Fantastic!
This is surely going to go into most STs regardless of other digital solutions. Us hobbyists who can desolder and socket an original Shifter will have work to do for others ;)
/Troed
Sidequest: VGA scan doubler
Smonson
Re: Sidequest: VGA scan doubler
Not the way I've got it mounted in my machine. I've replaced the shifter socket with IDC pin header sockets - I'm constantly unplugging and replugging mod boards into it. Then I'm using extra-long pin headers that are approximately 2cm long, so it sits above the larger passives that are in the shifter box.DoG wrote: 28 Jul 2020 12:04 Looks really nice. Will it fit in the shifter enclosure with the lid on or is that the goal? It looks like it will anyway.
The next one I make up, I'll use regular-length header pins and see if that fits. The main problem is one tall electrolytic that's close to the socket. I'll puzzle over what to do about that. I expect some people are going to want to plug this directly into the IC socket that the shifter is normally mounted in - I have my old H4 donor board with one of those on it so I can see how the height goes with that too.
Smonson
It'll be like the late 90s modchip scene all over again!troed wrote: 28 Jul 2020 12:11 Fantastic!
Smonson
Nah, I just had a close look and there really isn't much room... if you could sit a board right on top of the electrolytic capacitors, it's flush with the lid of the box. You could save a couple of mm if you could avoid the electrolytics (and then you hit the heads of a bunch of TO-92 transistors), but you actually need a fairly large amount of vertical space for the shifter IC and a socket. It might be better just to leave it open. I don't think closing it up improves anything picture-wise.DoG wrote: 28 Jul 2020 12:04 Looks really nice. Will it fit in the shifter enclosure with the lid on or is that the goal? It looks like it will anyway.
DoG
Yup, of course you have done some mods to easier test out stuff. Didn't think about the cap in there. You could make a large hole in your PCB design so the cap goes through your board. If you go with shorter pins that is and that is the end goal of course.Smonson wrote: 28 Jul 2020 12:19 ...The next one I make up, I'll use regular-length header pins and see if that fits. The main problem is one tall electrolytic that's close to the socket. I'll puzzle over what to do about that...
Remove lid is the easiest solution of course.
EDIT: I see what you mean by all the transistors. You don't save much space by clearing the cap.
Smonson
Heh, I actually kinda did this once for the HDMI mod, after I got the boards back I realised it was going to hit the cap. So I used a round file to notch the board on each of the prototypes... it wasn't pretty, but it did the job!DoG wrote: 28 Jul 2020 12:45 You could make a large hole in your PCB design so the cap goes through your board. If you go with shorter pins that is and that is the end goal of course.
I have quite a few old monitors to test with ;)Smonson wrote: 28 Jul 2020 11:50 It'd probably look even better on an old analogue VGA monitor, but I don't have one to test it.
Can't wait to get one to try out!
Great work that man. :bravo: :coolpics: :goodpost:
atari030
That is truly a work of art.
@Smonson Does Closure run ? :twisted: :twisted: :twisted: :twisted:
Smonson
Hahaha, I knew somebody was gonna ask that eventually!
Users browsing this forum: CCBot and 224 guests
