I'd like to try to reproduce that. So, yes, if you'll send me the .zip file I'll test with a SD card on real hardware (instead of in Hatari). I might not be able to test on a real Atari until next weekend or the weekend after that, though.exxos wrote: Wed Aug 16, 2023 8:53 pm Maybe because I have thousands of files and folders also ?
I can probably PM you my files, it's about 62MB zipped if you want to dump that on a SD card and try. All I can say is it works in TOS, but EMUTOS doesn't.
The test case I made for this has uncovered an EmuTOS bug though, which I'm currently fixing. However, this bug would not have affected in which situation you get the error message. I could only - under certain circumstances - cause EmuTOS to crash after getting the error message about the folder depth.
