STe replacing motheboard capacitors
The latest tweaks and fixes to keep your machine running in tip-top shape.
Re: STe replacing motheboard capacitors
Yep indeed. If you cannot solder and de-solder without destroying the boards then you are probably in the wrong hobby.
exxos wrote: Sun Nov 21, 2021 7:48 pm Yep indeed. If you cannot solder and de-solder without destroying the boards then you are probably in the wrong hobby.
Now you tell me? :lol:
Return to “TWEAKS & FIXES”
