Another suggestion that is similar to RJs above is to use a raspberry pi running footprint. It's a great tool with a good web interface.
Re the prints, not trying to be picky but personally I make the wall and top and bottom layers a little thicker.. prevents the prints from being transparent and provides better strength and on my printer at least, better quality wall finish.
exxos blog - random goings on
I like simple though :)PhilC wrote: 18 Apr 2019 16:18 Another suggestion that is similar to RJs above is to use a raspberry pi running footprint. It's a great tool with a good web interface.
Yeah they are a bit transparent, but thats nothing which can be easily changed. Its not really noticeable once its all assembled anyway.PhilC wrote: 18 Apr 2019 16:18 Re the prints, not trying to be picky but personally I make the wall and top and bottom layers a little thicker.. prevents the prints from being transparent and provides better strength and on my printer at least, better quality wall finish.
0.12mm vs 0.20mm
No real difference unless you're really really looking at it closely.. The 0.20mm may well just have a fraction rougher finished, but it is basically not noticeable.
0.2mm seems a bit less transparent on the bottom oddly.
Also interesting, what wall/layer thickness are you using Phil? I'd be interested to compare against my Cura settings.PhilC wrote: 18 Apr 2019 16:18 Another suggestion that is similar to RJs above is to use a raspberry pi running footprint. It's a great tool with a good web interface.
Repetier is nice, got it free, though there is a paid for version:
That's an interesting one. Next to no difference but, unexpectedly, the quality of the holes looks better on 0.2mm?
Better look at the nut holder..
Nice.
:bravo:
:bravo:
As far as I can see there is no difference... Though what could be throwing the view is that the 0.2mm holes are actually fractionally wider diameter...PhilC wrote: 18 Apr 2019 16:53 That's an interesting one. Next to no difference but, unexpectedly, the quality of the holes looks better on 0.2mm?
These are the ones set in Cura right now. I often print at 0.1 layer height, unless I need something quickly, so my print speeds etc are based on quality rather than speed.rubber_jonnie wrote: 18 Apr 2019 16:52
Layer Height 0.1
Initial Layer Height 0.2
Line Width 0.4
Wall thickness 0.4 (also print at 0.8 at times depending on what its used for)
Wall Line count 2 (also print at 4 at times as above)
Top / Bottom thickness 0.6
Top and bottom layers 6
Top/Bottom Pattern: Lines
Ironing off
Horizontal expansion 0
Infill Density 50 (depends on use again, as I repair items for the wife nursery, so have to make them stronger and kid proof)
Infill Pattern Octet (cos I like the pattern :lol:)
Printing Temperature 200 (will depend on printer and material obviously)
Build plate temperature 60 (as above)
Flow 100%
Retraction Enabled
Retraction speed 40mm/s
Print Speed 60mm/s
Infil Speed 60mm/s
Outer Wall Speed 30mm/s
Inner Wall Speed 60mm/s
Top/Bottomg Speed 30mm/s
Initial Layer Speed 30mm/s
Print cooling enables
Fan speed 100%
Support enabled / everywhere / 50 degrees
Build plate adhesion Type Skirt (This helps me to check the bed is level before it starts wasting material on the main body of the print.
Other things: I use a glass textured heated bed and have stronger springs in the height adjuster for the bed. Also an Aluminium extruder feed mechanism. And the printer is an Ender 3. Only other thing I plan to do with it is to install stepper vibration dampers. Not for noise reduction as some do but to help in reducing backlash etc.
And I need to get some glasses :)exxos wrote: 18 Apr 2019 17:00As far as I can see there is no difference... Though what could be throwing the view is that the 0.2mm holes are actually fractionally wider diameter...PhilC wrote: 18 Apr 2019 16:53 That's an interesting one. Next to no difference but, unexpectedly, the quality of the holes looks better on 0.2mm?
Users browsing this forum: CCBot and 68 guests
