So my H5 B1 seems to have a "unsolvable" RAM fault
- Capture.PNG (48.35 KiB) Viewed 140 times
- IMG_4198.JPG (202.95 KiB) Viewed 140 times
- IMG_4199.JPG (371.08 KiB) Viewed 140 times
Data bus seems to all switch low and give correct ROM start.
- IMG_4197.JPG (345.83 KiB) Viewed 140 times
Changed the MMU, CPU, GLUE..SIMM. Resoldered the simm socket, RAM resistors, MMU, GLUE, SHIFTER..
The Only time anything changed was when I resoldered the buffer chips.. Before it would randomly change pattern moving my hand over the motherboard. Since resoldering , its stopped doing that.
DRD5
- IMG_4201.JPG (385.87 KiB) Viewed 140 times
- IMG_4202.JPG (261.52 KiB) Viewed 140 times
DRD7 (a couple others look the same)
- IMG_4203.JPG (257.71 KiB) Viewed 140 times
So may have to change both the chips.. which is annoying.. as I don't think I have any spares
- Capture.PNG (90.75 KiB) Viewed 140 times
Looks like the pattern just changed
now the screen flashing red rather than the lines
- Capture.PNG (37.64 KiB) Viewed 140 times
