Hehe. There are plenty of alternatives for the A500.
New Board TF536
- Admin sponsor
Re: New Board TF536
- arkadiusz.makarenko
- Moderator Team
Re: New Board TF536
True.
Very few open access options for DIY'ers, though.
Edit. That advanced set. There is TF530 and TF534 after all.
~ Stanislaw Lem
~ Stanislaw Lem
- Admin sponsor
Re: New Board TF536
Pretty sure all of Matze's boards are OS.arkadiusz.makarenko wrote: Thu Dec 05, 2019 10:00 am
EDIT: E.g. https://gitlab.com/MHeinrichs/68030tk
- Moderator Team
Re: New Board TF536
Great project.terriblefire wrote: Thu Dec 05, 2019 10:16 amPretty sure all of Matze's boards are OS.arkadiusz.makarenko wrote: Thu Dec 05, 2019 10:00 am
But at this point it is great experimental kit.
(I think I will actually build it)
TF536 did seem to be much closer to be a rock solid DIY solution.
~ Stanislaw Lem
~ Stanislaw Lem
- Admin sponsor
Re: New Board TF536
Except it doesnt work.arkadiusz.makarenko wrote: Thu Dec 05, 2019 11:03 am TF536 did seem to be much closer to be a rock solid DIY solution.
- Moderator Team
Re: New Board TF536
I would call it mixed reviews.terriblefire wrote: Thu Dec 05, 2019 11:18 amExcept it doesnt work.arkadiusz.makarenko wrote: Thu Dec 05, 2019 11:03 am TF536 did seem to be much closer to be a rock solid DIY solution.
In this hobby 50% success rate (in sample of 2 ?), in my opinion it is very high success rate.
Comparing this to Matthias card - TF536 in current state is much more mature solution IMHO.
~ Stanislaw Lem
~ Stanislaw Lem
- 8 Bit Dreams
- Moderator Team
Re: New Board TF536
Well,
This is something i can't explain atm.
At the beginning i was thinking Alen just used different parts to build his Prototype, and that's why card wasn't stable, but then he sent it to Stephen, after some thinkering it worked just fine on Stephens setup, so these wasn't parts he used...
Alen tested his card on different systems, got same result though, so im starting to think it's the CPUs Alen used.. Yes, i know this sound silly, but it MAY be possible, got this phenomenon on TF534 cards, where 33Mhz CPUs working fine @50Mhz on 2b & 2c cards, but are unstable on latest 2d rev.. Don't know what's causing that, but that's the fact. Also 50Mhz ceramic cpu quits after 10 min. or so (seems to be fake), however original 50Mhz removed from Blizzard IV works great. Also original 33Mhz ceramic CPUs bought from US are working stable.. So yeah, need more tests to make final conclusion...
Re: New Board TF536
No, I tried many different CPUs, I also built 2 boards and both have identical problems. It works as long as you keep the CPLD freezing cold with the spray, hangs as soon as you stop. There is more to it than that, so I perfectly understand Stephen not wanting to go down that rabbit hole.
Can you just imagine the complaints and the pestering cause the board won't work on some systems...
- Moderator Team
Re: New Board TF536
It is clear that releasing this as commercial product is out of the question.alenppc wrote: Thu Dec 05, 2019 6:00 pm No, I tried many different CPUs, I also built 2 boards and both have identical problems. It works as long as you keep the CPLD freezing cold with the spray, hangs as soon as you stop. There is more to it than that, so I perfectly understand Stephen not wanting to go down that rabbit hole.
~ Stanislaw Lem
~ Stanislaw Lem
Re: New Board TF536
Thanks for developing the 500 accelerators anyway.
If there is another 500 accelerator I will might try to build it too. Maybe I'll get a CD32 or something too.
