:o)
:o)
330 disable function bug
MickGyver
Re: 330 disable function bug
I read in another thread that you are stopping the development of your boards. Sad to hear that but a big Thanks for all your precious work! :) If you ever find the time energy to fix this disable bug, I would be super grateful. I know how annoying it can be to troubleshoot and find bugs like these though...
- Admin sponsor
Yeah this one is the first bug I’ll tackle
wairnair
Hi Stephen,
Do you think you could take a short detour sometime to fix this issue? It would finalize the TF330 project (since the NVRAM issue is sorted and there's nothing else left afaik).
Also looking forward to the riser, very exciting.
Cheers
Cheers
- Admin sponsor
Its on my list but sorta low down the order... Currently havewairnair wrote: 18 Jan 2020 12:04 Hi Stephen,
Cheers
1. TF1260
2. Tf360
3. TF Riser
4. TF536
5. TF330 Disable Bug
matt020
If I try the disable switch.... and if the 030 kicks in causing one of the CPU's to get hot.... will it get dangerously hot? I want to try this but not if its going to cause the 020 to cook and I don't know its cooking...
- Admin sponsor
I wouldnt leave it like that for a prolonged period.matt020 wrote: 19 Jan 2020 00:04 If I try the disable switch.... and if the 030 kicks in causing one of the CPU's to get hot.... will it get dangerously hot? I want to try this but not if its going to cause the 020 to cook and I don't know its cooking...
- Admin sponsor
OK folks.. this is untested and is for the TF330 rev3 only... (which is the most common TF330).
But if anyone wants to try out this disable bug possible fix its here
You may find you the disable jumper behaviour changes.
supaduper
Just tried the firmware Steve and removed the Jumper but it does not disable the TF330 it still boots to the CF, so weather the Jumper is there or not it still boots to CF/IDE, but it will still boot game CDs with the jumper on
Just to add I do have 10k resistors on the disable line
- Admin sponsor
Try putting the jumper on at 90 degrees to how it is currently. I.e. how it was originally supposed to work. It actually may still boot the CF card but possibly will be in 020 mode. I can deal with that later.supaduper wrote: 19 Jan 2020 06:48 Just tried the firmware Steve and removed the Jumper but it does not disable the TF330 it still boots to the CF, so weather the Jumper is there or not it still boots to CF/IDE, but it will still boot game CDs with the jumper on
supaduper
Just did what you said put jumper at 90 deg and it just goes to the splash screen and CD drive not working/booting CDs
Users browsing this forum: Amazon [bot], CCBot and 1 guest
