The TF536 arrives
Re: The TF536 arrives
Perhaps some other component is dodgy, like the power supply or A500 itself?
- Admin sponsor
I had issues with it initially... Alen uses the pinstrip upside down compared to how I normally solder them (now ... I used to solder them that way round and had connection issues)
Can you post a pic of one of yours? I’m a little confused as to what you’re inferring.terriblefire wrote: Thu Aug 08, 2019 1:21 pm I had issues with it initially... Alen uses the pinstrip upside down compared to how I normally solder them (now ... I used to solder them that way round and had connection issues)
- Admin sponsor
This photo..
The top half of the strip is longer and thinner. I orient it so the fatter bottom pins make contact with the Amiga
Hello! I'm confused as well, on the picture the bottom pins are thinner (meant
for socket) and top pins are fatter (solder side)...
- Admin sponsor
But it doesnt work if you do that in my experience. The fatter pins fit nicely in turned pin sockets.richx wrote: Sun Aug 11, 2019 5:05 pm Hello! I'm confused as well, on the picture the bottom pins are thinner (meant
I’m not arguing what the manufacturer intended.. I’m just saying it doesn’t work.
Worth trying next time I build a board as the small pins are often too loose.
Is it a one shot thing TF? Ie does not damage the socket when inserted?
- Admin sponsor
It’s not going to damage a turned pin socket. It will damage a square pin socket. I usually put a turned pin strip on my relocators.
Will give it a try next time, thanks.terriblefire wrote: Tue Aug 13, 2019 11:20 am It’s not going to damage a turned pin socket. It will damage a square pin socket. I usually put a turned pin strip on my relocators.
I am gonna try soldering it the other way round next time. It just seemed logical to me that one would want longer pins on the bottom, but I guess I was wrong.
