparently the 3V chips do.terriblefire wrote: 15 Jul 2019 11:41 The CPLDs are 3.3v chips. They need the JTAG to behave at 3.3v.
They should work fine. There has been extensive testing on this. just dont use the clock buffer. Its not needed on the CD32.
Early blue TF328 problem
alenppc
- Moderator Team
Re: Early blue TF328 problem
alenppc
- Moderator Team
I have prebuilt TF330s for $115 USD/£90 GBP. I still haven't managed to get rid of all the stock, but I am hoping they will soon be gone.Smaug wrote: 15 Jul 2019 08:29 How much is the TF330 alone, I already have a Kipper2K v6 riser and loads of CF adapters used on my other Amiga stuff!...
/Mikael
