Sidequest: VGA scan doubler
sandord
Re: Sidequest: VGA scan doubler
Post by sandord »
My take is usually to make sure to have a lot of projects going on concurrently :P
Often that's a great way to deal with procrastination as well ;)
Smonson
Post by Smonson »
True! I'm actually working on my hard drive project in the meantime :)
sandord
Post by sandord »
Smonson wrote: 15 Jul 2020 15:03 True! I'm actually working on my hard drive project in the meantime :)
:o care to tell us a bit more about that? :excited:
Smonson
Post by Smonson »
Nothing fancy, I just like making my own stuff. It's basically a SatanDisk. Should work out pretty cheap as I'm using an ATMega plus a small 3.3v FPGA to do all the work. It seems to be physically working, now I'm just figuring out what the correct responses to the ACSI commands are meant to look like. I'll make a post for it once it actually works as a disk 🙂
sandord
Post by sandord »
Smonson wrote: 16 Jul 2020 01:44 Nothing fancy, I just like making my own stuff. It's basically a SatanDisk. Should work out pretty cheap as I'm using an ATMega plus a small 3.3v FPGA to do all the work. It seems to be physically working, now I'm just figuring out what the correct responses to the ACSI commands are meant to look like. I'll make a post for it once it actually works as a disk 🙂
Nevertheless, be sure to write that post. I think your work is highly inspiring and equally exciting :mrgreen:
Post by JezC »
Definitely interested in anything like this - with all the other retro-computer expenses, buying an actual US or Satandisk is a pipe dream at the moment...so having a similar solution available (hopefully for lower cost) would be amazing!
I'd considered using an ARM Cortex-M micro for USB MSD (as well as keyboard & mouse) & SD Card support...but that won't happen for a year or two/three at best...and will require something like a SCSI disc failure to prompt me into action... :shrug:
Very inspirational to see all these great developments in the community!
Smonson
Post by Smonson »
Thanks guys, you are too kind. I'll post the progress I have now, which is not very much, in a new thread :)
Smonson
Post by Smonson »
Everything worked out great. I haven't even hooked up the blanking signal, but the picture is already fantastic. It'd probably look even better on an old analogue VGA monitor, but I don't have one to test it.
Very nice ! :yay: :thumbup:
DoG
Post by DoG »
Looks really nice. Will it fit in the shifter enclosure with the lid on or is that the goal? It looks like it will anyway.
Users browsing this forum: CCBot and 10 guests
