What I do not understand why everything being calibrated fine so insanely far out
exxos blog - random goings on
@PhilC I am still puzzling over the z-axis currently. 100mm Movement exactly majors 100mm physically with a ruler. A 1mm high cube turns out at 1.25mm! I am thinking because the height is too much that it is why the thing appears to be under-extruding.
Is the 0.25mm the initial gap between the base and the extruder nozzle? I'm thinking off-by-one error in the software.
@exxos ok, sounds like you need something a bit more tweakable than you've got.
I have a spare 3d printer, my old one, that uses a touch screen and marlin software, it's an Ender 3.(need to put bltouch back on and recalibrate it first)
Or
I have some spare BigTreeTech boards motherboard, screen etc that you could retrofit to your printer?
Would you like either?
Or
Thanks for the offer @PhilC But I have my I3 here which I don't have these odd gaps problems with. I'm just trying to calibrate the flash forge so I can print out some new parts for the I3.
My flash forge is using the latest Marlin software and I'm using the various commands to calibrate the printer.
X&Y seem fine, but Z is way out. The only way I could probably do this is to make the travel 25% smaller. I will try a different slicer later as well.
@exxos No worries. I use Cura myself.
I have used at a couple of times but not really set it up yet properly.
I have recalibrated the bed levelling with a piece of paper this time.. it is 0.08mm machine which came with the printer was 0.17mm.. So hoping you will squashed the filament down a little better at least on the first layer and hopefully better on other layers..
It's about the right height now ...
Bottom layer looks much better..
Top layers still out
What's your layer height? At the risk of stating the obvious if it's not a factor of 1mm, you *won't* be able to print exactly that height. Bear in mind the bottom layer is sometimes scaled up a bit too (eg. 1.5x height).exxos wrote: Mon Aug 16, 2021 2:09 pm @PhilC I am still puzzling over the z-axis currently. 100mm Movement exactly majors 100mm physically with a ruler. A 1mm high cube turns out at 1.25mm!
I think I see what the problem is now..
It looks like the idler wheel is all over the place...
You can see the pink filament here in between the wheels...
Then a few mm later.. you can't...
Looks like the filament itself is all over the place, At least the part in the extruder head..
I was puzzling over what the heatsink and fan was actually doing front of this assembly, it would make more sense for the fan to blow on the filament surely ?!
