exxos blog - random goings on
Yeah, just one would be enough. I might have to hone up my SMD soldering skills about 5 levels to put the CPU on there though! :-)
stephen_usher wrote: Wed Oct 28, 2020 4:56 pm Yeah, just one would be enough. I might have to hone up my SMD soldering skills about 5 levels to put the CPU on there though! :-)
If you get one with bent pins then it'll take you forever to get everything lined up and soldered. Even with all the pins straight they are a pain to solder.
Noted. I'd have to use hot air on that scale of device.
I don't s'pose you know of a good source for them?
stephen_usher wrote: Wed Oct 28, 2020 5:55 pm Noted. I'd have to use hot air on that scale of device.
I believe exxos ordered them from Aliexpress.
Thanks... so pot luck then.
stephen_usher wrote: Wed Oct 28, 2020 6:26 pm Thanks... so pot luck then.
I've built four and all four will run at 50mhz for at least two hours each but with a heatsink.
Is this the correct type? "MC68030FE33C MC68030 QFP-132"
stephen_usher wrote: Wed Oct 28, 2020 6:45 pm Is this the correct type? "MC68030FE33C MC68030 QFP-132"
Sorry only just seen this post.. I got them from here.. https://www.aliexpress.com/item/4001034 ... 4c4dOptuSX but @PhilC said the pins were bent.
Got these in the UScleaner :)
DoG
Post by DoG »
exxos wrote: Tue Nov 03, 2020 2:27 pm Got these in the UScleaner :)
:dualthumbup:
