exxos blog - random goings on
Is there a cable that has the ends you need ON BOTH ENDS?
ST: TT030 10/32m; Falcon 030 14m(2); MSTe 4m; MST 4m(3); MST 4m AdSpeed; 1040STf 4m(4); ST 4m(2); MF 44 w/SCSI2SD(3); MF 30(3); MF30 w/Drem
8-Bit: 320XE w/Ultraspeed+/FIXXL; 320XE; 130XE w/Ultimate 1m; 600XL w/Ultimate 1m; 800XL w/Omnimon XL/Boss XL/Omniview XL; 800 w/Incognito; 800 48K; Black Box Enhanced(3); 1050 Super Archiver II; 1050 Happy(2); XF551 360K(2); XF551 720K; HD Tower 480m
Don't think so. Even those cables are getting a bit hard to find these days
Been on the hunt for replacement cartridge connectors.. These came this morning.. 2mm.. not right angle.. they almost fit as well
problem is the connector doesn't have much "edge room" so the cards don't fit because they are basically 1 or 2mm to wide
They do actually seem to fit though with a bit of a shove.. hmm...
Finally got some built up.. need to re-test them all make sure they all still work before they go into stock.
Doing some UK 102/104 DUALTOS ROMs
Some pesky PeST's finally heading into stock...
These arrived today
Also busy packing up the alt-ram board prototypes and remaining pest cables to be sent off and built
Those look familiar. Must remember to test mine, it's been fixed but since then I've been busy on the H4
Is there any more info about this?exxos wrote: Sun Nov 17, 2019 1:28 am Thanks to Icky, we have a render on how this will look
So this board is no bigger than the 68K CPU. Also stackable without using much additional height. This board can be driven with any up coming items, mostly flashy-clock to start with. Then we will finally have some proper benchmarks in GB6 for alt-ram tests
Falcon, TT & some more
I just posted about it above.
