Also another weird thing is my NAS drive is not accessible outside of my network (IE over the net) unless I open all the ports above 50,000. It does not even use any ports anywhere near that range. It is not consistent either. I thought I narrowed it down to a range of about 3,000 ports, so I kept halving and doubling continuously until I got it down to a single address. But nope it could not be that simple. As then later I opened up the range and it started working again where as before it would not. I narrowed it down 3 or 4 times on the range of ports and what number failed at one point then worked later.
I'm not leaving thousands of ports open. So the NAS will just have to remain "broken" as I really cannot be bothered with all the stupid faults any more.
Also Dawn's washing machine has a draining problem again. I had it in bits a few weeks back because it seemed like something was blocking the pump. there was a tiny bit of fluff in it well basically nothing. But this washing machine has been a issue for a long time now. I can fill the drum up with water and it will empty very quickly. So I cannot see how it has a emptying problem.
Anyway,Samsung can come out and screw around with it because there are simply not enough hours in the day to deal with all this BS all the time.
I am starting to really despise everything computer or electronic related these days. Absolutely nothing works properly any more. All my time just goes into screwing around with things that I should simply not be screwing around with, or have to screw around with in the first place!!
