330 disable function bug
68030 + SDRAM + IDE
Mister_Grave
Re: 330 disable function bug
Post by Mister_Grave »
supaduper wrote: Thu Dec 05, 2024 3:02 pm Firmware has all previous fixes so it is good to go
Regarding the Switch, it is a on/on switch so it is self explanatory ,the switch will have three connectors, so middle pin ( is the Shared connecter on the switch) will go to the Bottom left pin nearest the IDE connector ( this is looking down on the TF330) the other two connectors does not matter, just put one to the bottom right pin and the other to top left pin
Just study my pictures of the jumper positions and this will give you the correct connections
Thank you very much for the explanations! the switch also disables access to the CF card?
supaduper
Post by supaduper »
Mister_Grave wrote: Fri Dec 06, 2024 8:39 am
Yes, it disables the TF330 completely from the CD32
Mister_Grave
Great, that seems perfect, I just wanted to be able to find the “vanilla” CD32 using a switch.
If in the future I want to move from a TF330 to a TF360, can we upgrade the card or should we buy one again?
supaduper
Post by supaduper »
Mister_Grave wrote: Fri Dec 06, 2024 9:01 am Great, that seems perfect, I just wanted to be able to find the “vanilla” CD32 using a switch.
You need to buy the TF360, you cannot upgrade TF330 to TF360 it`s impossible to do
Mister_Grave
supaduper wrote: Fri Dec 06, 2024 10:25 am
ok. The TF360 was not for sale on amigastore, I only found out about it after ordering it :-s
supaduper
Post by supaduper »
Mister_Grave wrote: Fri Dec 06, 2024 10:45 am
The TF360 is not available through stores, only available from verified TerribleFire builders like me and a few others ;)
alenppc
Post by alenppc »
supaduper wrote: Fri Dec 06, 2024 10:50 am
Indeed, for any TF boards, always check with official builders first if you want good quality and support :)
Mister_Grave
I'm coming back to you because after 1 month of fun with my tf330 my deactivation switch no longer works since today 0_o
I removed the card, removed the switch, restarted, did all the tests I could, it no longer works. :-(
supaduper
Post by supaduper »
First off test that the jumpers are working so test the TF330 without the switch but with Jumper in both positions as shown in my pictures above to see if it works, I guess that your switch is gummy and just needs some contact cleaner,its a common fault
Mister_Grave
I just took the test. The tf330 remains activated.
Return to “TF330”
