So It now works with jumper in the Active position? and when you put the jumper on the DISABLE position it disables the TF330 from the CD32 ?
330 disable function bug
Re: 330 disable function bug
Mister_Grave
No. The problem is that I can no longer deactivate it.
Clean the Jumper pins with alcohol and try it again
disabled jumper position below
Mister_Grave
That's the first thing I did. I also recleaned all the contacts on the card as well as the riser.
Then that is a puzzle, if it has the correct firmware posted in this thread it should work, can you reflash the board yourself ? or know someone who can do it for you
Mister_Grave
I theoretically have everything I need to do it: I have Jtag cables, I have a pi4 (which serves as a Home assistant). It's just a bit laborious...
If the firmware was bugged, the tf330 wouldn't work at all, right?
Its the only thing I can suggest to see if it works with a reflash
Mister_Grave
Ok.... Is there a simple tutorial?
32bits did a nice pi tutorial
Mister_Grave
Thank you !
And last question, does the Firmware you are offering here contain the latest performance boost improvements?
