exxos blog - random goings on
Rustynutt wrote: Wed Jul 19, 2023 6:06 pm To unstall testy old exe's, use (what I think is a UK product) Revo Uninstaller.
It's a nice tool for pretty much all Window cleaning functions.
Yep thats a good tool and used it a lot :)
Rustynutt wrote: Wed Jul 19, 2023 6:06 pm I too have occasional screen issues flashing off and on at times, then it stops.
Win 7 ASUS 2.8GH Quadcore something or another with an MSI graphics card.
What's most prevalent now are green asterisk looking symbols popping up all over the "home" screen (don't want to say desktop :) ). But they don't appear in application windows :roll:
Some forums read where the graphics card memory is going bad.
Yeah its still questionable about the graphics card since I have problems in Linux and Windows.
Seems to be a common issue though :shrug:
https://www.wintips.org/fix-windows-10- ... er-update/
https://www.makeuseof.com/fix-windows-1 ... th-cursor/
I have been having shut down problems as well ironically :roll:
It gets stuck on the waiting for background services to close screen for ages, never used to do that. Gone through all the background services and turned off all that I dare. Mostly things like Opera and Adobe updater services etc.
But currently I think it is Samsung magician which is causing the shutdown problems. I have updated it to the current version and now I need to reboot another 50 times to see if it is stable :roll: so far so good.
Also found you can turn on more detailed start up and shut down information in windows. https://www.thewindowsclub.com/enable-v ... ge-windows
At the moment I do not appear to be getting the black screen on boot up with cursor problem. I did have it once about an hour ago and I just reset the PC and it doesn't come back...yet...
I have also worked through all the errors in the system log which took a long time. Mostly involved deleting drivers and stuff in the registry and all sorts of hacky tricks. Seems I had not completely removed paragon 14 :roll:
At one point I thought it was because the Linux drive was plugged in and that was somehow preventing windows from starting up. That seems to be one of a common problem along with graphics drivers.
When I have done some more backups I may leave it running on memory test for a while and make sure the system does not have some strange fault.
Decided to try memtest86 has it seems to have got bundled with Linux. Has opened a whole can of worms :(
Basically it rockets to 61% then locks up. I have swapped the memory around and try different slots and while the percentage does change, it is consistent to what is currently set up.
Oddly the + sign is still flashing, so part of the program is running.
I've tried or upping the voltages on various things and lowering the speed of the memory book as yet not found anything which works at all :(
So I don't know if the program is somehow buggy with my setup or there is genuinely some problem somewhere :(
How many sticks of RAM, can you drop down from 4x to 2x or from 2x to 1x sticks? Failing that you may need to buy new ram?
Not sure if memtest86 is supposed to lock up, surely it is supposed to report errors. I dunno.
Could be your PSU?
You do seem to be experiencing a range of problems spanning graphics, general stability and hard disk boot sector issues at various different times... Certainly sounds like it has to be something that can effect all of those things.
Rustynutt
Post by Rustynutt »
Think Steve may be in to something.
They are not Falcons, they don't last forever :)
You probably tried already booting in safemode?
Steve wrote: Wed Jul 19, 2023 9:25 pm How many sticks of RAM, can you drop down from 4x to 2x or from 2x to 1x sticks? Failing that you may need to buy new ram?
Could be your PSU?
I've got 2 sticks of DDR4 8GB each. I've tried one at a time in a different slot and no change.
I'm running a Linux ram test within Linux and it's passing so far. So I don't know if memtest86 is a red herring or not now :(
Normally with bad ram I would get the BSOD in windows. But possible something could just die like I have been seeing.
I even tried a older version of memtest86. It seemed to pass address test then die on sequential test.
I may try updating my bios as my settings are trashed now anyway.
Rustynutt wrote: Wed Jul 19, 2023 9:36 pm Think Steve may be in to something.
The motherboard is only like a year old. But generally once I'm in Windows I don't seem to have any problems.
Looks like I have version 5 of memtest86 and they past version 10 now. So I need to figure out how to update that next.
Edit
I've burned it onto USB stick than start messing with the grub stuff again. It's all gone very posh now. Tests seem to be running fine so far...
Memory tested fine.
Rebooted and back to black screen with mouse arrow . Tried several boots.. nope.. booted right into safe mode. Tried normally.. nope.. so disabled all but antivirus and Microsoft services and booted up.. could have been a fluke but it's something to go on.
Currently I tried updating Nvidia graphics drivers and now my control panel has vanished. Can't work out how to download it from anywhere. So rather than go down that rabbit hole , I'm going to restore my backup from this afternoon. Then I'll try disabling services again...
This is basically the screen I have been looking at all week. infamous BSOD ( black screen of death) With only the mouse cursor on screen.
Also this is a screen it got constantly stuck on during shutdown. well it is not necessarily a bad thing, it definitely was not "normal" to my particular setup in getting stuck there.
The odd thing is that if I did control alternate delete to bring up task manager, it would often then proceed to shut down normally as if something was becoming "un-stuck" during the switch.
After restoring the backup last night everything is working fine again :shrug: I have removed Samsung magician fully as that was suspect previously. I have also disabled the majority of services on start-up which I deemed not really necessary. Some seem to turn themselves back on but nothing much.
Interesting thing about my boot up this morning is my windows now says " preparing desktop" as opposed to just a regular welcome screen. it is at that point normally hangs for a while before going to the black screen. I noticed this morning that my NAS drive had powered down ( standby) and it was again stuck on the preparing desktop until I heard the NAS spin up and it then went to desktop as normal.
There was some updates for the NAS drive , so I have installed them as well in case that was causing some problems. Also uninstalled some drivers and software which were dating back to like 2012 era. Stuff like "AMD catalyst control centre" driving was to bring dating back to my very old ATI based cards.
I also stumbled across this program. Will attach the programs below in case they disappear at some point.
https://www.bleepingcomputer.com/downlo ... scan-tool/
FRST.zip
(3.33 MiB) Downloaded 58 times
It basically scans the error logs and lists them more conveniently. There was not really much in the way of errors other than several entries moaning that the search file indexes were corrupted. A couple other bizarro messages that I don't think are relevant to anything. There was A fairly long list moaning about some knowledgebase fixes which cannot update without extended Windows 7 support. So I basically ignoring them. They only seemed to be relating to Microsoft Edge anyway.
Shutting down my PC seems to be extremely quick again now. starting up also seems very quick. so basically the only things I have really changed on services which are running when Windows starts. but I don't really think there is anything much there anyway..
Samsung magician was in there obviously has been removed now. my best guess is it was that which was causing the problems.
The phenomtweaker I don't believe was enabled (or installed even) . I think some of those programs which are listed in start-up are not even installed any more. Have not yet had time to figure out how to remove invalid items from that list.
I think the only likely candidate was again that Samsung magician program and possibly the creative audio drivers. but I don't see why the drivers would load as I don't have the creative card in my PC anymore..
Incidentally this is the faulty Memtest V5. Which annoyingly led me down the rabbit hole :roll:
The new version is a lot more posh! and works!!!
Also the results of the tests in Linux.
Still don't really understand what changed with all this. Because my PC had been working perfectly for literally years ( aside from a year or two ago when my motherboard "died") . Again I did download Microsoft Office updates which could have been where the problems started from. I don't get why those would specifically cause problems with the system to start with.
I have also currently turned off a setting in antivirus, but I don't believe it was relating.. Because I disabled basically everything in the antivirus previously and it did not solve the start-up problems. But anyway, In was it always scans new files, but it does not allow access to them until they have been proven safe.. Now if the Internet connection is not working at that point it is entirely possible windows could lock up.But as turning of the antivirus did not seem to change anything then I don't believe it is relating currently.
Because there is a lot of unknowns going on, I am not changing anything for the time being.I don't think it is a driver problem or hardware problems because generally if I press reset when it got stuck I could often boot into Windows perfectly well afterwards. it would seemingly always boot perfectly well into safe mode as well. Also using " last known good configuration" also seemed to help a lot. but because the fall seems mostly intermittent it is difficult to tell what works and what doesn't. but if the last known good configuration worked, what changed to make it not work afterwards....
I have ran error checking on my C: drive, defragged and now currently making constant backups and verifying them to make sure there are no issues. At one point I thought it was acting up because the Linux drive was plugged in, though when I could not boot into windows, I unplugged the drive and left it out, but the problem still persisted anyway.
There is a load of other stuff I have been doing but not really noteworthy. just generally tidying up my windows install trying to eliminate possible points of failure. I hold my breath every time I turn on my PC now waiting for the black screen to return :roll:
