exxos blog - random goings on
dml
Post by dml »
Here's an update that will print the exact address of the first fault in each solid block:
https://www.dropbox.com/s/rcvovjouc8hzp ... 4.zip?dl=1
It also asks for an individual keypress before printing each kind of result and the graphic map so stuff doesn't scroll away too easily.
So if I got this right.. The start and end address fail and although the ones in between pass...
1100000000101011000110 - FAIL
1100000000101011001000
1100000000101011001010
1100000000101011001100
1100000000101011001110
1100000000101011010000
1100000000101011010010
1100000000101011010100
1100000000101011010110
1100000000101011011000
1100000000101011011010
1100000000101011011100
1100000000101011011110
1100000000101011100000
1100000000101011100010
1100000000101011100100
1100000000101011100110
1100000000101011101000
1100000000101011101010
1100000000101011101100
1100000000101011101110
1100000000101011110000
1100000000101011110010
1100000000101011110100
1100000000101011110110
1100000000101011111000
1100000000101011111010
1100000000101011111100
1100000000101011111110
1100000000101100000000
1100000000101100000010
1100000000101100000100
1100000000101100000110
1100000000101100001000
1100000000101100001010
1100000000101100001100
1100000000101100001110
1100000000101100010000
1100000000101100010010
1100000000101100010100
1100000000101100010110
1100000000101100011000
1100000000101100011010
1100000000101100011100
1100000000101100011110
1100000000101100100000
1100000000101100100010
1100000000101100100100
1100000000101100100110
1100000000101100101000
1100000000101100101010
1100000000101100101100
1100000000101100101110
1100000000101100110000
1100000000101100110010
1100000000101100110100
1100000000101100110110
1100000000101100111000
1100000000101100111010
1100000000101100111100
1100000000101100111110
1100000000101101000000
1100000000101101000010
1100000000101101000100
1100000000101101000110
1100000000101101001000
1100000000101101001010
1100000000101101001100
1100000000101101001110
1100000000101101010000
1100000000101101010010
1100000000101101010100
1100000000101101010110
1100000000101101011000
1100000000101101011010
1100000000101101011100
1100000000101101011110
1100000000101101100000
1100000000101101100010
1100000000101101100100
1100000000101101100110
1100000000101101101000
1100000000101101101010
1100000000101101101100
1100000000101101101110
1100000000101101110000
1100000000101101110010
1100000000101101110100
1100000000101101110110
1100000000101101111000
1100000000101101111010
1100000000101101111100
1100000000101101111110
1100000000101110000000
1100000000101110000010
1100000000101110000100
1100000000101110000110
1100000000101110001000
1100000000101110001010
1100000000101110001100
1100000000101110001110
1100000000101110010000
1100000000101110010010
1100000000101110010100
1100000000101110010110
1100000000101110011000
1100000000101110011010
1100000000101110011100
1100000000101110011110
1100000000101110100000
1100000000101110100010
1100000000101110100100
1100000000101110100110
1100000000101110101000
1100000000101110101010
1100000000101110101100
1100000000101110101110
1100000000101110110000
1100000000101110110010
1100000000101110110100
1100000000101110110110
1100000000101110111000
1100000000101110111010
1100000000101110111100
1100000000101110111110
1100000000101111000000
1100000000101111000010
1100000000101111000100
1100000000101111000110
1100000000101111001000
1100000000101111001010
1100000000101111001100
1100000000101111001110
1100000000101111010000
1100000000101111010010
1100000000101111010100
1100000000101111010110
1100000000101111011000
1100000000101111011010
1100000000101111011100
1100000000101111011110
1100000000101111100000
1100000000101111100010
1100000000101111100100
1100000000101111100110
1100000000101111101000
1100000000101111101010
1100000000101111101100
1100000000101111101110
1100000000101111110000
1100000000101111110010
1100000000101111110100
1100000000101111110110
1100000000101111111000
1100000000101111111010
1100000000101111111100
1100000000101111111110
1100000000110000000000
1100000000110000000010
1100000000110000000100
1100000000110000000110
1100000000110000001000
1100000000110000001010
1100000000110000001100
1100000000110000001110
1100000000110000010000
1100000000110000010010
1100000000110000010100
1100000000110000010110
1100000000110000011000
1100000000110000011010
1100000000110000011100
1100000000110000011110
1100000000110000100000
1100000000110000100010
1100000000110000100100
1100000000110000100110
1100000000110000101000
1100000000110000101010
1100000000110000101100
1100000000110000101110
1100000000110000110000
1100000000110000110010
1100000000110000110100
1100000000110000110110
1100000000110000111000
1100000000110000111010
1100000000110000111100
1100000000110000111110
1100000000110001000000
1100000000110001000010
1100000000110001000100
1100000000110001000110
1100000000110001001000
1100000000110001001010
1100000000110001001100
1100000000110001001110
1100000000110001010000
1100000000110001010010
1100000000110001010100
1100000000110001010110
1100000000110001011000
1100000000110001011010
1100000000110001011100
1100000000110001011110
1100000000110001100000
1100000000110001100010
1100000000110001100100
1100000000110001100110
1100000000110001101000
1100000000110001101010
1100000000110001101100
1100000000110001101110
1100000000110001110000
1100000000110001110010
1100000000110001110100
1100000000110001110110
1100000000110001111000
1100000000110001111010
1100000000110001111100
1100000000110001111110
1100000000110010000000
1100000000110010000010
1100000000110010000100
1100000000110010000110
1100000000110010001000
1100000000110010001010
1100000000110010001100
1100000000110010001110
1100000000110010010000
1100000000110010010010
1100000000110010010100
1100000000110010010110
1100000000110010011000
1100000000110010011010
1100000000110010011100
1100000000110010011110
1100000000110010100000
1100000000110010100010
1100000000110010100100
1100000000110010100110
1100000000110010101000
1100000000110010101010
1100000000110010101100
1100000000110010101110
1100000000110010110000
1100000000110010110010
1100000000110010110100
1100000000110010110110
1100000000110010111000
1100000000110010111010
1100000000110010111100
1100000000110010111110
1100000000110011000000
1100000000110011000010
1100000000110011000100
1100000000110011000110
1100000000110011001000
1100000000110011001010
1100000000110011001100
1100000000110011001110
1100000000110011010000
1100000000110011010010
1100000000110011010100
1100000000110011010110
1100000000110011011000
1100000000110011011010
1100000000110011011100
1100000000110011011110
1100000000110011100000
1100000000110011100010
1100000000110011100100
1100000000110011100110
1100000000110011101000
1100000000110011101010
1100000000110011101100
1100000000110011101110
1100000000110011110000
1100000000110011110010
1100000000110011110100
1100000000110011110110
1100000000110011111000
1100000000110011111010
1100000000110011111100
1100000000110011111110
1100000000110100000000
1100000000110100000010
1100000000110100000100
1100000000110100000110
1100000000110100001000
1100000000110100001010
1100000000110100001100
1100000000110100001110
1100000000110100010000
1100000000110100010010
1100000000110100010100
1100000000110100010110
1100000000110100011000
1100000000110100011010
1100000000110100011100
1100000000110100011110
1100000000110100100000
1100000000110100100010
1100000000110100100100
1100000000110100100110
1100000000110100101000
1100000000110100101010
1100000000110100101100
1100000000110100101110
1100000000110100110000
1100000000110100110010
1100000000110100110100
1100000000110100110110
1100000000110100111000
1100000000110100111010
1100000000110100111100
1100000000110100111110
1100000000110101000000
1100000000110101000010
1100000000110101000100
1100000000110101000110
1100000000110101001000
1100000000110101001010
1100000000110101001100
1100000000110101001110
1100000000110101010000
1100000000110101010010
1100000000110101010100
1100000000110101010110
1100000000110101011000
1100000000110101011010
1100000000110101011100
1100000000110101011110
1100000000110101100000
1100000000110101100010
1100000000110101100100
1100000000110101100110
1100000000110101101000
1100000000110101101010
1100000000110101101100
1100000000110101101110
1100000000110101110000
1100000000110101110010
1100000000110101110100
1100000000110101110110
1100000000110101111000
1100000000110101111010
1100000000110101111100
1100000000110101111110
1100000000110110000000
1100000000110110000010
1100000000110110000100
1100000000110110000110
1100000000110110001000
1100000000110110001010
1100000000110110001100
1100000000110110001110
1100000000110110010000
1100000000110110010010
1100000000110110010100
1100000000110110010110
1100000000110110011000
1100000000110110011010
1100000000110110011100
1100000000110110011110
1100000000110110100000
1100000000110110100010
1100000000110110100100
1100000000110110100110
1100000000110110101000
1100000000110110101010
1100000000110110101100
1100000000110110101110
1100000000110110110000
1100000000110110110010
1100000000110110110100
1100000000110110110110
1100000000110110111000
1100000000110110111010
1100000000110110111100
1100000000110110111110
1100000000110111000000
1100000000110111000010
1100000000110111000100
1100000000110111000110
1100000000110111001000
1100000000110111001010
1100000000110111001100
1100000000110111001110
1100000000110111010000
1100000000110111010010
1100000000110111010100
1100000000110111010110
1100000000110111011000
1100000000110111011010
1100000000110111011100
1100000000110111011110
1100000000110111100000
1100000000110111100010
1100000000110111100100
1100000000110111100110
1100000000110111101000
1100000000110111101010
1100000000110111101100
1100000000110111101110
1100000000110111110000
1100000000110111110010
1100000000110111110100
1100000000110111110110
1100000000110111111000
1100000000110111111010
1100000000110111111100
1100000000110111111110
1100000000111000000000
1100000000111000000010
1100000000111000000100
1100000000111000000110
1100000000111000001000
1100000000111000001010
1100000000111000001100
1100000000111000001110
1100000000111000010000
1100000000111000010010
1100000000111000010100
1100000000111000010110
1100000000111000011000
1100000000111000011010
1100000000111000011100
1100000000111000011110
1100000000111000100000
1100000000111000100010
1100000000111000100100
1100000000111000100110
1100000000111000101000
1100000000111000101010
1100000000111000101100
1100000000111000101110
1100000000111000110000
1100000000111000110010
1100000000111000110100
1100000000111000110110
1100000000111000111000
1100000000111000111010
1100000000111000111100
1100000000111000111110
1100000000111001000000
1100000000111001000010
1100000000111001000100
1100000000111001000110
1100000000111001001000
1100000000111001001010
1100000000111001001100
1100000000111001001110
1100000000111001010000
1100000000111001010010
1100000000111001010100
1100000000111001010110
1100000000111001011000
1100000000111001011010
1100000000111001011100
1100000000111001011110
1100000000111001100000
1100000000111001100010
1100000000111001100100
1100000000111001100110
1100000000111001101000
1100000000111001101010
1100000000111001101100
1100000000111001101110
1100000000111001110000
1100000000111001110010
1100000000111001110100
1100000000111001110110
1100000000111001111000
1100000000111001111010
1100000000111001111100
1100000000111001111110
1100000000111010000000
1100000000111010000010
1100000000111010000100
1100000000111010000110
1100000000111010001000
1100000000111010001010
1100000000111010001100
1100000000111010001110
1100000000111010010000
1100000000111010010010
1100000000111010010100
1100000000111010010110
1100000000111010011000
1100000000111010011010
1100000000111010011100
1100000000111010011110
1100000000111010100000
1100000000111010100010
1100000000111010100100
1100000000111010100110
1100000000111010101000
1100000000111010101010
1100000000111010101100
1100000000111010101110
1100000000111010110000
1100000000111010110010
1100000000111010110100
1100000000111010110110
1100000000111010111000
1100000000111010111010
1100000000111010111100
1100000000111010111110
1100000000111011000000
1100000000111011000010
1100000000111011000100
1100000000111011000110
1100000000111011001000
1100000000111011001010
1100000000111011001100
1100000000111011001110
1100000000111011010000
1100000000111011010010
1100000000111011010100
1100000000111011010110
1100000000111011011000
1100000000111011011010
1100000000111011011100
1100000000111011011110
1100000000111011100000
1100000000111011100010
1100000000111011100100
1100000000111011100110
1100000000111011101000
1100000000111011101010
1100000000111011101100
1100000000111011101110
1100000000111011110000
1100000000111011110010
1100000000111011110100
1100000000111011110110
1100000000111011111000
1100000000111011111010
1100000000111011111100
1100000000111011111110
1100000000111100000000
1100000000111100000010
1100000000111100000100
1100000000111100000110
1100000000111100001000
1100000000111100001010
1100000000111100001100
1100000000111100001110
1100000000111100010000
1100000000111100010010
1100000000111100010100
1100000000111100010110
1100000000111100011000
1100000000111100011010
1100000000111100011100
1100000000111100011110
1100000000111100100000
1100000000111100100010
1100000000111100100100
1100000000111100100110
1100000000111100101000
1100000000111100101010
1100000000111100101100
1100000000111100101110
1100000000111100110000
1100000000111100110010
1100000000111100110100
1100000000111100110110
1100000000111100111000
1100000000111100111010
1100000000111100111100
1100000000111100111110
1100000000111101000000
1100000000111101000010
1100000000111101000100
1100000000111101000110
1100000000111101001000
1100000000111101001010
1100000000111101001100
1100000000111101001110
1100000000111101010000
1100000000111101010010
1100000000111101010100
1100000000111101010110
1100000000111101011000
1100000000111101011010
1100000000111101011100
1100000000111101011110
1100000000111101100000
1100000000111101100010
1100000000111101100100
1100000000111101100110
1100000000111101101000
1100000000111101101010
1100000000111101101100
1100000000111101101110
1100000000111101110000
1100000000111101110010
1100000000111101110100
1100000000111101110110
1100000000111101111000
1100000000111101111010
1100000000111101111100
1100000000111101111110
1100000000111110000000
1100000000111110000010
1100000000111110000100
1100000000111110000110
1100000000111110001000
1100000000111110001010
1100000000111110001100
1100000000111110001110
1100000000111110010000
1100000000111110010010
1100000000111110010100
1100000000111110010110
1100000000111110011000
1100000000111110011010
1100000000111110011100
1100000000111110011110
1100000000111110100000
1100000000111110100010
1100000000111110100100
1100000000111110100110
1100000000111110101000
1100000000111110101010
1100000000111110101100
1100000000111110101110
1100000000111110110000
1100000000111110110010
1100000000111110110100
1100000000111110110110
1100000000111110111000
1100000000111110111010
1100000000111110111100
1100000000111110111110
1100000000111111000000
1100000000111111000010
1100000000111111000100
1100000000111111000110
1100000000111111001000
1100000000111111001010
1100000000111111001100
1100000000111111001110
1100000000111111010000
1100000000111111010010
1100000000111111010100
1100000000111111010110
1100000000111111011000
1100000000111111011010
1100000000111111011100
1100000000111111011110
1100000000111111100000
1100000000111111100010
1100000000111111100100
1100000000111111100110
1100000000111111101000
1100000000111111101010
1100000000111111101100
1100000000111111101110
1100000000111111110000
1100000000111111110010
1100000000111111110100
1100000000111111110110
1100000000111111111000
1100000000111111111010
1100000000111111111100
1100000000111111111110
1100000001000000000000
1100000001000000000010
1100000001000000000100
1100000001000000000110
1100000001000000001000
1100000001000000001010
1100000001000000001100
1100000001000000001110
1100000001000000010000
1100000001000000010010
1100000001000000010100
1100000001000000010110
1100000001000000011000
1100000001000000011010
1100000001000000011100
1100000001000000011110
1100000001000000100000
1100000001000000100010
1100000001000000100100
1100000001000000100110
1100000001000000101000
1100000001000000101010
1100000001000000101100
1100000001000000101110
1100000001000000110000
1100000001000000110010
1100000001000000110100
1100000001000000110110
1100000001000000111000
1100000001000000111010
1100000001000000111100
1100000001000000111110
1100000001000001000000
1100000001000001000010
1100000001000001000100
1100000001000001000110
1100000001000001001000
1100000001000001001010
1100000001000001001100
1100000001000001001110
1100000001000001010000
1100000001000001010010
1100000001000001010100
1100000001000001010110
1100000001000001011000
1100000001000001011010
1100000001000001011100
1100000001000001011110
1100000001000001100000
1100000001000001100010
1100000001000001100100
1100000001000001100110
1100000001000001101000
1100000001000001101010
1100000001000001101100
1100000001000001101110
1100000001000001110000
1100000001000001110010
1100000001000001110100
1100000001000001110110
1100000001000001111000
1100000001000001111010
1100000001000001111100
1100000001000001111110
1100000001000010000000
1100000001000010000010
1100000001000010000100
1100000001000010000110
1100000001000010001000
1100000001000010001010
1100000001000010001100
1100000001000010001110
1100000001000010010000
1100000001000010010010
1100000001000010010100
1100000001000010010110
1100000001000010011000
1100000001000010011010
1100000001000010011100
1100000001000010011110
1100000001000010100000
1100000001000010100010
1100000001000010100100
1100000001000010100110
1100000001000010101000
1100000001000010101010
1100000001000010101100
1100000001000010101110
1100000001000010110000
1100000001000010110010
1100000001000010110100
1100000001000010110110
1100000001000010111000
1100000001000010111010
1100000001000010111100
1100000001000010111110
1100000001000011000000
1100000001000011000010
1100000001000011000100
1100000001000011000110
1100000001000011001000
1100000001000011001010
1100000001000011001100
1100000001000011001110
1100000001000011010000
1100000001000011010010
1100000001000011010100
1100000001000011010110
1100000001000011011000
1100000001000011011010
1100000001000011011100
1100000001000011011110
1100000001000011100000
1100000001000011100010
1100000001000011100100
1100000001000011100110
1100000001000011101000
1100000001000011101010
1100000001000011101100
1100000001000011101110
1100000001000011110000
1100000001000011110010
1100000001000011110100
1100000001000011110110
1100000001000011111000
1100000001000011111010
1100000001000011111100
1100000001000011111110
1100000001000100000000
1100000001000100000010
1100000001000100000100
1100000001000100000110
1100000001000100001000
1100000001000100001010
1100000001000100001100
1100000001000100001110
1100000001000100010000
1100000001000100010010
1100000001000100010100
1100000001000100010110
1100000001000100011000
1100000001000100011010
1100000001000100011100
1100000001000100011110
1100000001000100100000
1100000001000100100010
1100000001000100100100
1100000001000100100110
1100000001000100101000
1100000001000100101010
1100000001000100101100
1100000001000100101110
1100000001000100110000
1100000001000100110010
1100000001000100110100
1100000001000100110110
1100000001000100111000
1100000001000100111010
1100000001000100111100
1100000001000100111110
1100000001000101000000
1100000001000101000010
1100000001000101000100
1100000001000101000110
1100000001000101001000
1100000001000101001010
1100000001000101001100
1100000001000101001110
1100000001000101010000
1100000001000101010010
1100000001000101010100
1100000001000101010110
1100000001000101011000
1100000001000101011010
1100000001000101011100
1100000001000101011110
1100000001000101100000
1100000001000101100010
1100000001000101100100
1100000001000101100110
1100000001000101101000
1100000001000101101010
1100000001000101101100
1100000001000101101110
1100000001000101110000
1100000001000101110010
1100000001000101110100
1100000001000101110110
1100000001000101111000
1100000001000101111010
1100000001000101111100
1100000001000101111110
1100000001000110000000
1100000001000110000010
1100000001000110000100
1100000001000110000110
1100000001000110001000
1100000001000110001010
1100000001000110001100
1100000001000110001110
1100000001000110010000
1100000001000110010010
1100000001000110010100
1100000001000110010110
1100000001000110011000
1100000001000110011010
1100000001000110011100
1100000001000110011110
1100000001000110100000
1100000001000110100010
1100000001000110100100
1100000001000110100110
1100000001000110101000
1100000001000110101010
1100000001000110101100
1100000001000110101110
1100000001000110110000
1100000001000110110010
1100000001000110110100
1100000001000110110110
1100000001000110111000
1100000001000110111010
1100000001000110111100
1100000001000110111110
1100000001000111000000
1100000001000111000010
1100000001000111000100
1100000001000111000110
1100000001000111001000
1100000001000111001010
1100000001000111001100
1100000001000111001110
1100000001000111010000
1100000001000111010010
1100000001000111010100
1100000001000111010110
1100000001000111011000
1100000001000111011010
1100000001000111011100
1100000001000111011110
1100000001000111100000
1100000001000111100010
1100000001000111100100
1100000001000111100110
1100000001000111101000
1100000001000111101010
1100000001000111101100
1100000001000111101110
1100000001000111110000
1100000001000111110010
1100000001000111110100
1100000001000111110110
1100000001000111111000
1100000001000111111010
1100000001000111111100
1100000001000111111110
1100000001001000000000
1100000001001000000010
1100000001001000000100
1100000001001000000110
1100000001001000001000
1100000001001000001010
1100000001001000001100
1100000001001000001110
1100000001001000010000
1100000001001000010010
1100000001001000010100
1100000001001000010110
1100000001001000011000
1100000001001000011010
1100000001001000011100
1100000001001000011110
1100000001001000100000
1100000001001000100010
1100000001001000100100
1100000001001000100110
1100000001001000101000
1100000001001000101010
1100000001001000101100
1100000001001000101110
1100000001001000110000
1100000001001000110010
1100000001001000110100
1100000001001000110110
1100000001001000111000
1100000001001000111010
1100000001001000111100
1100000001001000111110
1100000001001001000000
1100000001001001000010
1100000001001001000100
1100000001001001000110
1100000001001001001000
1100000001001001001010
1100000001001001001100
1100000001001001001110
1100000001001001010000
1100000001001001010010
1100000001001001010100
1100000001001001010110
1100000001001001011000
1100000001001001011010
1100000001001001011100
1100000001001001011110
1100000001001001100000
1100000001001001100010
1100000001001001100100
1100000001001001100110
1100000001001001101000
1100000001001001101010
1100000001001001101100
1100000001001001101110
1100000001001001110000
1100000001001001110010
1100000001001001110100
1100000001001001110110
1100000001001001111000
1100000001001001111010
1100000001001001111100
1100000001001001111110
1100000001001010000000
1100000001001010000010
1100000001001010000100
1100000001001010000110
1100000001001010001000
1100000001001010001010
1100000001001010001100
1100000001001010001110
1100000001001010010000
1100000001001010010010
1100000001001010010100
1100000001001010010110
1100000001001010011000
1100000001001010011010
1100000001001010011100
1100000001001010011110
1100000001001010100000
1100000001001010100010
1100000001001010100100
1100000001001010100110
1100000001001010101000
1100000001001010101010
1100000001001010101100
1100000001001010101110
1100000001001010110000
1100000001001010110010
1100000001001010110100
1100000001001010110110
1100000001001010111000
1100000001001010111010
1100000001001010111100
1100000001001010111110
1100000001001011000000
1100000001001011000010
1100000001001011000100
1100000001001011000110
1100000001001011001000
1100000001001011001010
1100000001001011001100
1100000001001011001110
1100000001001011010000
1100000001001011010010
1100000001001011010100
1100000001001011010110
1100000001001011011000
1100000001001011011010
1100000001001011011100
1100000001001011011110
1100000001001011100000
1100000001001011100010
1100000001001011100100
1100000001001011100110
1100000001001011101000
1100000001001011101010
1100000001001011101100
1100000001001011101110
1100000001001011110000
1100000001001011110010
1100000001001011110100
1100000001001011110110
1100000001001011111000
1100000001001011111010
1100000001001011111100
1100000001001011111110
1100000001001100000000
1100000001001100000010
1100000001001100000100
1100000001001100000110
1100000001001100001000
1100000001001100001010
1100000001001100001100
1100000001001100001110
1100000001001100010000
1100000001001100010010
1100000001001100010100
1100000001001100010110
1100000001001100011000
1100000001001100011010
1100000001001100011100
1100000001001100011110
1100000001001100100000
1100000001001100100010
1100000001001100100100
1100000001001100100110
1100000001001100101000
1100000001001100101010
1100000001001100101100
1100000001001100101110
1100000001001100110000
1100000001001100110010
1100000001001100110100
1100000001001100110110
1100000001001100111000
1100000001001100111010
1100000001001100111100
1100000001001100111110
1100000001001101000000
1100000001001101000010
1100000001001101000100
1100000001001101000110
1100000001001101001000
1100000001001101001010
1100000001001101001100
1100000001001101001110
1100000001001101010000
1100000001001101010010
1100000001001101010100
1100000001001101010110
1100000001001101011000
1100000001001101011010
1100000001001101011100
1100000001001101011110
1100000001001101100000
1100000001001101100010
1100000001001101100100
1100000001001101100110
1100000001001101101000
1100000001001101101010
1100000001001101101100
1100000001001101101110
1100000001001101110000
1100000001001101110010
1100000001001101110100
1100000001001101110110
1100000001001101111000
1100000001001101111010
1100000001001101111100
1100000001001101111110
1100000001001110000000
1100000001001110000010
1100000001001110000100
1100000001001110000110
1100000001001110001000
1100000001001110001010
1100000001001110001100
1100000001001110001110
1100000001001110010000
1100000001001110010010
1100000001001110010100
1100000001001110010110
1100000001001110011000
1100000001001110011010
1100000001001110011100
1100000001001110011110
1100000001001110100000
1100000001001110100010
1100000001001110100100
1100000001001110100110
1100000001001110101000
1100000001001110101010
1100000001001110101100
1100000001001110101110
1100000001001110110000
1100000001001110110010
1100000001001110110100
1100000001001110110110
1100000001001110111000
1100000001001110111010
1100000001001110111100
1100000001001110111110
1100000001001111000000
1100000001001111000010
1100000001001111000100
1100000001001111000110
1100000001001111001000
1100000001001111001010
1100000001001111001100
1100000001001111001110
1100000001001111010000
1100000001001111010010
1100000001001111010100
1100000001001111010110
1100000001001111011000
1100000001001111011010
1100000001001111011100
1100000001001111011110
1100000001001111100000
1100000001001111100010
1100000001001111100100
1100000001001111100110
1100000001001111101000
1100000001001111101010
1100000001001111101100
1100000001001111101110
1100000001001111110000
1100000001001111110010
1100000001001111110100
1100000001001111110110
1100000001001111111000
1100000001001111111010
1100000001001111111100
1100000001001111111110
1100000001010000000000
1100000001010000000010
1100000001010000000100
1100000001010000000110
1100000001010000001000
1100000001010000001010
1100000001010000001100
1100000001010000001110
1100000001010000010000
1100000001010000010010
1100000001010000010100
1100000001010000010110
1100000001010000011000
1100000001010000011010
1100000001010000011100
1100000001010000011110
1100000001010000100000
1100000001010000100010
1100000001010000100100
1100000001010000100110
1100000001010000101000
1100000001010000101010
1100000001010000101100
1100000001010000101110
1100000001010000110000
1100000001010000110010
1100000001010000110100
1100000001010000110110
1100000001010000111000
1100000001010000111010
1100000001010000111100
1100000001010000111110
1100000001010001000000
1100000001010001000010
1100000001010001000100
1100000001010001000110
1100000001010001001000
1100000001010001001010
1100000001010001001100
1100000001010001001110
1100000001010001010000
1100000001010001010010
1100000001010001010100
1100000001010001010110
1100000001010001011000
1100000001010001011010
1100000001010001011100
1100000001010001011110
1100000001010001100000
1100000001010001100010
1100000001010001100100
1100000001010001100110
1100000001010001101000
1100000001010001101010
1100000001010001101100
1100000001010001101110
1100000001010001110000
1100000001010001110010
1100000001010001110100
1100000001010001110110
1100000001010001111000
1100000001010001111010
1100000001010001111100
1100000001010001111110
1100000001010010000000
1100000001010010000010
1100000001010010000100
1100000001010010000110
1100000001010010001000
1100000001010010001010
1100000001010010001100
1100000001010010001110
1100000001010010010000
1100000001010010010010
1100000001010010010100
1100000001010010010110
1100000001010010011000
1100000001010010011010
1100000001010010011100
1100000001010010011110
1100000001010010100000
1100000001010010100010
1100000001010010100100
1100000001010010100110
1100000001010010101000
1100000001010010101010
1100000001010010101100
1100000001010010101110
1100000001010010110000
1100000001010010110010
1100000001010010110100
1100000001010010110110
1100000001010010111000
1100000001010010111010
1100000001010010111100
1100000001010010111110
1100000001010011000000
1100000001010011000010
1100000001010011000100
1100000001010011000110
1100000001010011001000
1100000001010011001010
1100000001010011001100
1100000001010011001110
1100000001010011010000
1100000001010011010010
1100000001010011010100
1100000001010011010110
1100000001010011011000
1100000001010011011010
1100000001010011011100
1100000001010011011110
1100000001010011100000
1100000001010011100010
1100000001010011100100
1100000001010011100110
1100000001010011101000
1100000001010011101010
1100000001010011101100
1100000001010011101110
1100000001010011110000
1100000001010011110010
1100000001010011110100
1100000001010011110110
1100000001010011111000
1100000001010011111010
1100000001010011111100
1100000001010011111110
1100000001010100000000
1100000001010100000010
1100000001010100000100
1100000001010100000110
1100000001010100001000
1100000001010100001010
1100000001010100001100
1100000001010100001110
1100000001010100010000
1100000001010100010010
1100000001010100010100
1100000001010100010110
1100000001010100011000
1100000001010100011010
1100000001010100011100
1100000001010100011110
1100000001010100100000
1100000001010100100010
1100000001010100100100
1100000001010100100110
1100000001010100101000
1100000001010100101010
1100000001010100101100
1100000001010100101110
1100000001010100110000
1100000001010100110010
1100000001010100110100
1100000001010100110110
1100000001010100111000
1100000001010100111010
1100000001010100111100
1100000001010100111110
1100000001010101000000
1100000001010101000010
1100000001010101000100
1100000001010101000110
1100000001010101001000
1100000001010101001010
1100000001010101001100
1100000001010101001110
1100000001010101010000
1100000001010101010010
1100000001010101010100
1100000001010101010110
1100000001010101011000
1100000001010101011010
1100000001010101011100
1100000001010101011110
1100000001010101100000
1100000001010101100010
1100000001010101100100
1100000001010101100110
1100000001010101101000
1100000001010101101010
1100000001010101101100
1100000001010101101110
1100000001010101110000
1100000001010101110010
1100000001010101110100
1100000001010101110110
1100000001010101111000
1100000001010101111010
1100000001010101111100
1100000001010101111110
1100000001010110000000
1100000001010110000010
1100000001010110000100
1100000001010110000110
1100000001010110001000
1100000001010110001010
1100000001010110001100
1100000001010110001110
1100000001010110010000
1100000001010110010010
1100000001010110010100
1100000001010110010110
1100000001010110011000
1100000001010110011010
1100000001010110011100
1100000001010110011110
1100000001010110100000
1100000001010110100010
1100000001010110100100
1100000001010110100110
1100000001010110101000
1100000001010110101010
1100000001010110101100
1100000001010110101110
1100000001010110110000
1100000001010110110010
1100000001010110110100
1100000001010110110110
1100000001010110111000
1100000001010110111010
1100000001010110111100
1100000001010110111110
1100000001010111000000
1100000001010111000010
1100000001010111000100
1100000001010111000110
1100000001010111001000
1100000001010111001010
1100000001010111001100
1100000001010111001110
1100000001010111010000
1100000001010111010010
1100000001010111010100
1100000001010111010110
1100000001010111011000
1100000001010111011010
1100000001010111011100
1100000001010111011110
1100000001010111100000
1100000001010111100010
1100000001010111100100
1100000001010111100110
1100000001010111101000
1100000001010111101010
1100000001010111101100
1100000001010111101110
1100000001010111110000
1100000001010111110010
1100000001010111110100
1100000001010111110110
1100000001010111111000
1100000001010111111010
1100000001010111111100
1100000001010111111110
1100000001011000000000
1100000001011000000010
1100000001011000000100
1100000001011000000110
1100000001011000001000
1100000001011000001010
1100000001011000001100
1100000001011000001110
1100000001011000010000
1100000001011000010010
1100000001011000010100
1100000001011000010110
1100000001011000011000
1100000001011000011010
1100000001011000011100
1100000001011000011110
1100000001011000100000
1100000001011000100010
1100000001011000100100
1100000001011000100110
1100000001011000101000
1100000001011000101010
1100000001011000101100
1100000001011000101110
1100000001011000110000
1100000001011000110010
1100000001011000110100
1100000001011000110110
1100000001011000111000
1100000001011000111010
1100000001011000111100
1100000001011000111110
1100000001011001000000
1100000001011001000010
1100000001011001000100
1100000001011001000110
1100000001011001001000
1100000001011001001010
1100000001011001001100
1100000001011001001110
1100000001011001010000
1100000001011001010010
1100000001011001010100
1100000001011001010110
1100000001011001011000
1100000001011001011010
1100000001011001011100
1100000001011001011110
1100000001011001100000
1100000001011001100010
1100000001011001100100
1100000001011001100110
1100000001011001101000
1100000001011001101010
1100000001011001101100
1100000001011001101110
1100000001011001110000
1100000001011001110010
1100000001011001110100
1100000001011001110110
1100000001011001111000
1100000001011001111010
1100000001011001111100
1100000001011001111110
1100000001011010000000
1100000001011010000010
1100000001011010000100
1100000001011010000110
1100000001011010001000
1100000001011010001010
1100000001011010001100
1100000001011010001110
1100000001011010010000
1100000001011010010010
1100000001011010010100
1100000001011010010110
1100000001011010011000
1100000001011010011010
1100000001011010011100
1100000001011010011110
1100000001011010100000
1100000001011010100010
1100000001011010100100
1100000001011010100110
1100000001011010101000
1100000001011010101010
1100000001011010101100
1100000001011010101110
1100000001011010110000
1100000001011010110010
1100000001011010110100
1100000001011010110110
1100000001011010111000
1100000001011010111010
1100000001011010111100
1100000001011010111110
1100000001011011000000
1100000001011011000010
1100000001011011000100
1100000001011011000110
1100000001011011001000
1100000001011011001010
1100000001011011001100
1100000001011011001110
1100000001011011010000
1100000001011011010010
1100000001011011010100
1100000001011011010110
1100000001011011011000
1100000001011011011010
1100000001011011011100
1100000001011011011110
1100000001011011100000
1100000001011011100010
1100000001011011100100
1100000001011011100110
1100000001011011101000
1100000001011011101010
1100000001011011101100
1100000001011011101110
1100000001011011110000
1100000001011011110010
1100000001011011110100
1100000001011011110110
1100000001011011111000
1100000001011011111010
1100000001011011111100
1100000001011011111110
1100000001011100000000
1100000001011100000010
1100000001011100000100
1100000001011100000110
1100000001011100001000
1100000001011100001010
1100000001011100001100
1100000001011100001110
1100000001011100010000
1100000001011100010010
1100000001011100010100
1100000001011100010110
1100000001011100011000
1100000001011100011010
1100000001011100011100
1100000001011100011110
1100000001011100100000
1100000001011100100010
1100000001011100100100
1100000001011100100110
1100000001011100101000
1100000001011100101010
1100000001011100101100
1100000001011100101110
1100000001011100110000
1100000001011100110010
1100000001011100110100
1100000001011100110110
1100000001011100111000
1100000001011100111010
1100000001011100111100
1100000001011100111110
1100000001011101000000
1100000001011101000010
1100000001011101000100
1100000001011101000110
1100000001011101001000
1100000001011101001010
1100000001011101001100
1100000001011101001110
1100000001011101010000
1100000001011101010010
1100000001011101010100
1100000001011101010110
1100000001011101011000
1100000001011101011010
1100000001011101011100
1100000001011101011110
1100000001011101100000
1100000001011101100010
1100000001011101100100
1100000001011101100110
1100000001011101101000
1100000001011101101010
1100000001011101101100
1100000001011101101110
1100000001011101110000
1100000001011101110010
1100000001011101110100
1100000001011101110110
1100000001011101111000
1100000001011101111010
1100000001011101111100
1100000001011101111110
1100000001011110000000
1100000001011110000010
1100000001011110000100
1100000001011110000110
1100000001011110001000
1100000001011110001010
1100000001011110001100
1100000001011110001110
1100000001011110010000
1100000001011110010010
1100000001011110010100
1100000001011110010110
1100000001011110011000
1100000001011110011010
1100000001011110011100
1100000001011110011110
1100000001011110100000
1100000001011110100010
1100000001011110100100
1100000001011110100110
1100000001011110101000
1100000001011110101010
1100000001011110101100
1100000001011110101110
1100000001011110110000
1100000001011110110010
1100000001011110110100
1100000001011110110110
1100000001011110111000
1100000001011110111010
1100000001011110111100
1100000001011110111110
1100000001011111000000
1100000001011111000010
1100000001011111000100
1100000001011111000110
1100000001011111001000
1100000001011111001010
1100000001011111001100
1100000001011111001110
1100000001011111010000
1100000001011111010010
1100000001011111010100
1100000001011111010110
1100000001011111011000
1100000001011111011010
1100000001011111011100
1100000001011111011110
1100000001011111100000
1100000001011111100010
1100000001011111100100
1100000001011111100110
1100000001011111101000
1100000001011111101010
1100000001011111101100
1100000001011111101110
1100000001011111110000
1100000001011111110010
1100000001011111110100
1100000001011111110110
1100000001011111111000
1100000001011111111010
1100000001011111111100
1100000001011111111110
1100000001100000000000
1100000001100000000010
1100000001100000000100
1100000001100000000110
1100000001100000001000
1100000001100000001010
1100000001100000001100
1100000001100000001110
1100000001100000010000
1100000001100000010010
1100000001100000010100
1100000001100000010110
1100000001100000011000
1100000001100000011010
1100000001100000011100
1100000001100000011110
1100000001100000100000
1100000001100000100010
1100000001100000100100
1100000001100000100110
1100000001100000101000
1100000001100000101010
1100000001100000101100
1100000001100000101110
1100000001100000110000
1100000001100000110010
1100000001100000110100
1100000001100000110110
1100000001100000111000
1100000001100000111010
1100000001100000111100
1100000001100000111110
1100000001100001000000
1100000001100001000010
1100000001100001000100
1100000001100001000110
1100000001100001001000
1100000001100001001010
1100000001100001001100
1100000001100001001110
1100000001100001010000
1100000001100001010010
1100000001100001010100
1100000001100001010110
1100000001100001011000
1100000001100001011010
1100000001100001011100
1100000001100001011110
1100000001100001100000
1100000001100001100010
1100000001100001100100
1100000001100001100110
1100000001100001101000
1100000001100001101010
1100000001100001101100
1100000001100001101110
1100000001100001110000
1100000001100001110010
1100000001100001110100
1100000001100001110110
1100000001100001111000
1100000001100001111010
1100000001100001111100
1100000001100001111110
1100000001100010000000
1100000001100010000010
1100000001100010000100
1100000001100010000110
1100000001100010001000
1100000001100010001010
1100000001100010001100
1100000001100010001110
1100000001100010010000
1100000001100010010010
1100000001100010010100
1100000001100010010110
1100000001100010011000
1100000001100010011010
1100000001100010011100
1100000001100010011110
1100000001100010100000
1100000001100010100010
1100000001100010100100
1100000001100010100110
1100000001100010101000
1100000001100010101010
1100000001100010101100
1100000001100010101110
1100000001100010110000
1100000001100010110010
1100000001100010110100
1100000001100010110110
1100000001100010111000
1100000001100010111010
1100000001100010111100
1100000001100010111110
1100000001100011000000
1100000001100011000010
1100000001100011000100
1100000001100011000110
1100000001100011001000
1100000001100011001010
1100000001100011001100
1100000001100011001110
1100000001100011010000
1100000001100011010010
1100000001100011010100
1100000001100011010110
1100000001100011011000
1100000001100011011010
1100000001100011011100
1100000001100011011110
1100000001100011100000
1100000001100011100010
1100000001100011100100
1100000001100011100110
1100000001100011101000
1100000001100011101010
1100000001100011101100
1100000001100011101110
1100000001100011110000
1100000001100011110010
1100000001100011110100
1100000001100011110110
1100000001100011111000
1100000001100011111010
1100000001100011111100
1100000001100011111110
1100000001100100000000
1100000001100100000010
1100000001100100000100
1100000001100100000110
1100000001100100001000
1100000001100100001010
1100000001100100001100
1100000001100100001110
1100000001100100010000
1100000001100100010010
1100000001100100010100
1100000001100100010110
1100000001100100011000
1100000001100100011010
1100000001100100011100
1100000001100100011110
1100000001100100100000
1100000001100100100010
1100000001100100100100
1100000001100100100110
1100000001100100101000
1100000001100100101010
1100000001100100101100
1100000001100100101110
1100000001100100110000
1100000001100100110010
1100000001100100110100
1100000001100100110110
1100000001100100111000
1100000001100100111010
1100000001100100111100
1100000001100100111110
1100000001100101000000
1100000001100101000010
1100000001100101000100
1100000001100101000110
1100000001100101001000
1100000001100101001010
1100000001100101001100
1100000001100101001110
1100000001100101010000
1100000001100101010010
1100000001100101010100
1100000001100101010110
1100000001100101011000
1100000001100101011010
1100000001100101011100
1100000001100101011110
1100000001100101100000
1100000001100101100010
1100000001100101100100
1100000001100101100110
1100000001100101101000
1100000001100101101010
1100000001100101101100
1100000001100101101110
1100000001100101110000
1100000001100101110010
1100000001100101110100
1100000001100101110110
1100000001100101111000
1100000001100101111010
1100000001100101111100
1100000001100101111110
1100000001100110000000
1100000001100110000010
1100000001100110000100
1100000001100110000110
1100000001100110001000
1100000001100110001010
1100000001100110001100
1100000001100110001110
1100000001100110010000
1100000001100110010010
1100000001100110010100
1100000001100110010110
1100000001100110011000
1100000001100110011010
1100000001100110011100
1100000001100110011110
1100000001100110100000
1100000001100110100010
1100000001100110100100
1100000001100110100110
1100000001100110101000
1100000001100110101010
1100000001100110101100
1100000001100110101110
1100000001100110110000
1100000001100110110010
1100000001100110110100
1100000001100110110110
1100000001100110111000
1100000001100110111010
1100000001100110111100
1100000001100110111110
1100000001100111000000
1100000001100111000010
1100000001100111000100
1100000001100111000110
1100000001100111001000
1100000001100111001010
1100000001100111001100
1100000001100111001110
1100000001100111010000
1100000001100111010010
1100000001100111010100
1100000001100111010110
1100000001100111011000
1100000001100111011010
1100000001100111011100
1100000001100111011110
1100000001100111100000
1100000001100111100010
1100000001100111100100
1100000001100111100110
1100000001100111101000
1100000001100111101010
1100000001100111101100
1100000001100111101110
1100000001100111110000
1100000001100111110010
1100000001100111110100
1100000001100111110110
1100000001100111111000
1100000001100111111010
1100000001100111111100
1100000001100111111110
1100000001101000000000
1100000001101000000010
1100000001101000000100
1100000001101000000110
1100000001101000001000
1100000001101000001010
1100000001101000001100
1100000001101000001110
1100000001101000010000
1100000001101000010010
1100000001101000010100
1100000001101000010110
1100000001101000011000
1100000001101000011010
1100000001101000011100
1100000001101000011110
1100000001101000100000
1100000001101000100010
1100000001101000100100
1100000001101000100110
1100000001101000101000
1100000001101000101010
1100000001101000101100
1100000001101000101110
1100000001101000110000
1100000001101000110010
1100000001101000110100
1100000001101000110110
1100000001101000111000
1100000001101000111010
1100000001101000111100
1100000001101000111110
1100000001101001000000
1100000001101001000010
1100000001101001000100
1100000001101001000110
1100000001101001001000
1100000001101001001010
1100000001101001001100
1100000001101001001110
1100000001101001010000
1100000001101001010010
1100000001101001010100
1100000001101001010110
1100000001101001011000
1100000001101001011010
1100000001101001011100
1100000001101001011110
1100000001101001100000
1100000001101001100010
1100000001101001100100
1100000001101001100110
1100000001101001101000
1100000001101001101010
1100000001101001101100
1100000001101001101110
1100000001101001110000
1100000001101001110010
1100000001101001110100
1100000001101001110110
1100000001101001111000
1100000001101001111010
1100000001101001111100
1100000001101001111110
1100000001101010000000
1100000001101010000010
1100000001101010000100
1100000001101010000110
1100000001101010001000
1100000001101010001010
1100000001101010001100
1100000001101010001110
1100000001101010010000
1100000001101010010010
1100000001101010010100
1100000001101010010110
1100000001101010011000
1100000001101010011010
1100000001101010011100
1100000001101010011110
1100000001101010100000
1100000001101010100010
1100000001101010100100
1100000001101010100110
1100000001101010101000
1100000001101010101010
1100000001101010101100
1100000001101010101110
1100000001101010110000
1100000001101010110010
1100000001101010110100
1100000001101010110110
1100000001101010111000
1100000001101010111010
1100000001101010111100
1100000001101010111110
1100000001101011000000
1100000001101011000010
1100000001101011000100
1100000001101011000110
1100000001101011001000
1100000001101011001010
1100000001101011001100
1100000001101011001110
1100000001101011010000
1100000001101011010010
1100000001101011010100
1100000001101011010110
1100000001101011011000
1100000001101011011010
1100000001101011011100
1100000001101011011110
1100000001101011100000
1100000001101011100010
1100000001101011100100
1100000001101011100110
1100000001101011101000
1100000001101011101010
1100000001101011101100
1100000001101011101110
1100000001101011110000
1100000001101011110010
1100000001101011110100
1100000001101011110110
1100000001101011111000
1100000001101011111010
1100000001101011111100
1100000001101011111110
1100000001101100000000
1100000001101100000010
1100000001101100000100
1100000001101100000110
1100000001101100001000
1100000001101100001010
1100000001101100001100
1100000001101100001110
1100000001101100010000
1100000001101100010010
1100000001101100010100
1100000001101100010110
1100000001101100011000
1100000001101100011010
1100000001101100011100
1100000001101100011110
1100000001101100100000
1100000001101100100010
1100000001101100100100
1100000001101100100110
1100000001101100101000
1100000001101100101010
1100000001101100101100
1100000001101100101110
1100000001101100110000
1100000001101100110010
1100000001101100110100
1100000001101100110110
1100000001101100111000
1100000001101100111010
1100000001101100111100
1100000001101100111110
1100000001101101000000
1100000001101101000010
1100000001101101000100
1100000001101101000110
1100000001101101001000
1100000001101101001010
1100000001101101001100
1100000001101101001110
1100000001101101010000
1100000001101101010010
1100000001101101010100
1100000001101101010110
1100000001101101011000
1100000001101101011010
1100000001101101011100
1100000001101101011110
1100000001101101100000
1100000001101101100010
1100000001101101100100
1100000001101101100110
1100000001101101101000
1100000001101101101010
1100000001101101101100
1100000001101101101110
1100000001101101110000
1100000001101101110010
1100000001101101110100
1100000001101101110110
1100000001101101111000
1100000001101101111010
1100000001101101111100
1100000001101101111110
1100000001101110000000
1100000001101110000010
1100000001101110000100
1100000001101110000110
1100000001101110001000
1100000001101110001010
1100000001101110001100
1100000001101110001110
1100000001101110010000
1100000001101110010010
1100000001101110010100
1100000001101110010110
1100000001101110011000
1100000001101110011010
1100000001101110011100
1100000001101110011110
1100000001101110100000
1100000001101110100010
1100000001101110100100
1100000001101110100110
1100000001101110101000
1100000001101110101010
1100000001101110101100
1100000001101110101110
1100000001101110110000
1100000001101110110010
1100000001101110110100
1100000001101110110110
1100000001101110111000
1100000001101110111010
1100000001101110111100
1100000001101110111110
1100000001101111000000
1100000001101111000010
1100000001101111000100
1100000001101111000110
1100000001101111001000
1100000001101111001010
1100000001101111001100
1100000001101111001110
1100000001101111010000
1100000001101111010010
1100000001101111010100
1100000001101111010110
1100000001101111011000
1100000001101111011010
1100000001101111011100
1100000001101111011110
1100000001101111100000
1100000001101111100010
1100000001101111100100
1100000001101111100110
1100000001101111101000
1100000001101111101010
1100000001101111101100
1100000001101111101110
1100000001101111110000
1100000001101111110010
1100000001101111110100
1100000001101111110110
1100000001101111111000
1100000001101111111010
1100000001101111111100
1100000001101111111110
1100000001110000000000
1100000001110000000010
1100000001110000000100
1100000001110000000110
1100000001110000001000
1100000001110000001010
1100000001110000001100
1100000001110000001110
1100000001110000010000
1100000001110000010010
1100000001110000010100
1100000001110000010110
1100000001110000011000
1100000001110000011010
1100000001110000011100
1100000001110000011110
1100000001110000100000
1100000001110000100010
1100000001110000100100
1100000001110000100110
1100000001110000101000
1100000001110000101010
1100000001110000101100
1100000001110000101110
1100000001110000110000
1100000001110000110010
1100000001110000110100
1100000001110000110110
1100000001110000111000
1100000001110000111010
1100000001110000111100
1100000001110000111110
1100000001110001000000
1100000001110001000010
1100000001110001000100
1100000001110001000110
1100000001110001001000
1100000001110001001010
1100000001110001001100
1100000001110001001110
1100000001110001010000
1100000001110001010010
1100000001110001010100
1100000001110001010110
1100000001110001011000
1100000001110001011010
1100000001110001011100
1100000001110001011110
1100000001110001100000
1100000001110001100010
1100000001110001100100
1100000001110001100110
1100000001110001101000
1100000001110001101010
1100000001110001101100
1100000001110001101110
1100000001110001110000
1100000001110001110010
1100000001110001110100
1100000001110001110110
1100000001110001111000
1100000001110001111010
1100000001110001111100
1100000001110001111110
1100000001110010000000
1100000001110010000010
1100000001110010000100
1100000001110010000110
1100000001110010001000
1100000001110010001010
1100000001110010001100
1100000001110010001110
1100000001110010010000
1100000001110010010010
1100000001110010010100
1100000001110010010110
1100000001110010011000
1100000001110010011010
1100000001110010011100
1100000001110010011110
1100000001110010100000
1100000001110010100010
1100000001110010100100
1100000001110010100110
1100000001110010101000
1100000001110010101010
1100000001110010101100
1100000001110010101110
1100000001110010110000
1100000001110010110010
1100000001110010110100
1100000001110010110110
1100000001110010111000
1100000001110010111010
1100000001110010111100
1100000001110010111110
1100000001110011000000
1100000001110011000010
1100000001110011000100
1100000001110011000110
1100000001110011001000
1100000001110011001010
1100000001110011001100
1100000001110011001110
1100000001110011010000
1100000001110011010010
1100000001110011010100
1100000001110011010110
1100000001110011011000
1100000001110011011010
1100000001110011011100
1100000001110011011110
1100000001110011100000
1100000001110011100010
1100000001110011100100
1100000001110011100110
1100000001110011101000
1100000001110011101010
1100000001110011101100
1100000001110011101110
1100000001110011110000
1100000001110011110010
1100000001110011110100
1100000001110011110110
1100000001110011111000
1100000001110011111010
1100000001110011111100
1100000001110011111110
1100000001110100000000
1100000001110100000010
1100000001110100000100
1100000001110100000110
1100000001110100001000
1100000001110100001010
1100000001110100001100
1100000001110100001110
1100000001110100010000
1100000001110100010010
1100000001110100010100
1100000001110100010110
1100000001110100011000
1100000001110100011010
1100000001110100011100
1100000001110100011110
1100000001110100100000
1100000001110100100010
1100000001110100100100
1100000001110100100110
1100000001110100101000
1100000001110100101010
1100000001110100101100
1100000001110100101110
1100000001110100110000
1100000001110100110010
1100000001110100110100
1100000001110100110110
1100000001110100111000
1100000001110100111010
1100000001110100111100
1100000001110100111110
1100000001110101000000
1100000001110101000010
1100000001110101000100
1100000001110101000110
1100000001110101001000
1100000001110101001010
1100000001110101001100
1100000001110101001110
1100000001110101010000
1100000001110101010010
1100000001110101010100
1100000001110101010110
1100000001110101011000
1100000001110101011010
1100000001110101011100
1100000001110101011110
1100000001110101100000
1100000001110101100010
1100000001110101100100
1100000001110101100110
1100000001110101101000
1100000001110101101010
1100000001110101101100
1100000001110101101110
1100000001110101110000
1100000001110101110010
1100000001110101110100
1100000001110101110110
1100000001110101111000
1100000001110101111010
1100000001110101111100
1100000001110101111110
1100000001110110000000
1100000001110110000010
1100000001110110000100
1100000001110110000110
1100000001110110001000
1100000001110110001010
1100000001110110001100
1100000001110110001110
1100000001110110010000
1100000001110110010010
1100000001110110010100
1100000001110110010110
1100000001110110011000
1100000001110110011010
1100000001110110011100
1100000001110110011110
1100000001110110100000
1100000001110110100010
1100000001110110100100
1100000001110110100110
1100000001110110101000
1100000001110110101010
1100000001110110101100
1100000001110110101110
1100000001110110110000
1100000001110110110010
1100000001110110110100
1100000001110110110110
1100000001110110111000
1100000001110110111010
1100000001110110111100
1100000001110110111110
1100000001110111000000
1100000001110111000010
1100000001110111000100
1100000001110111000110
1100000001110111001000
1100000001110111001010
1100000001110111001100
1100000001110111001110
1100000001110111010000
1100000001110111010010
1100000001110111010100
1100000001110111010110
1100000001110111011000
1100000001110111011010
1100000001110111011100
1100000001110111011110
1100000001110111100000
1100000001110111100010
1100000001110111100100
1100000001110111100110
1100000001110111101000
1100000001110111101010
1100000001110111101100
1100000001110111101110
1100000001110111110000
1100000001110111110010
1100000001110111110100
1100000001110111110110
1100000001110111111000
1100000001110111111010
1100000001110111111100
1100000001110111111110
1100000001111000000000
1100000001111000000010
1100000001111000000100
1100000001111000000110
1100000001111000001000
1100000001111000001010
1100000001111000001100
1100000001111000001110
1100000001111000010000
1100000001111000010010
1100000001111000010100
1100000001111000010110
1100000001111000011000
1100000001111000011010
1100000001111000011100
1100000001111000011110
1100000001111000100000
1100000001111000100010
1100000001111000100100
1100000001111000100110
1100000001111000101000
1100000001111000101010
1100000001111000101100
1100000001111000101110
1100000001111000110000
1100000001111000110010
1100000001111000110100
1100000001111000110110
1100000001111000111000
1100000001111000111010
1100000001111000111100
1100000001111000111110
1100000001111001000000
1100000001111001000010
1100000001111001000100
1100000001111001000110
1100000001111001001000
1100000001111001001010
1100000001111001001100
1100000001111001001110
1100000001111001010000
1100000001111001010010
1100000001111001010100
1100000001111001010110
1100000001111001011000
1100000001111001011010
1100000001111001011100
1100000001111001011110
1100000001111001100000
1100000001111001100010
1100000001111001100100
1100000001111001100110
1100000001111001101000
1100000001111001101010
1100000001111001101100
1100000001111001101110
1100000001111001110000
1100000001111001110010
1100000001111001110100
1100000001111001110110
1100000001111001111000
1100000001111001111010
1100000001111001111100
1100000001111001111110
1100000001111010000000
1100000001111010000010
1100000001111010000100
1100000001111010000110
1100000001111010001000
1100000001111010001010
1100000001111010001100
1100000001111010001110
1100000001111010010000
1100000001111010010010
1100000001111010010100
1100000001111010010110
1100000001111010011000
1100000001111010011010
1100000001111010011100
1100000001111010011110
1100000001111010100000
1100000001111010100010
1100000001111010100100
1100000001111010100110
1100000001111010101000
1100000001111010101010
1100000001111010101100
1100000001111010101110
1100000001111010110000
1100000001111010110010
1100000001111010110100
1100000001111010110110
1100000001111010111000
1100000001111010111010
1100000001111010111100
1100000001111010111110
1100000001111011000000
1100000001111011000010
1100000001111011000100
1100000001111011000110
1100000001111011001000
1100000001111011001010
1100000001111011001100
1100000001111011001110
1100000001111011010000
1100000001111011010010
1100000001111011010100
1100000001111011010110
1100000001111011011000
1100000001111011011010
1100000001111011011100
1100000001111011011110
1100000001111011100000
1100000001111011100010
1100000001111011100100
1100000001111011100110
1100000001111011101000
1100000001111011101010
1100000001111011101100
1100000001111011101110
1100000001111011110000
1100000001111011110010
1100000001111011110100
1100000001111011110110
1100000001111011111000
1100000001111011111010
1100000001111011111100
1100000001111011111110
1100000001111100000000
1100000001111100000010
1100000001111100000100
1100000001111100000110
1100000001111100001000
1100000001111100001010
1100000001111100001100
1100000001111100001110
1100000001111100010000
1100000001111100010010
1100000001111100010100
1100000001111100010110
1100000001111100011000
1100000001111100011010
1100000001111100011100
1100000001111100011110
1100000001111100100000
1100000001111100100010
1100000001111100100100
1100000001111100100110
1100000001111100101000
1100000001111100101010
1100000001111100101100
1100000001111100101110
1100000001111100110000
1100000001111100110010
1100000001111100110100
1100000001111100110110
1100000001111100111000
1100000001111100111010
1100000001111100111100
1100000001111100111110
1100000001111101000000
1100000001111101000010
1100000001111101000100
1100000001111101000110
1100000001111101001000
1100000001111101001010
1100000001111101001100
1100000001111101001110
1100000001111101010000
1100000001111101010010
1100000001111101010100
1100000001111101010110
1100000001111101011000
1100000001111101011010
1100000001111101011100
1100000001111101011110
1100000001111101100000
1100000001111101100010
1100000001111101100100
1100000001111101100110
1100000001111101101000
1100000001111101101010
1100000001111101101100
1100000001111101101110
1100000001111101110000
1100000001111101110010
1100000001111101110100
1100000001111101110110
1100000001111101111000
1100000001111101111010
1100000001111101111100
1100000001111101111110
1100000001111110000000
1100000001111110000010
1100000001111110000100
1100000001111110000110
1100000001111110001000
1100000001111110001010
1100000001111110001100
1100000001111110001110
1100000001111110010000
1100000001111110010010
1100000001111110010100
1100000001111110010110
1100000001111110011000
1100000001111110011010
1100000001111110011100
1100000001111110011110
1100000001111110100000
1100000001111110100010
1100000001111110100100
1100000001111110100110
1100000001111110101000
1100000001111110101010
1100000001111110101100
1100000001111110101110
1100000001111110110000
1100000001111110110010
1100000001111110110100
1100000001111110110110
1100000001111110111000
1100000001111110111010
1100000001111110111100
1100000001111110111110
1100000001111111000000
1100000001111111000010
1100000001111111000100
1100000001111111000110
1100000001111111001000
1100000001111111001010
1100000001111111001100
1100000001111111001110
1100000001111111010000
1100000001111111010010
1100000001111111010100
1100000001111111010110
1100000001111111011000
1100000001111111011010
1100000001111111011100
1100000001111111011110
1100000001111111100000
1100000001111111100010
1100000001111111100100
1100000001111111100110
1100000001111111101000
1100000001111111101010
1100000001111111101100
1100000001111111101110
1100000001111111110000
1100000001111111110010
1100000001111111110100
1100000001111111110110
1100000001111111111000
1100000001111111111010
1100000001111111111100
1100000001111111111110
1100000010000000000000
1100000010000000000010
1100000010000000000100
1100000010000000000110
1100000010000000001000
1100000010000000001010
1100000010000000001100
1100000010000000001110
1100000010000000010000
1100000010000000010010
1100000010000000010100
1100000010000000010110
1100000010000000011000
1100000010000000011010
1100000010000000011100
1100000010000000011110
1100000010000000100000
1100000010000000100010
1100000010000000100100
1100000010000000100110
1100000010000000101000
1100000010000000101010
1100000010000000101100
1100000010000000101110
1100000010000000110000
1100000010000000110010
1100000010000000110100
1100000010000000110110
1100000010000000111000
1100000010000000111010
1100000010000000111100
1100000010000000111110
1100000010000001000000
1100000010000001000010
1100000010000001000100
1100000010000001000110
1100000010000001001000
1100000010000001001010
1100000010000001001100
1100000010000001001110
1100000010000001010000
1100000010000001010010
1100000010000001010100
1100000010000001010110
1100000010000001011000
1100000010000001011010
1100000010000001011100
1100000010000001011110
1100000010000001100000
1100000010000001100010
1100000010000001100100
1100000010000001100110
1100000010000001101000
1100000010000001101010
1100000010000001101100
1100000010000001101110
1100000010000001110000
1100000010000001110010
1100000010000001110100
1100000010000001110110
1100000010000001111000
1100000010000001111010
1100000010000001111100
1100000010000001111110
1100000010000010000000
1100000010000010000010
1100000010000010000100
1100000010000010000110
1100000010000010001000
1100000010000010001010
1100000010000010001100
1100000010000010001110
1100000010000010010000
1100000010000010010010
1100000010000010010100
1100000010000010010110
1100000010000010011000
1100000010000010011010
1100000010000010011100
1100000010000010011110
1100000010000010100000
1100000010000010100010
1100000010000010100100
1100000010000010100110
1100000010000010101000
1100000010000010101010
1100000010000010101100
1100000010000010101110
1100000010000010110000
1100000010000010110010
1100000010000010110100
1100000010000010110110
1100000010000010111000
1100000010000010111010
1100000010000010111100
1100000010000010111110
1100000010000011000000
1100000010000011000010
1100000010000011000100
1100000010000011000110
1100000010000011001000
1100000010000011001010
1100000010000011001100
1100000010000011001110
1100000010000011010000
1100000010000011010010
1100000010000011010100
1100000010000011010110
1100000010000011011000
1100000010000011011010
1100000010000011011100
1100000010000011011110
1100000010000011100000
1100000010000011100010
1100000010000011100100
1100000010000011100110
1100000010000011101000
1100000010000011101010
1100000010000011101100
1100000010000011101110
1100000010000011110000
1100000010000011110010
1100000010000011110100
1100000010000011110110
1100000010000011111000
1100000010000011111010
1100000010000011111100
1100000010000011111110
1100000010000100000000
1100000010000100000010
1100000010000100000100
1100000010000100000110
1100000010000100001000
1100000010000100001010
1100000010000100001100
1100000010000100001110
1100000010000100010000
1100000010000100010010
1100000010000100010100
1100000010000100010110
1100000010000100011000
1100000010000100011010
1100000010000100011100
1100000010000100011110
1100000010000100100000
1100000010000100100010
1100000010000100100100
1100000010000100100110
1100000010000100101000
1100000010000100101010
1100000010000100101100
1100000010000100101110
1100000010000100110000
1100000010000100110010
1100000010000100110100
1100000010000100110110
1100000010000100111000
1100000010000100111010
1100000010000100111100
1100000010000100111110
1100000010000101000000
1100000010000101000010
1100000010000101000100
1100000010000101000110
1100000010000101001000
1100000010000101001010
1100000010000101001100
1100000010000101001110
1100000010000101010000
1100000010000101010010
1100000010000101010100
1100000010000101010110
1100000010000101011000
1100000010000101011010
1100000010000101011100
1100000010000101011110
1100000010000101100000
1100000010000101100010
1100000010000101100100
1100000010000101100110
1100000010000101101000
1100000010000101101010
1100000010000101101100
1100000010000101101110
1100000010000101110000
1100000010000101110010
1100000010000101110100
1100000010000101110110
1100000010000101111000
1100000010000101111010
1100000010000101111100
1100000010000101111110
1100000010000110000000
1100000010000110000010
1100000010000110000100
1100000010000110000110
1100000010000110001000
1100000010000110001010
1100000010000110001100
1100000010000110001110
1100000010000110010000
1100000010000110010010
1100000010000110010100
1100000010000110010110
1100000010000110011000
1100000010000110011010
1100000010000110011100
1100000010000110011110
1100000010000110100000
1100000010000110100010
1100000010000110100100
1100000010000110100110
1100000010000110101000
1100000010000110101010
1100000010000110101100
1100000010000110101110
1100000010000110110000
1100000010000110110010
1100000010000110110100
1100000010000110110110
1100000010000110111000
1100000010000110111010
1100000010000110111100
1100000010000110111110
1100000010000111000000
1100000010000111000010
1100000010000111000100
1100000010000111000110
1100000010000111001000
1100000010000111001010
1100000010000111001100
1100000010000111001110
1100000010000111010000
1100000010000111010010
1100000010000111010100
1100000010000111010110
1100000010000111011000
1100000010000111011010
1100000010000111011100
1100000010000111011110
1100000010000111100000
1100000010000111100010
1100000010000111100100
1100000010000111100110
1100000010000111101000
1100000010000111101010
1100000010000111101100
1100000010000111101110
1100000010000111110000
1100000010000111110010
1100000010000111110100
1100000010000111110110
1100000010000111111000
1100000010000111111010
1100000010000111111100
1100000010000111111110
1100000010001000000000
1100000010001000000010
1100000010001000000100
1100000010001000000110
1100000010001000001000
1100000010001000001010
1100000010001000001100
1100000010001000001110
1100000010001000010000
1100000010001000010010
1100000010001000010100
1100000010001000010110
1100000010001000011000
1100000010001000011010
1100000010001000011100
1100000010001000011110
1100000010001000100000
1100000010001000100010
1100000010001000100100
1100000010001000100110
1100000010001000101000
1100000010001000101010
1100000010001000101100
1100000010001000101110
1100000010001000110000
1100000010001000110010
1100000010001000110100
1100000010001000110110
1100000010001000111000
1100000010001000111010
1100000010001000111100
1100000010001000111110
1100000010001001000000
1100000010001001000010
1100000010001001000100
1100000010001001000110
1100000010001001001000
1100000010001001001010
1100000010001001001100
1100000010001001001110
1100000010001001010000
1100000010001001010010
1100000010001001010100
1100000010001001010110
1100000010001001011000
1100000010001001011010
1100000010001001011100
1100000010001001011110
1100000010001001100000
1100000010001001100010
1100000010001001100100
1100000010001001100110
1100000010001001101000
1100000010001001101010
1100000010001001101100
1100000010001001101110
1100000010001001110000
1100000010001001110010
1100000010001001110100
1100000010001001110110
1100000010001001111000
1100000010001001111010
1100000010001001111100
1100000010001001111110
1100000010001010000000
1100000010001010000010
1100000010001010000100
1100000010001010000110
1100000010001010001000
1100000010001010001010
1100000010001010001100
1100000010001010001110
1100000010001010010000
1100000010001010010010
1100000010001010010100
1100000010001010010110
1100000010001010011000
1100000010001010011010
1100000010001010011100
1100000010001010011110
1100000010001010100000
1100000010001010100010
1100000010001010100100
1100000010001010100110
1100000010001010101000
1100000010001010101010
1100000010001010101100
1100000010001010101110
1100000010001010110000
1100000010001010110010
1100000010001010110100
1100000010001010110110
1100000010001010111000
1100000010001010111010
1100000010001010111100
1100000010001010111110
1100000010001011000000
1100000010001011000010
1100000010001011000100
1100000010001011000110
1100000010001011001000
1100000010001011001010
1100000010001011001100
1100000010001011001110
1100000010001011010000
1100000010001011010010
1100000010001011010100
1100000010001011010110
1100000010001011011000
1100000010001011011010
1100000010001011011100
1100000010001011011110
1100000010001011100000
1100000010001011100010
1100000010001011100100
1100000010001011100110
1100000010001011101000
1100000010001011101010
1100000010001011101100
1100000010001011101110
1100000010001011110000
1100000010001011110010
1100000010001011110100
1100000010001011110110
1100000010001011111000
1100000010001011111010
1100000010001011111100
1100000010001011111110
1100000010001100000000
1100000010001100000010
1100000010001100000100
1100000010001100000110
1100000010001100001000
1100000010001100001010
1100000010001100001100
1100000010001100001110
1100000010001100010000
1100000010001100010010
1100000010001100010100
1100000010001100010110
1100000010001100011000
1100000010001100011010
1100000010001100011100
1100000010001100011110
1100000010001100100000
1100000010001100100010
1100000010001100100100
1100000010001100100110
1100000010001100101000
1100000010001100101010
1100000010001100101100
1100000010001100101110
1100000010001100110000
1100000010001100110010
1100000010001100110100
1100000010001100110110
1100000010001100111000
1100000010001100111010
1100000010001100111100
1100000010001100111110
1100000010001101000000
1100000010001101000010
1100000010001101000100
1100000010001101000110
1100000010001101001000
1100000010001101001010
1100000010001101001100
1100000010001101001110
1100000010001101010000
1100000010001101010010
1100000010001101010100
1100000010001101010110
1100000010001101011000
1100000010001101011010
1100000010001101011100
1100000010001101011110
1100000010001101100000
1100000010001101100010
1100000010001101100100
1100000010001101100110
1100000010001101101000
1100000010001101101010
1100000010001101101100
1100000010001101101110
1100000010001101110000
1100000010001101110010
1100000010001101110100
1100000010001101110110
1100000010001101111000
1100000010001101111010
1100000010001101111100
1100000010001101111110
1100000010001110000000
1100000010001110000010
1100000010001110000100
1100000010001110000110
1100000010001110001000
1100000010001110001010
1100000010001110001100
1100000010001110001110
1100000010001110010000
1100000010001110010010
1100000010001110010100
1100000010001110010110
1100000010001110011000
1100000010001110011010
1100000010001110011100
1100000010001110011110
1100000010001110100000
1100000010001110100010
1100000010001110100100
1100000010001110100110
1100000010001110101000
1100000010001110101010
1100000010001110101100
1100000010001110101110
1100000010001110110000
1100000010001110110010
1100000010001110110100
1100000010001110110110
1100000010001110111000
1100000010001110111010
1100000010001110111100
1100000010001110111110
1100000010001111000000
1100000010001111000010
1100000010001111000100
1100000010001111000110
1100000010001111001000
1100000010001111001010
1100000010001111001100
1100000010001111001110
1100000010001111010000
1100000010001111010010
1100000010001111010100
1100000010001111010110
1100000010001111011000
1100000010001111011010
1100000010001111011100
1100000010001111011110
1100000010001111100000
1100000010001111100010
1100000010001111100100
1100000010001111100110
1100000010001111101000
1100000010001111101010
1100000010001111101100
1100000010001111101110
1100000010001111110000
1100000010001111110010
1100000010001111110100
1100000010001111110110
1100000010001111111000
1100000010001111111010
1100000010001111111100
1100000010001111111110
1100000010010000000000
1100000010010000000010
1100000010010000000100
1100000010010000000110
1100000010010000001000
1100000010010000001010
1100000010010000001100
1100000010010000001110
1100000010010000010000
1100000010010000010010
1100000010010000010100
1100000010010000010110
1100000010010000011000
1100000010010000011010
1100000010010000011100
1100000010010000011110
1100000010010000100000
1100000010010000100010
1100000010010000100100
1100000010010000100110
1100000010010000101000
1100000010010000101010
1100000010010000101100
1100000010010000101110
1100000010010000110000
1100000010010000110010
1100000010010000110100
1100000010010000110110
1100000010010000111000
1100000010010000111010
1100000010010000111100
1100000010010000111110
1100000010010001000000
1100000010010001000010
1100000010010001000100
1100000010010001000110
1100000010010001001000
1100000010010001001010
1100000010010001001100
1100000010010001001110
1100000010010001010000
1100000010010001010010
1100000010010001010100
1100000010010001010110
1100000010010001011000
1100000010010001011010
1100000010010001011100
1100000010010001011110
1100000010010001100000
1100000010010001100010
1100000010010001100100
1100000010010001100110
1100000010010001101000
1100000010010001101010
1100000010010001101100
1100000010010001101110
1100000010010001110000
1100000010010001110010
1100000010010001110100
1100000010010001110110
1100000010010001111000
1100000010010001111010
1100000010010001111100
1100000010010001111110
1100000010010010000000
1100000010010010000010
1100000010010010000100
1100000010010010000110
1100000010010010001000
1100000010010010001010
1100000010010010001100
1100000010010010001110
1100000010010010010000
1100000010010010010010
1100000010010010010100
1100000010010010010110
1100000010010010011000
1100000010010010011010
1100000010010010011100
1100000010010010011110
1100000010010010100000
1100000010010010100010
1100000010010010100100
1100000010010010100110
1100000010010010101000
1100000010010010101010
1100000010010010101100
1100000010010010101110
1100000010010010110000
1100000010010010110010
1100000010010010110100
1100000010010010110110
1100000010010010111000
1100000010010010111010
1100000010010010111100
1100000010010010111110
1100000010010011000000
1100000010010011000010
1100000010010011000100
1100000010010011000110
1100000010010011001000
1100000010010011001010
1100000010010011001100
1100000010010011001110
1100000010010011010000
1100000010010011010010
1100000010010011010100
1100000010010011010110
1100000010010011011000
1100000010010011011010
1100000010010011011100
1100000010010011011110
1100000010010011100000
1100000010010011100010
1100000010010011100100
1100000010010011100110
1100000010010011101000
1100000010010011101010
1100000010010011101100
1100000010010011101110
1100000010010011110000
1100000010010011110010
1100000010010011110100
1100000010010011110110
1100000010010011111000
1100000010010011111010
1100000010010011111100
1100000010010011111110
1100000010010100000000
1100000010010100000010
1100000010010100000100
1100000010010100000110
1100000010010100001000
1100000010010100001010
1100000010010100001100
1100000010010100001110
1100000010010100010000
1100000010010100010010
1100000010010100010100
1100000010010100010110
1100000010010100011000
1100000010010100011010
1100000010010100011100
1100000010010100011110
1100000010010100100000
1100000010010100100010
1100000010010100100100
1100000010010100100110
1100000010010100101000
1100000010010100101010
1100000010010100101100
1100000010010100101110
1100000010010100110000
1100000010010100110010
1100000010010100110100
1100000010010100110110
1100000010010100111000
1100000010010100111010
1100000010010100111100
1100000010010100111110
1100000010010101000000
1100000010010101000010
1100000010010101000100
1100000010010101000110
1100000010010101001000
1100000010010101001010
1100000010010101001100
1100000010010101001110
1100000010010101010000
1100000010010101010010
1100000010010101010100
1100000010010101010110
1100000010010101011000
1100000010010101011010
1100000010010101011100
1100000010010101011110
1100000010010101100000
1100000010010101100010
1100000010010101100100
1100000010010101100110
1100000010010101101000
1100000010010101101010
1100000010010101101100
1100000010010101101110
1100000010010101110000
1100000010010101110010
1100000010010101110100
1100000010010101110110
1100000010010101111000
1100000010010101111010
1100000010010101111100
1100000010010101111110
1100000010010110000000
1100000010010110000010
1100000010010110000100
1100000010010110000110
1100000010010110001000
1100000010010110001010
1100000010010110001100
1100000010010110001110
1100000010010110010000
1100000010010110010010
1100000010010110010100
1100000010010110010110
1100000010010110011000
1100000010010110011010
1100000010010110011100
1100000010010110011110
1100000010010110100000
1100000010010110100010
1100000010010110100100
1100000010010110100110
1100000010010110101000
1100000010010110101010
1100000010010110101100
1100000010010110101110
1100000010010110110000
1100000010010110110010
1100000010010110110100
1100000010010110110110
1100000010010110111000
1100000010010110111010
1100000010010110111100
1100000010010110111110
1100000010010111000000
1100000010010111000010
1100000010010111000100
1100000010010111000110
1100000010010111001000
1100000010010111001010
1100000010010111001100
1100000010010111001110
1100000010010111010000
1100000010010111010010
1100000010010111010100
1100000010010111010110
1100000010010111011000
1100000010010111011010
1100000010010111011100
1100000010010111011110
1100000010010111100000
1100000010010111100010
1100000010010111100100
1100000010010111100110
1100000010010111101000
1100000010010111101010
1100000010010111101100
1100000010010111101110
1100000010010111110000
1100000010010111110010
1100000010010111110100
1100000010010111110110
1100000010010111111000
1100000010010111111010
1100000010010111111100
1100000010010111111110
1100000010011000000000
1100000010011000000010
1100000010011000000100
1100000010011000000110
1100000010011000001000
1100000010011000001010
1100000010011000001100
1100000010011000001110
1100000010011000010000
1100000010011000010010
1100000010011000010100
1100000010011000010110
1100000010011000011000
1100000010011000011010
1100000010011000011100
1100000010011000011110
1100000010011000100000
1100000010011000100010
1100000010011000100100
1100000010011000100110
1100000010011000101000
1100000010011000101010
1100000010011000101100
1100000010011000101110
1100000010011000110000
1100000010011000110010
1100000010011000110100
1100000010011000110110
1100000010011000111000
1100000010011000111010
1100000010011000111100
1100000010011000111110
1100000010011001000000
1100000010011001000010
1100000010011001000100
1100000010011001000110
1100000010011001001000
1100000010011001001010
1100000010011001001100
1100000010011001001110
1100000010011001010000
1100000010011001010010
1100000010011001010100
1100000010011001010110
1100000010011001011000
1100000010011001011010
1100000010011001011100
1100000010011001011110
1100000010011001100000
1100000010011001100010
1100000010011001100100
1100000010011001100110
1100000010011001101000
1100000010011001101010
1100000010011001101100
1100000010011001101110
1100000010011001110000
1100000010011001110010
1100000010011001110100
1100000010011001110110
1100000010011001111000
1100000010011001111010
1100000010011001111100
1100000010011001111110
1100000010011010000000
1100000010011010000010
1100000010011010000100
1100000010011010000110
1100000010011010001000
1100000010011010001010
1100000010011010001100
1100000010011010001110
1100000010011010010000
1100000010011010010010
1100000010011010010100
1100000010011010010110
1100000010011010011000
1100000010011010011010
1100000010011010011100
1100000010011010011110
1100000010011010100000
1100000010011010100010
1100000010011010100100
1100000010011010100110
1100000010011010101000
1100000010011010101010
1100000010011010101100
1100000010011010101110
1100000010011010110000
1100000010011010110010
1100000010011010110100
1100000010011010110110
1100000010011010111000
1100000010011010111010
1100000010011010111100
1100000010011010111110
1100000010011011000000
1100000010011011000010
1100000010011011000100
1100000010011011000110
1100000010011011001000
1100000010011011001010
1100000010011011001100
1100000010011011001110
1100000010011011010000
1100000010011011010010
1100000010011011010100
1100000010011011010110
1100000010011011011000
1100000010011011011010
1100000010011011011100
1100000010011011011110
1100000010011011100000
1100000010011011100010
1100000010011011100100
1100000010011011100110
1100000010011011101000
1100000010011011101010
1100000010011011101100
1100000010011011101110
1100000010011011110000
1100000010011011110010
1100000010011011110100
1100000010011011110110
1100000010011011111000
1100000010011011111010
1100000010011011111100
1100000010011011111110
1100000010011100000000
1100000010011100000010
1100000010011100000100
1100000010011100000110
1100000010011100001000
1100000010011100001010
1100000010011100001100
1100000010011100001110
1100000010011100010000
1100000010011100010010
1100000010011100010100
1100000010011100010110
1100000010011100011000
1100000010011100011010
1100000010011100011100
1100000010011100011110
1100000010011100100000
1100000010011100100010
1100000010011100100100
1100000010011100100110
1100000010011100101000
1100000010011100101010
1100000010011100101100
1100000010011100101110
1100000010011100110000
1100000010011100110010
1100000010011100110100
1100000010011100110110
1100000010011100111000
1100000010011100111010
1100000010011100111100
1100000010011100111110
1100000010011101000000
1100000010011101000010
1100000010011101000100
1100000010011101000110
1100000010011101001000
1100000010011101001010
1100000010011101001100
1100000010011101001110
1100000010011101010000
1100000010011101010010
1100000010011101010100
1100000010011101010110
1100000010011101011000
1100000010011101011010
1100000010011101011100
1100000010011101011110
1100000010011101100000
1100000010011101100010
1100000010011101100100
1100000010011101100110
1100000010011101101000
1100000010011101101010
1100000010011101101100
1100000010011101101110
1100000010011101110000
1100000010011101110010
1100000010011101110100
1100000010011101110110
1100000010011101111000
1100000010011101111010
1100000010011101111100
1100000010011101111110
1100000010011110000000
1100000010011110000010
1100000010011110000100
1100000010011110000110
1100000010011110001000
1100000010011110001010
1100000010011110001100
1100000010011110001110
1100000010011110010000
1100000010011110010010
1100000010011110010100
1100000010011110010110
1100000010011110011000
1100000010011110011010
1100000010011110011100
1100000010011110011110
1100000010011110100000
1100000010011110100010
1100000010011110100100
1100000010011110100110
1100000010011110101000
1100000010011110101010
1100000010011110101100
1100000010011110101110
1100000010011110110000
1100000010011110110010
1100000010011110110100
1100000010011110110110
1100000010011110111000
1100000010011110111010
1100000010011110111100
1100000010011110111110
1100000010011111000000
1100000010011111000010
1100000010011111000100
1100000010011111000110
1100000010011111001000
1100000010011111001010
1100000010011111001100
1100000010011111001110
1100000010011111010000
1100000010011111010010
1100000010011111010100
1100000010011111010110
1100000010011111011000
1100000010011111011010
1100000010011111011100
1100000010011111011110
1100000010011111100000
1100000010011111100010
1100000010011111100100
1100000010011111100110
1100000010011111101000
1100000010011111101010
1100000010011111101100
1100000010011111101110
1100000010011111110000
1100000010011111110010
1100000010011111110100
1100000010011111110110
1100000010011111111000
1100000010011111111010
1100000010011111111100
1100000010011111111110
1100000010100000000000
1100000010100000000010
1100000010100000000100
1100000010100000000110
1100000010100000001000
1100000010100000001010
1100000010100000001100
1100000010100000001110
1100000010100000010000
1100000010100000010010
1100000010100000010100
1100000010100000010110
1100000010100000011000
1100000010100000011010
1100000010100000011100
1100000010100000011110
1100000010100000100000
1100000010100000100010
1100000010100000100100
1100000010100000100110
1100000010100000101000
1100000010100000101010
1100000010100000101100
1100000010100000101110
1100000010100000110000
1100000010100000110010
1100000010100000110100
1100000010100000110110
1100000010100000111000
1100000010100000111010
1100000010100000111100
1100000010100000111110
1100000010100001000000
1100000010100001000010
1100000010100001000100
1100000010100001000110
1100000010100001001000
1100000010100001001010
1100000010100001001100
1100000010100001001110
1100000010100001010000
1100000010100001010010
1100000010100001010100
1100000010100001010110
1100000010100001011000
1100000010100001011010
1100000010100001011100
1100000010100001011110
1100000010100001100000
1100000010100001100010
1100000010100001100100
1100000010100001100110
1100000010100001101000
1100000010100001101010
1100000010100001101100
1100000010100001101110
1100000010100001110000
1100000010100001110010
1100000010100001110100
1100000010100001110110
1100000010100001111000
1100000010100001111010
1100000010100001111100
1100000010100001111110
1100000010100010000000
1100000010100010000010
1100000010100010000100
1100000010100010000110
1100000010100010001000
1100000010100010001010
1100000010100010001100
1100000010100010001110
1100000010100010010000
1100000010100010010010
1100000010100010010100
1100000010100010010110
1100000010100010011000
1100000010100010011010
1100000010100010011100
1100000010100010011110
1100000010100010100000
1100000010100010100010
1100000010100010100100
1100000010100010100110
1100000010100010101000
1100000010100010101010
1100000010100010101100
1100000010100010101110
1100000010100010110000
1100000010100010110010
1100000010100010110100
1100000010100010110110
1100000010100010111000
1100000010100010111010
1100000010100010111100
1100000010100010111110
1100000010100011000000
1100000010100011000010
1100000010100011000100
1100000010100011000110
1100000010100011001000
1100000010100011001010
1100000010100011001100
1100000010100011001110
1100000010100011010000
1100000010100011010010
1100000010100011010100
1100000010100011010110
1100000010100011011000
1100000010100011011010
1100000010100011011100
1100000010100011011110
1100000010100011100000
1100000010100011100010
1100000010100011100100
1100000010100011100110
1100000010100011101000
1100000010100011101010
1100000010100011101100
1100000010100011101110
1100000010100011110000
1100000010100011110010
1100000010100011110100
1100000010100011110110
1100000010100011111000
1100000010100011111010
1100000010100011111100
1100000010100011111110
1100000010100100000000
1100000010100100000010
1100000010100100000100
1100000010100100000110
1100000010100100001000
1100000010100100001010
1100000010100100001100
1100000010100100001110
1100000010100100010000
1100000010100100010010
1100000010100100010100
1100000010100100010110
1100000010100100011000
1100000010100100011010
1100000010100100011100
1100000010100100011110
1100000010100100100000
1100000010100100100010
1100000010100100100100
1100000010100100100110
1100000010100100101000
1100000010100100101010
1100000010100100101100
1100000010100100101110
1100000010100100110000
1100000010100100110010
1100000010100100110100
1100000010100100110110
1100000010100100111000
1100000010100100111010
1100000010100100111100
1100000010100100111110
1100000010100101000000
1100000010100101000010
1100000010100101000100
1100000010100101000110
1100000010100101001000
1100000010100101001010
1100000010100101001100
1100000010100101001110
1100000010100101010000
1100000010100101010010
1100000010100101010100
1100000010100101010110
1100000010100101011000
1100000010100101011010
1100000010100101011100
1100000010100101011110
1100000010100101100000
1100000010100101100010
1100000010100101100100
1100000010100101100110
1100000010100101101000
1100000010100101101010
1100000010100101101100
1100000010100101101110
1100000010100101110000
1100000010100101110010
1100000010100101110100
1100000010100101110110
1100000010100101111000
1100000010100101111010
1100000010100101111100
1100000010100101111110
1100000010100110000000
1100000010100110000010
1100000010100110000100
1100000010100110000110
1100000010100110001000
1100000010100110001010
1100000010100110001100
1100000010100110001110
1100000010100110010000
1100000010100110010010
1100000010100110010100
1100000010100110010110
1100000010100110011000
1100000010100110011010
1100000010100110011100
1100000010100110011110
1100000010100110100000
1100000010100110100010
1100000010100110100100
1100000010100110100110
1100000010100110101000
1100000010100110101010
1100000010100110101100
1100000010100110101110
1100000010100110110000
1100000010100110110010
1100000010100110110100
1100000010100110110110
1100000010100110111000
1100000010100110111010
1100000010100110111100
1100000010100110111110
1100000010100111000000
1100000010100111000010
1100000010100111000100
1100000010100111000110
1100000010100111001000
1100000010100111001010
1100000010100111001100
1100000010100111001110
1100000010100111010000
1100000010100111010010
1100000010100111010100
1100000010100111010110
1100000010100111011000
1100000010100111011010
1100000010100111011100
1100000010100111011110
1100000010100111100000
1100000010100111100010
1100000010100111100100
1100000010100111100110
1100000010100111101000
1100000010100111101010
1100000010100111101100
1100000010100111101110
1100000010100111110000
1100000010100111110010
1100000010100111110100
1100000010100111110110
1100000010100111111000
1100000010100111111010
1100000010100111111100
1100000010100111111110
1100000010101000000000
1100000010101000000010
1100000010101000000100
1100000010101000000110
1100000010101000001000
1100000010101000001010
1100000010101000001100
1100000010101000001110
1100000010101000010000
1100000010101000010010
1100000010101000010100
1100000010101000010110
1100000010101000011000
1100000010101000011010
1100000010101000011100
1100000010101000011110
1100000010101000100000
1100000010101000100010
1100000010101000100100
1100000010101000100110
1100000010101000101000
1100000010101000101010
1100000010101000101100
1100000010101000101110
1100000010101000110000
1100000010101000110010
1100000010101000110100
1100000010101000110110
1100000010101000111000
1100000010101000111010
1100000010101000111100
1100000010101000111110
1100000010101001000000
1100000010101001000010
1100000010101001000100
1100000010101001000110
1100000010101001001000
1100000010101001001010
1100000010101001001100
1100000010101001001110
1100000010101001010000
1100000010101001010010
1100000010101001010100
1100000010101001010110
1100000010101001011000
1100000010101001011010
1100000010101001011100
1100000010101001011110
1100000010101001100000
1100000010101001100010
1100000010101001100100
1100000010101001100110
1100000010101001101000
1100000010101001101010
1100000010101001101100
1100000010101001101110
1100000010101001110000
1100000010101001110010
1100000010101001110100
1100000010101001110110
1100000010101001111000
1100000010101001111010
1100000010101001111100
1100000010101001111110
1100000010101010000000
1100000010101010000010
1100000010101010000100
1100000010101010000110
1100000010101010001000
1100000010101010001010
1100000010101010001100
1100000010101010001110
1100000010101010010000
1100000010101010010010
1100000010101010010100
1100000010101010010110
1100000010101010011000
1100000010101010011010
1100000010101010011100
1100000010101010011110
1100000010101010100000
1100000010101010100010
1100000010101010100100
1100000010101010100110
1100000010101010101000
1100000010101010101010
1100000010101010101100
1100000010101010101110
1100000010101010110000
1100000010101010110010
1100000010101010110100
1100000010101010110110
1100000010101010111000
1100000010101010111010
1100000010101010111100
1100000010101010111110
1100000010101011000000
1100000010101011000010
1100000010101011000100
1100000010101011000110 - FAIL
I don't get it.
Crumbs, I take a weekend off and four pages go by!
Sounds like DML has gone to town on the testing programs. :lol:
exxos wrote: Sat Nov 12, 2022 3:20 am I'm not sure how the RAM is orientated in RAM :lol: on the STFM you have 16 chips 1 bit each. It makes up 512k. So when the other 16 chips are fitted, it uses a high bank CAS1H CAS1L. Then to add more RAM you have MAD9 in play for 4MB. At which point I assume its 1MB banks which are selected with RAS/CAS.
The falcon loses me :lol: I assume having more addresses and 32bit that its in blocks of 4MB then bank switches. So for there to be a 1MB chunk missing every 4MB.. I'd assume MAD10 is broken or a bank select RAS/CAS ... I dunno.. @Badwolf translate :lol:
Without specific knowledge of VIDEL (which @ijor may have?) there's no way of inferring which bit of which address ends up where from purely logical deduction.
VIDEL can organise its row and column multiplexing however was convenient at the time and the data lines wouldn't necessarily correspond to the bus data lines.
By way of example on DFB1 the row and column multiplexing changes between firmware and providing the individual bits within each bytes are all kept together, the order of the bits can vary between 'bus bits' and 'chip bits'.
Prior knowledge is required.
exxos wrote: Sun Nov 13, 2022 9:09 pm Is bit11 in the videl actually used for starters ? I think you said your program used true colour, so it would never register on those faulty bits ?
There is something else which may have to be considered here.. That bit11 assuming testing in 16 bits.. Actually has a high and low word.. Assuming this will mean that bit11 could actually be bit 27 in a different RAM chip :stars:
In 16-bit video mode each pixel is 16 bits and they're packed adjacent to each other, so it does fill the memory. You were quoting the VIDEL registers which store each palette (in the indexed modes) as RGxB (32bit). Not relevant in this case as they're not used for 16 bit mode and they're not in DRAM anyway.
My understanding of the bit11 problem is the other way around, however. The Falcon's RAM is 32 bit, accessed by VIDEL as such and is I believe interleaved cleverly to increase access speed (@mikro may be able to enlighten us her). That would mean that bit11 on the data bus actually spans two different chips. If you were seeing a bit11 error on every single RAM access, then that *would* be odd!
... going to digest the rest of the thread now.
dml wrote: Mon Nov 14, 2022 2:41 pm Here's an update that will print the exact address of the first fault in each solid block:
https://www.dropbox.com/s/rcvovjouc8hzp ... 4.zip?dl=1
It also asks for an individual keypress before printing each kind of result and the graphic map so stuff doesn't scroll away too easily.
Badwolf wrote: Mon Nov 14, 2022 2:48 pm Crumbs, I take a weekend off and four pages go by!
:lol:
Yes indeed @dml I think is writing programs faster than I can try them currently :lol:
I think we are all going down the rabbit hole somehow with this problem though :(
I was merely trying to narrow it down to any specific address range relating to bit 11. Obviously seems to not fail completely because it only fails on certain address ranges.
Currently I was only blaming the data bit itself, but wondering could the address bits themselves had blown the chip. But currently the signals look fine on those so I assume it is not relating to any particular address combination.
Just does not make sense that if bit 11 Was blowing the chip, then why did it only blow the chip on particular address ranges.. Does not really make sense..
dml
Post by dml »
Just noticed the address reporting is off by 4 (postinc bug) so the 0xac8 offset will actually be 0xac4 (for a 32bit test), and might be ac6 for a 16bit test, depending on which word is affected.
(I'll fix this and update the link but you don't really need to re-run the test, just take it into account).
dml wrote: Mon Nov 14, 2022 3:00 pm Just noticed the address reporting is off by 4 (postinc bug) so the 0xac8 offset will actually be 0xac4 (for a 32bit test), and might be ac6 for a 16bit test, depending on which word is affected.
Yep.. I was just about to ask that there was a slight discrepancy there.
dml
Post by dml »
Here's the fixed version (the address-off-by-4-bytes reporting) and I removed the 16bit data test since it seems redundant now.
https://www.dropbox.com/s/0upei90g63zj8 ... 5.zip?dl=1
Will leave it alone until/unless something more is requested
dml wrote: Mon Nov 14, 2022 3:03 pm Here's the fixed version (the address-off-by-4-bytes reporting) and I removed the 16bit data test since it seems redundant now.
Many thanks.
Might be worth putting these programs in the software essential section and just doing a quick write-up about them ? think it may be useful in the future if not for myself other people..
As said previously I think we are going down the rabbit hole little bit here now.
We have no way of really telling what failure mode the DRAM IC would have. I will just have to speculate that when some bad spikes hit bit 11, regardless of what address it was on, it must have punched through some other blocks in the chip somehow as well. For example ,it just takes out alternate 1MB blocks in the chip for whatever reason.
It just seemed odd that if something was blowing up so many address ranges, then it would blow the entire lot in the chip. Not just particular "banks" within the chip. What I can tell it just seems pretty random what address it starts to fail on. Is not like it just simply got to address on a 4MB boundary and then started to fail. In that case we could blame it on whatever address bits switched over at the 4MB mark. But that does not seem to be the case.
exxos wrote: Mon Nov 14, 2022 3:08 pm We have no way of really telling what failure mode the DRAM IC would have. I will just have to speculate that when some bad spikes hit bit 11, regardless of what address it was on, it must have punched through some other blocks in the chip somehow as well. For example ,it just takes out alternate 1MB blocks in the chip for whatever reason.
We don't know what particular row and column xAE6 in the lower bank corresponds to, but that particular data line will be used for all other lower addresses too, so it's not going to be on the data pin side.
Looks like that particular row and column is returning high no matter whan you write to it. The little charge bucket in that part of the chip is zonko, I reckon.
EDIT: but as for why fewer errors when DFB1 attached..? That's odd. Is DFB1 enabled or disabled when you see this phenomenon?
