Mega ST - Internal Ultrasatan Bracket (Lotharek)
macsonny
Re: Mega ST - Internal Ultrasatan Bracket (Lotharek)
Thanks - appreciate it
Looks like it's view only. No way to download or import into Fusion360.
It would need the project to be shared by @PhilC directly from Autodesk's online Fusion to download it.
I no longer have it in my library on Fusion, so I'm unable to download it. As Stephen says, its now view only.stephen_usher wrote: 30 Dec 2024 11:04 Looks like it's view only. No way to download or import into Fusion360.
Darklord
Just a reminder - I mentioned this in another post, but Lotharek has changed the
mounting holes on the latest run of internal Ultrasatan's. The one I purchased
recently does not mount up the same as the previous US I had bought and put in
my Mega STe. Also, the dual SD-card mounts are set at a slightly different distance
apart than they were before.
The various 3D printed mounting options on Thingiverse, for example, won't fit
the new model I have (unless someone has changed them since my post).
viewtopic.php?f=29&t=7423
macsonny
Ok, seems there isn't really a solution floating around right now.
I'll plan to design my own bracket over the next few days.
Will post here once done.
macsonny
Ok, so it's starting to come together. I've used a Gotek STL file and modified the front and the mount points of the UltraSATAN.
Still making a few tweaks but will post STL file here when done.
Darklord
Hmm, had this lying around on my hard drive...
macsonny
Ok. So after a few revisions (5 in total) I've got a final version which I think works ok.
Here are a few photos of it installed in my Mega ST 4 including on showing the internal mount.
I've attached the original STL file. If any one is handy with CAD software maybe you could make the outline for the drive to mount into the front faceplate a bit thicker towards centre as it's currently a bit think and doesn't print great. I'm thinking an extra 0.5mm all the way around would be perfect.
Note this is for the most current version of the UltraSatan board.
Hope this is of use to a few people out there!
Darklord
Oh, my bad - I thought you were going for the rear cover plate, not for
the floppy drive bay.
Glad you got it sorted out. :)
Looks good to me, mine used the rear expansion port for the US.
Users browsing this forum: CCBot and 6 guests
