exxos blog - random goings on
Brought one of these cheap DAC amps.. https://www.ebay.co.uk/itm/283794891977
My dad did buy a expensive DAC, but I wanted one with tone controls on it as mostly I use headphones and need a bit of tweaking..
So I should be able to go optical out from the SACD player to this DAC unit..
Had this from @ube Arrive today, no idea how to wire it up, but its gonna be awesome whatever it does :)
ube
Post by ube »
1. Straighten the pins.
2. Replace the reset 555 with unit.
3. Remove/disconnect c102.
4. Connect pin 5 to whatever you want to switch (ie dual tos).
Usage:
Press and release reset. Within one second, press again to switch pin 5. (Two times: pin 6. Three times: pin 7.)
Tadaaa! :D
master of the bare pcb
Cool, press 50 times fast, got it! Will have a go Monday! :excited: :excited:
ube
Post by ube »
I’m more proud of the name than the unit itself. Re555et.
ube wrote: 28 Aug 2020 22:16 I’m more proud of the name than the unit itself. Re555et.
Oh sweet! Thats pretty cool and clever. :thumbup:
So...
Re - As in remake.
Re - As in REset
555 - as in what it is.
555 - as in a play on S.. but with a stutter I guess :lol:
:stars: :dizzy:
So 0.2mm nozzle, with 0.1mm steps.. first print look like our cat has been chewing it :lol: I think smaller steps is aggravating the oozing issues.. will low the temp and try 0.2mm on Monday..
I also think PLA is to fragile for this kinda thing as well :roll: But oddly the pink PLA is pretty strong. Could just be down to 0.4mm used.. :shrug:
@exxos is that over extrusion on the legs?
I've never used a 0.2mm nozzle but I'd expect to have to retune retraction, microsteps, etc.
How does print time compare to 0.4mm?
PhilC wrote: 28 Aug 2020 22:46 @exxos is that over extrusion on the legs?
It's hard to say, just looks like its not cooled quick enough and blobbed all over the place. In other places looks like its shrunk.
PhilC wrote: 28 Aug 2020 22:46 I've never used a 0.2mm nozzle but I'd expect to have to retune retraction, microsteps, etc.
Yep, its my first time, so expect issues.
PhilC wrote: 28 Aug 2020 22:46 How does print time compare to 0.4mm?
Takes twice as long ? :lol:
@exxos thought it might time wise.
You do know its probably cheaper to buy rawl plugs than print your own? :P :lol:
Users browsing this forum: CCBot and 13 guests
