exxos blog - random goings on
derkom
Post by derkom »
exxos wrote: Mon Apr 27, 2020 4:51 pm It looks like when I moved the capacitors about, to the right, I must have missed that one for some reason it should have been further to the right :roll:
Why doesn't ERC catch that?
derkom wrote: Mon Apr 27, 2020 5:31 pm Why doesn't ERC catch that?
No idea.
Oh it does, I must have skipped past it :roll:
STEP 1: Drill holes in PCB.
STEP 2: Damaged Control.
STEP 3: Bodge wire.
:cussing: :cussing: :headbang: :pullhair: :foldarms:
:dizzy:
Diagrom time...
@terriblefire Need a translation maybe :lol:
Garbage before this text was binary numbers: 1, 2, 4, 8, 16, 32, 64, 128, 240, 1                        5, 170 and 85
To help you find biterrors to the mfp. Now starting normal startuptext etc
Atari DiagROM V0.9 - 19-Sep-18
                               - By Stephen J. Leary
 - Based on the Amiga Version By John (Chucky/The Gang) Hertell
- Parallel Code $ff - Start of ROM, CPU Seems somewhat alive
 - Resetting all hardware (RESET instruction): Done.
 - Reinitialising Video ($10000): Done.
 - Sending reset to keyboard controller (IKBD Reset): Done.
- Parallel Code $fe - Test UDS/LDS line
 - Test of writing word $FFFF to $400 FAILED.
 - Test of writing word $00FF to $400 OK.
 - Test of writing word $FF00 to $400 FAILED.
 - Test of writing word $0000 to $400 FAILED.
 - Test of writing byte (even) $ff to $400 OK.
 - Test of writing byte (odd) $ff to $401 OK.
- Parallel Code $fd - Start of chipmemdetection
  - Performing MMU Configuration: $00 Done.
Addr $00000400Write:AAAAAAAARead:AAABAAAB   FAILED
Addr $00000400Write:55555555Read:AA55AA55   FAILED
Addr $00000400Write:F0F0F0F0Read:AAF1AAF1   FAILED
Addr $00000400Write:00000000Read:00010001   FAILED
Addr $00008400Write:AAAAAAAARead:AAABAAAB   FAILED
Addr $00008400Write:55555555Read:AA55AA55   FAILED
Addr $00008400Write:F0F0F0F0Read:AAF1AAF1   FAILED
Addr $00008400Write:00000000Read:00010001   FAILED
Addr $00010400Write:AAAAAAAARead:AAABAAAB   FAILED
Addr $00010400Write:55555555Read:AA55AA55   FAILED
Addr $00010400Write:F0F0F0F0Read:AAF1AAF1   FAILED
Addr $00010400Write:00000000Read:00010001   FAILED
Addr $00018400Write:AAAAAAAARead:AAABAAAB   FAILED
Addr $00018400Write:55555555Read:AA55AA55   FAILED
Addr $00018400Write:F0F0F0F0Read:AAF1AAF1   FAILED
Addr $00018400Write:00000000Read:00010001   FAILED
Addr $00020400Write:AAAAAAAARead:FFFFFFFF   FAILED
Addr $00020400Write:55555555Read:D2E9D2E9   FAILED
Addr $00020400Write:F0F0F0F0Read:08E708E7   FAILED
Addr $00020400Write:0F0F0F0FRead:BBF7BAF7   FAILED
Addr $00020400Write:00000000Read:FFFFFFFF   FAILED
Addr $00028400Write:AAAAAAAARead:FFFFFFFF   FAILED
Addr $00028400Write:55555555Read:FFFFFFFF   FAILED
Addr $00028400Write:F0F0F0F0Read:FFFFFFFF   FAILED
Addr $00028400Write:0F0F0F0FRead:FFFFFFFF   FAILED
Addr $00028400Write:00000000Read:F3EFF3E3   FAILED
Addr $00030400Write:AAAAAAAARead:E4EDE4ED   FAILED
Addr $00030400Write:55555555Read:C8E5C8E5   FAILED
Addr $00030400Write:F0F0F0F0Read:FFFFFFFF   FAILED
Addr $00030400Write:0F0F0F0FRead:FFFFFFFF   FAILED
Addr $00030400Write:00000000Read:9DFD9DFD   FAILED
Addr $00038400Write:AAAAAAAARead:FFFFFFFF   FAILED
Addr $00038400Write:55555555Read:FFFFFFFF   FAILED
Addr $00038400Write:F0F0F0F0Read:FFFFFFFF   FAILED
Addr $00038400Write:0F0F0F0FRead:FFFFFFFF   FAILED
Addr $00038400Write:00000000Read:FFFFFFFF   FAILED
Addr $00040400Write:AAAAAAAARead:00E000E0   FAILED
Addr $00040400Write:55555555Read:00500050   FAILED
Addr $00040400Write:F0F0F0F0Read:00400040   FAILED
Addr $00040400Write:0F0F0F0FRead:00F000F0   FAILED
Addr $00040400Write:00000000Read:00400040   FAILED
Addr $00048400Write:AAAAAAAARead:00E000E0   FAILED
Addr $00048400Write:55555555Read:00500050   FAILED
Addr $00048400Write:F0F0F0F0Read:00400040   FAILED
Addr $00048400Write:0F0F0F0FRead:00F000F0   FAILED
Addr $00048400Write:00000000Read:00400040   FAILED
Addr $00050400Write:AAAAAAAARead:00E000E0   FAILED
Addr $00050400Write:55555555Read:00500050   FAILED
Addr $00050400Write:F0F0F0F0Read:00400040   FAILED
Addr $00050400Write:0F0F0F0FRead:00F000F0   FAILED
Addr $00050400Write:00000000Read:00400040   FAILED
Addr $00058400Write:AAAAAAAARead:00E000E0   FAILED
Addr $00058400Write:55555555Read:00500050   FAILED
Addr $00058400Write:F0F0F0F0Read:00400040   FAILED
Addr $00058400Write:0F0F0F0FRead:00F000F0   FAILED
Addr $00058400Write:00000000Read:00400040   FAILED
Addr $00060400Write:AAAAAAAARead:00E000E0   FAILED
Addr $00060400Write:55555555Read:00500050   FAILED
Addr $00060400Write:F0F0F0F0Read:00400040   FAILED
Addr $00060400Write:0F0F0F0FRead:00F000F0   FAILED
Addr $00060400Write:00000000Read:00400040   FAILED
Addr $00068400Write:AAAAAAAARead:00E000E0   FAILED
Addr $00068400Write:55555555Read:00500050   FAILED
Addr $00068400Write:F0F0F0F0Read:00400040   FAILED
Addr $00068400Write:0F0F0F0FRead:00F000F0   FAILED
Must be assuming 32bit...
AAAAAAAA = 1010101010101010 1010101010101010
AAABAAAB = 1010101010101011 1010101010101011
So assume D0 is stuck...
EDIT2:
OK so D0 bodge wire ended up on D1 :lol: :roll: Now I fixed that...
:roll:
55555555 = 101010101010101 0101010101010101
AA55AA55 =1010101001010101 1010101001010101
Addr $00000400Write:F0F0F0F0Read:AAF0AAF0 FAILED
1111000011110000 1111000011110000
1010101011110000 1010101011110000
This one looks easier...
Addr $001F8400Write:00000000Read:00400040 FAILED
9876543210
00400040 = 10000000000000001000000
So bit 6 to look at next...
:headbang:
So bit 6 fixed....
:roll:
Addr $00040400Write:AAAAAAAARead:00A000A0 FAILED
00040400 = 100 0000010000000000
So bit 10 now :roll:
Seems like loads of bits broken with this one..
F0F0F0F0 Read: 00000000 FAILED
5432109876543210
So bits 4,5,6,7,12,13,14,15 are all high :WTF:
So a whole bank is duff.. but the banks are top and bottom in a row, not as highlighted.. So there is nothing common to all those bits :stars:
Addr $001E8400Write:F0F0 F0F0 Read:0000 0000 FAILED
Addr $001E8400Write:0F0F 0F0F Read:00F0 00F0 FAILED
F0F0 = 1111000011110000
0000 = 0000000000000000
0F0F = 0000111100001111
00F0 = 0000000011110000
Replaced all the DRAM chips and now it just looks like D15 it broken..
Addr $001F8400Write:F0F0 F0F0 Read:8000 8000 FAILED
Addr $001F8400Write:0F0F 0F0F Read:80F0 80F0 FAILED
1111000011110000 f0f0
1000000000000000 8000
0000111100001111 0f0f
1000000011110000 80f0
Plugged in the Atari diagnostic cart...
I1 RAM/data line error 0000000000000000 1111111100000000 000008
So assume its the high bank in error...
EDIT2:
So the bodge wire I put on, was on the wrong pin :roll:
Now the screen is flashing red with....
I3 RAM address check 0000000000001000 0000010000001010 000008
Manual says..
13 RAM addressing. Wrong location is being addressed.
EDIT3:
Back to DIAGROM..
Garbage before this text was binary numbers: 1, 2, 4, 8, 16, 32, 64, 128, 240, 15, 170 and 85
 - Test of writing word $FFFF to $400 OK.
 - Test of writing word $FF00 to $400 OK.
 - Test of writing word $0000 to $400 OK.
Addr $00020400   OK  Number of 32K blocks found: $04
Startaddr: $00000400 Endaddr: $00020000
- Parallel Code $fb - Memorydetection done
- Parallel Code $fc - Start of motherboard fastmemdetection
Then it gets stuck ?!
@rubber_jonnie
In your RAM escapades, you any idea whats going on with this one ?
Manual says..
It looks like A0 is shorted to GND somewhere on the PCB :roll:
