TF536 on the ST
Other boosters or variants.
Methanoid
Re: TF536 on the ST
Post by Methanoid »
Is it possible to fit the keyboard and close the case with one of these or is there a relocator board like on the Amiga 500 that solves the issue?
Re: TF536 on the ST
Nobody has solved the re locator issue yet. Some ST models its probably possible due the CPU location being seemingly random on the ST motherboards :)
ube
Re: TF536 on the ST
Post by ube »
terriblefire wrote: Mon Jun 17, 2019 7:11 pm Nobody has solved the re locator issue yet. Some ST models its probably possible due the CPU location being seemingly random on the ST motherboards :)
I'll guess the STM motherboard is probably the best.. And.. Oh, there's two in my bookshelf. Now, if I only could get my hands on a 536 PCB I could probably make one, if it's needed.. :)
master of the bare pcb
Methanoid
Re: TF536 on the ST
Post by Methanoid »
ube wrote: Mon Sep 16, 2019 10:58 pm
https://atariage.com/forums/uploads/mon ... 515781.jpg
It looks like (depending on the orientation of the CPU which doesnt look like it is socketted) it will either fit almost perfectly or NOT at all... Maybe you can tell us since you have the STM and https://www.exxosforum.co.uk/forum/viewt ... =76&t=1887 shows a perfect pic of the board that you could test fit after printing? :D
Re: TF536 on the ST
The Tf cards would go towards the back of the case on that board
agranlund
Re: TF536 on the ST
Post by agranlund »
I don't know if the dimensions are exactly the same as the TF534, but at least for the that card the floppy connector will be in the way unless it's raised up quite high to clear it, or relocated a little bit toward the front of the machine. But other than that I think it should fit really well in the STM :)
It should probably be moved a bit to the left also, to avoid the relocator board from colliding with Exxos 4MB upgrade :)
(The board in this picture is moving the CPU 3.81mm toward the front and that caused clearance issues with the Ram upgrade, hence the Dremel action)
Re: TF536 on the ST
I've been testing the TF536 on the H4 and it runs desktop ok but crashes (2 Bombs) the moment music starts..
I'm thinking this is some interrupt issue?
Re: TF536 on the ST
What music ? A lot of chipmusic was pretty buggy to start with.. if you can run GB6 fine , then you can't be far off.. Though it doesn't test audio of course..
Re: TF536 on the ST
exxos wrote: Fri May 29, 2020 12:20 am What music ? A lot of chipmusic was pretty buggy to start with.. if you can run GB6 fine , then you can't be far off.. Though it doesn't test audio of course..
Sorry. Completely missed a vital part of the context there.
Running Frontier. Crashes the instant the chipmusic starts with the Tf536. I'm sure @agranlund will confirm that the TF534 doesnt do this (i'll dig one out and try).
I'm guessing this is some kind of interrupt issue as the desktop click work ok.
Re: TF536 on the ST
@terriblefire no problem running Frontier on 534 but 536 crashes for me too.
I have been working on a relocator for the STFM will post details when back from work later.
Return to “EVERYTHING ELSE”
