exxos blog - random goings on
Tried taking the exclusion multiplier down to 90%. It is a lot better now.. letting it print now..
Took a screenshot of a slightly different infill pattern I did before, and you can see how blobby it is. On the long straights it prints perfectly well, but when the head changes direction it builds up a blob..
Current printing..
8000mm/min , 1500 accel.
exxos wrote: Mon Aug 23, 2021 7:31 pm Took a screenshot of a slightly different infill pattern I did before, and you can see how blobby it is. On the long straights it prints perfectly well, but when the head changes direction it builds up a blob..
At a guess, I'd say acceleration is too low so it's dwelling in that spot and oozing (retraction only kicks in for non-printing moves rather than printing changes of direction).
exxos wrote: Mon Aug 23, 2021 7:31 pm Current printing..
That sounds better. Your previous settings were almost certainly acceleration limited, although I did I assume the 80,000mm/min was a typo as you'd need a 4 metre printer to get up to speed. ;)
I'd be surprised if you could maintain 8000mm/min consistently, but I think you're on the right track looking for the highest acceleration you can handle, then hunting for the best max speed. It passes the *ear* test, anyway :)
Badwolf wrote: Mon Aug 23, 2021 8:36 pm At a guess, I'd say acceleration is too low so it's dwelling in that spot and oozing (retraction only kicks in for non-printing moves rather than printing changes of direction).
I thought that. but stupid high or low speeds made no difference at all.
Badwolf wrote: Mon Aug 23, 2021 8:36 pm I'd be surprised if you could maintain 8000mm/min consistently, but I think you're on the right track looking for the highest acceleration you can handle, then hunting for the best max speed. It passes the *ear* test, anyway :)
I think I can push higher acceleration. But for small parts its not really relevant.
Finished print :)
Poorly finger :(
WARNING - Image contains fingers.
Post by JezC »
exxos wrote: Tue Aug 24, 2021 12:37 pm Poorly finger :(
Just as well it had a warning... otherwise I might have had to report that post!
Funny that I'm used to the sight of my own blood but still more affected when I see other people's (and animals etc.) vital fluids...
exxos wrote: Mon Aug 23, 2021 11:27 pm
Looking good, though.
Prusaslicer has a wibby-wobbly all curves fill pattern (I forget the name), may reduce dwell time in any single location?
I3 new stronger Y-idler..
Your finger is not going to get a modelling career looking like that @exxos :)
Icky wrote: Tue Aug 24, 2021 7:23 pm Your finger is not going to get a modelling career looking like that @exxos :)
Depends what you're into I guess :lol:
exxos wrote: Tue Aug 24, 2021 7:25 pm
True. It could end up as a stunt double in a zombie flick
