Thanks @Badwolf . indeed "walking the rectangle list" is done. The AES just seems to get confused somehow when 2 windows are open.
Its odd the AES even draws in my new window. It could be issuing redraw events before the window has actually moved. But not sure how that could really happen. It shouldn't be drawing on the on top window when the window being moved is behind the new window. It would make sense if the main window was on top, but it isn't.
I never used mint etc. But assume clicking a window and moving it, doesn't actually make it the selected on top window ? Currently making it the top window and doing a full redraw seems the only solution.
exxos blog - random goings on
Unless that's a basic issue, I can't imagine it's the AES getting confused. Multiple windows are a fairly common occurance!exxos wrote: 04 Jan 2023 14:41 Thanks @Badwolf . indeed "walking the rectangle list" is done. The AES just seems to get confused somehow when 2 windows are open.
That's down to the indivdual AES rather than MiNT per se, but normally clicking on a window tops it. Is that what's going wrong, you're missing the WM_TOPPED event and it's asking you to redraw the area that was previously occluded?Its odd the AES even draws in my new window. It could be issuing redraw events before the window has actually moved. But not sure how that could really happen. It shouldn't be drawing on the on top window when the window being moved is behind the new window. It would make sense if the main window was on top, but it isn't.
EDIT: actually I see that XaAES doesn't top on move.
I've just hacked my program to stop drawing the text and to open two windows instead:-
I think that's working as intended. I moved the second (lower, underlapped) window out without topping it and the dark grey area was redrawn only.
Source attached.
Source attached.
Thanks. It doesn't look like I do anything any different. Though your example would be doing the same as mine does. Only I use black squares to denote what areas the AES is sending.Badwolf wrote: 04 Jan 2023 15:40 I think that's working as intended. I moved the second (lower, underlapped) window out without topping it and the dark grey area was redrawn only.
I wonder if I'm missing some events somehow. Can't check now as not at home. But I'd assume , as you say, dragging the bottom window causes the exposed area to redraw. But aside from the redraw message , not sure what else would be needed ?
Multiple windows only work with one GB7 window open. Opening a directory on desktop and moving either windows about all works fine. Its not until I open 2 GB7 windows ( same program) that things get messed up. Both windows have their own handle and draw routines.
Maybe there is something FUBAR in the HISOFT libs somewhere. I'm fast running out of ideas now. I know the WINDOWS READ in basic screws up if you call it over 1,000 times or something. So there are bugs somewhere.
I think the only key thing there is that msg_buf[3] indicating the window handle during the WM_REDRAW event. I presume you're then deciding which draw routine to call based on a look-up against that ID?exxos wrote: 04 Jan 2023 16:11 Multiple windows only work with one GB7 window open. Opening a directory on desktop and moving either windows about all works fine. Its not until I open 2 GB7 windows ( same program) that things get messed up. Both windows have their own handle and draw routines.
Is that code robust (no off-by-one error or similar)?
Could very well be.Maybe there is something FUBAR in the HISOFT libs somewhere. I'm fast running out of ideas now. I know the WINDOWS READ in basic screws up if you call it over 1,000 times or something. So there are bugs somewhere.
Badwolf wrote: 04 Jan 2023 16:38 I think the only key thing there is that msg_buf[3] indicating the window handle during the WM_REDRAW event. I presume you're then deciding which draw routine to call based on a look-up against that ID?
'GB7 MAIN WINDOW
if mess(3)=our_aeshandle then
if mess(0)= WM_MOVED THEN vs_color 0,1000,0,0 : UDSCREEN2 mess(4),mess(5),mess(6),mess(7),0: EXIT IF 'red
if mess(0)=wm_redraw AND e<>1 then CALL UDS: vs_color 0,0,1000,0 : redraw mess(4),mess(5),mess(6),mess(7): EXIT IF ' green FROM AESDEMO
if mess(0)=WM_NEWTOP AND e<>1 then CALL UDS:vs_color 0,0,0,1000 : call full_redraw ' blue window clicked on
end if
'INFO WINDOW MOVED
if mess(3)=our_aeshandle2 then
WINDOW LOCATE INFOID,mess(4),mess(5),mess(6),mess(7)
junk=wind_get(our_aeshandle2,WF_WORKXYWH,x,y,w,h) ' get work area of the main window (internal)
junk=wind_update(1)
base_redraw x,y,w,h
junk=wind_update(0)
end if
END IFIn this post viewtopic.php?p=96297#p96297 I only get the move window event and one redraw event.
The red parts what is returned by the intersection routine. And the black parts is what is returned in the REDRAW events.
I don't know why the main GB7 window gets drawn on the top window yet either.
How it is currently it works. The when clicking the GB7 main window which is under the new window, when it is clicked on it automatically brings it to the front. This must be something HISOFT is doing because I do not process any other messages other than REDRAW and MOVE currently.
Currently I am not really sure how you are supposed to move a window with AES functions @Badwolf ?
Found it in your code
And I don't bloody believe it but it seems to be behaving now :roll: Need to do more testing though.
case WM_MOVED:
wind_set( msg_buf[3], WF_CURRXYWH, msg_buf[4],
msg_buf[5], msg_buf[6], msg_buf[7] );-
The test video..
So it seems the HISOFT WINDOW LOCATE function is totally broken then :roll: Even the odd redraw issues in the new top window have even vanished now. :shock:
So no bloody wonder it has taken me so long to track down this problem. Because the problem isn't actually with my code it is built into the HISOFT libraries which I was essentially debugging :pullhair:
This is also why I stopped writing software in Windows, because I was spending more time debugging the dll's in Windows than debugging my own code :lol: :roll:
Been doing a lot of tests. On occasion a desktop window doesn't seem to get refreshed. But not sure the cause of that.
Also the redraw events trigger twice which is odd. Its the same events as well. So maybe I need to clear the event variables after doing a event. I kind of assumed event multi would basically do that the next time its called anyway :shrug:
The first problem may be because I still have WINDOW LOCATE for the second window.
The second problem might be because I need a second "exit if" in the moved event line. But could be other issues as well.
HigashiJun
Yup, a good film indeed.
I guess a lot of kids cried when Artax the horse died in the swamps... :cry:
(Even if it came back to life at the end).
Users browsing this forum: Baidu [Spider], CCBot and 12 guests
