exxos blog - random goings on
.. why the heck does it put a via right next to a though-hole part when it could just take the track right next to it
Made a fair bit of progress....
The SYNC protection diodes should be next to the monitor connector.. they are next to the DMA on the Alpha
#brainturnedoff
This part about done
Onto the DMA area next...
Just doing a initial autoroute to see where the bottlenecks are with where I have placed components, this is by no means the final version, and is a long way off, I need to add the SIMM socket yet etc..
I am going to move the oscillator and buffer, more towards the back end of the shifter, where there is a bit more room, it should help with the routing around the CPU etc...
72pin simm added. I have left the Falcon board on there for the time being, it is always possible I have wired up the SIMM wrong, so always good to stick with what works for now
The Falcon RAM board will probably be removed in the revision after this board..
Can'ya tell what it is yet....
I'm guessing something to do with the 16Mhz mod for the STF remake?
rubber_jonnie wrote: Fri May 03, 2019 3:52 pm I'm guessing something to do with the 16Mhz mod for the STF remake?
Autorouter working its magic....
I just received some board this morning to make a neater job of my diabolical wiring hack to get the 16MHz mod working.
