TF536 on the ST
Other boosters or variants.
Re: TF536 on the ST
@terriblefire i tbought that might be the case. Ill disable them and see how things go.
Umberto1st
Re: TF536 on the ST
Post by Umberto1st »
I have been using Exxos V7 HD upgrade without any problems. I have even removed it to test the dma and found no difference. I would pull the hd upgrade and install a stock 68000 and retest. The HD upgrade has actually improved floppy reliability due to the 10k pull ups
3)1040 stf/m, 2)Mega 4 ST, 1)STE, 1)Mega STE, 1)STacy, 2)Falcon 030
Re: TF536 on the ST
@Umberto1st that's how I tested the floppy worked. Will pop the pullups onto a wd1772 and try with DD and the TF536
Umberto1st
Re: TF536 on the ST
PhilC wrote: Thu Aug 13, 2020 9:16 am @Umberto1st that's how I tested the floppy worked. Will pop the pullups onto a wd1772 and try with DD and the TF536
I also did this fix for good measure
https://www.exxosforum.co.uk/forum/viewt ... =17&t=1395
Re: TF536 on the ST
Guys, I would park this for the time being. I have no time to investigate at the moment
Umberto1st
Re: TF536 on the ST
Appreciate all the help, do what you need to do my friend, like I said I'm supposed to be working on a Falcon
Umberto1st
Re: TF536 on the ST
One other thing I have done on the V7 HD upgrade, is I am using a AJAX FDC
Re: TF536 on the ST
Umberto1st wrote: Thu Aug 13, 2020 9:40 am
That may be why yours works at 1.44mb when mine doesn't as mines a standard 1772
Umberto1st
Re: TF536 on the ST
PhilC wrote: Thu Aug 13, 2020 10:19 am
Could be, but I also have a STFM set up for the TF534/536 with a ver 5 HD and a 1772 and it works
Umberto1st
Re: TF536 on the ST
Try turning cache off, you can do it in xboot or the general tab in the control panel. I have found that cache turned on can mess with the floppy.
Return to “EVERYTHING ELSE”
