So there is 3K difference between my code and the file I read from the TF board itself.. I notice the make file compiler options is for speed.. can't for the life of my find any compiler options in the ISE anywhere. google no help either.
OK in strategies then... looks like set to speed anyway...
EDIT2:
PRogramed my compiled jed and the ST is still booting, so no idea what the differences are....
exxos 534 blog - Atari
Re: exxos 534 blog - Atari
LOL, thats apretty good start from my point of view
Just doing a benchmark. can't make it any worse I guess :lol:
A bit better....
I'd say that's a pretty good improvement over the last results
Fraction better...
The caches only seem to give 3% on the first test (without data cache is 100%) but it should be more like 25% faster on all tests :shrug:
I've got some 50mhz smt crystals which I shall put on in a bit, want me to try your firmware with it?
Yeah, can do. 50mhz might bring RAM speed up to 100%...PhilC wrote: 13 Jun 2019 19:21 I've got some 50mhz smt crystals which I shall put on in a bit, want me to try your firmware with it?
OK let me dump this here before I balls it up anymore...
Cyprian
http://260ste.atari.org
