Pinmap is in the ucf files. That’s what it’s for. It’s in my sources. Just add it to the project. You need a project for ram cpld and one for bus cpld.
The chips are a
XC9572XLVQ64-10 for the bus cpld.
XC95144XLTQ100-10 for the ram cpld
I don’t use projects or the IDE. I have a Linux makefile that build multiple boards from the same sources. The IDE sucks
The ucf files you need are here
https://github.com/terriblefire/tf534/t ... s/tf534r2c
exxos 534 blog - Atari
- Admin sponsor
Re: exxos 534 blog - Atari
OK thanks. So with all the .V files, what exactly gets loaded into which chip ? I will start with the bus one first anyway..
- Admin sponsor
The files required by each are listed in the makefile
https://raw.githubusercontent.com/terri ... c/Makefile
Think I've got it loaded in right..
The IDE has some terrible screwy redraw bugs :roll:
- Admin sponsor
This is why I just use visual studio code and a makefile
#makecable
Well got this far...
- Admin sponsor
You compiled that for an XA9572 not an XC9572XL
ah, seems the 9500 is listed in 3 different options in the menu :roll:
Users browsing this forum: CCBot and 22 guests
