exxos blog - random goings on
Solder pasting the shifter adapter boards..
Just so supercool :lol:
exxos wrote: Fri Dec 03, 2021 5:44 pm Solder pasting the shifter adapter boards..
The Voltera is cool. Now I have mine working well it shaves so much time off of the previous method of using stencils.
Next crappy video production. Not sure how many more videos I will do as it is taking a bucketload of time up :roll:
ST2VGA & diagnostic cartridges have been made and I'm currently waiting for shipment to me.
Back to the 4MB MMU boards...
Adding the SMT connector and capacitor..
Then onto the hot plate for a gentle simmer for a while..
Then soldering the header pins and sockets..
Then into the ultrasonic cleaner..
Meanwhile the 4MB boards have just come out of the cleaner..
While they was all tested before going in the cleaner, they are tested again afterwards.
And then they have the final QC sticker on them.
Now the shifter boards are out of the cleaner and undergoing a test as well..
:dizzy:
Being too poorly to do much else today, I started dabbling with a 68K CPU relocator for the 70789 boards. So this way the TOS206 decoder boards & 16MHz booster can be fitted in the original STFM case.
It is a bit of a squash in between the 4MB MMU RAM board and the MB keyboard post hole, but it *just* fits.
This board will have the bus pullups on it and some caps later..
Taking shape :) need to print it out next make sure it all fits.
Went to Eagle 9 to try to speed up some routing (I like the auto DRC over V7) but like 5 minutes into it all...
Same old BS again. Eagle has more bloody bugs than our back garden! :roll:
I mean seriously! :WTF:
Good old V7.. Same job.
I have managed to squash up the 4MB MMU RAM board a little bit. Effectively moving the connector further inwards. It should help miss the CPU relocated boards in batches in the future.
Back to the relocator. On paper it fits, literally :lol:
