Ok. works both in EmuTOS and TOS2.06 here.PhilC wrote: 05 Aug 2020 16:59 I'm using a CF card with straight cable. Refresh with a previous good firmware i use for testing and its all good again but no HD
I'm using PP's IDE image.
Do you have a link to this? I am as confused as ever as to which kind of partition needs to have the IDE byte swapped and which doesn’t.
https://atari.8bitchip.info/DiskImgPP1.htmlEzdineG wrote: 05 Aug 2020 19:57Do you have a link to this? I am as confused as ever as to which kind of partition needs to have the IDE byte swapped and which doesn’t.
I do understand that the TF looks like *IT IS* already swapped to the ST, so swapping it here would be like unswapping on a typical ST IDE.
On that page there is this information:
Is that something you can share to rule out image issues? I've tried the latest firmware on two H4s, a Mega ST and an STFM and aren't having the success you've had at all.terriblefire wrote: 05 Aug 2020 20:57 Still working lovely here.
My 1Gb.img has the ide header overlapped and i byte swapped it.
Users browsing this forum: Ahrefs [bot], CCBot and 3 guests
