:o)
TF536 on the ST
Other boosters or variants.
Umberto1st
Re: TF536 on the ST
Post by Umberto1st »
No go on auto boot with PP's drivers
3)1040 stf/m, 2)Mega 4 ST, 1)STE, 1)Mega STE, 1)STacy, 2)Falcon 030
Re: TF536 on the ST
Have you tried the 1GB image i posted back?
Umberto1st
Re: TF536 on the ST
terriblefire wrote: 10 Aug 2020 08:32 Have you tried the 1GB image i posted back?
I have, plus the IDE image provided with Peter Putnik's Hard disk driver. Its not for lack of trying. I'm on furlough right because of the virus and have plenty of free time. When TOS is booting is will attempt to boot from the IDE compact flash adapter. The activity LED will come on and stay on. It will not boot the drives until the floppy loads the HDD driver. This is the same for HD Driver and PP's driver. Its like it is waiting for the INT or ACK to occur that never happens. Emutos has always booted correctly, with the exception that it does not boot the HD driver .SYS file. I'm sure that is because it has its own HD driver built in, and is normal behavior for it.
Re: TF536 on the ST
Very strange.. it worked for me but i dont have a swapped cable to test.. Also I am using H4 not a ST.
EzdineG
Re: TF536 on the ST
Post by EzdineG »
As one of those thoroughly confused by these byte swap shenanigans, could the difference be between an image that is completely swapped (including MBR) and an image that is swapped and then the driver is written natively (or un-swapped MBR, but swapped image) ?
I have had nonsensical results myself with swapped, un-swapped and PP driver hex edited images. PPutniks drive image software further confuses my results as it has a "swap L/H" option when writing to media that has made some non working images work for me.
Re: TF536 on the ST
I can probably make myself a twisted cable if anyone knows which bits to swap? (In between fixing my floppy)
Umberto1st
Re: TF536 on the ST
PhilC wrote: 10 Aug 2020 16:41 I can probably make myself a twisted cable if anyone knows which bits to swap? (In between fixing my floppy)
https://www.exxosforum.co.uk/forum/viewt ... =30#p26499
It took 10 minutes to modify a cable, easy deal
third photo down
EzdineG
Re: TF536 on the ST
Post by EzdineG »
Umberto1st wrote: 10 Aug 2020 18:52
third photo down
But this shouldn't be needed if you're using a PC format image, right? The TF is already "twisted", so twisting it should only help with TOS images. Screw TOS images :)
Umberto1st
Re: TF536 on the ST
EzdineG wrote: 10 Aug 2020 18:55
third photo down
With Emutos i does not matter, twisted or not twisted cable, or format to that matter. But it has its limitations, but is in constant development, I prefer TOS 2.06 for compatibility reasons.
Umberto1st
Re: TF536 on the ST
PP's Hard disk driver is incompatible with the TF536 and TOS 2.06.I can partition but reads and writes are all corrupted. I have tried on multiple machines with the same result. I think its time to set the TF536 to the side for a while and get onto repairing my Falcon. I don't have any hair left to pull out. Hoping these issues can be worked, since it is a nicely designed booster.
Return to “EVERYTHING ELSE”
Users browsing this forum: Bing [Bot], CCBot and 0 guests
