I thought there was a guide somewhere as well, but couldn't find it. Think the CF card needs formatting as "FAT"... ?rubber_jonnie wrote: Tue Mar 22, 2022 10:47 pm Hmm, I thought I'd done a guide for this already, but yes, you need to set up the partitions for TOS & Window at the same time, which is done through the HDDRIVER config tool. you don't need a FAT32 partition, you just need to format it right on the ST.
As @exxos said, just go for all 256MB partitions with HDDRIVER and don't forget with V11 you can use Blitter acceleration too.
Using HDDriver 10.14 to Create Eight Partitions (First One Bootable) on a 4GB SD Card
Re: Using HDDriver 10.14 to Create Eight Partitions (First One Bootable) on a 4GB SD Card
Actually I just checked my Mega 4 which has a CF card and the partition sizes, including C: are about 512MB with HDDRIVER 11, but I am using TOS 2.06 in both the Mega 4 and the MSTE which has a CosmosEx and SD card.
When you select the drive to partition, there is a compatibility button in there that allows you to use TOS and Windows compatibility together so the cards can be used under either TOS or Windows.
I didn't tick the byte swap option and it worked just fine. Experiment a bit see what you get. I would advise that you wipe the SD or CF card beforehand, it just works a bit better. I usually do this using diskpart under windows and the clean command.
Ok, so thanks to all for their help...I managed to get it working!
I wiped the CF card as @rubber_jonnie suggested, then popped it into the ST, booted from floppy & configured the whole CF card as a single partition (Windows + TOS compatible but no byte swap), rebooted, then installed HD Driver on the CF card & all is working...I can transfer files via the CF card between PC and ST just as advertised!
Really cool!
Really cool!
SplendidJezC wrote: Wed Mar 23, 2022 10:17 pm Ok, so thanks to all for their help...I managed to get it working!
Really cool!
