ALPHA CPU Extension Board - Yes Another Tower
Re: ALPHA CPU Extension Board - Yes Another Tower
For those making the extension board I thought I would make the patch clearer to see if you decide to remove the patch resistors from underneath.
This was my board with the patch resistor under the white tape and lines. There was also another line to the other SIL resistor as well:
After removing the patch (because you are using the extension board SIL) the underside should look like this:
IMG_3999 (1).jpg (147.32 KiB) Viewed 5162 times
There is a patch you need to do on the extension board but its a small wire not so messy as the Remake board patch it replaces.
