This is monochrome passed through the scandoubler (not through the original ST monitor port though, yet):
- scandoubler2-mono1.png (1.55 MiB) Viewed 6123 times
There is some kind of random noise in the image, which you can see toward the bottom of that pic. Where the noise is and what it looks like depends on what image is displayed on the screen, so I think it's the monitor having trouble with the monochrome frame parameters (tried on 2 monitors, same effect).
You can see different noise in this pic which has a window opened (especially in the last few lines, and on the right edge just after the active area):
- scandoubler2-mono2.png (1.37 MiB) Viewed 6123 times
This is the native Atari frame timing for monochrome which I don't have at hand at this moment. There was a post on the other forum with the timing parameters which is now gone, I should have saved it somewhere. Since mono doesn't use blanking, the monitor could be getting confused... it's my working hypothesis. I'm going to try synthetically generating hsync at a different position in the scanline to see if that improves it.
The intentional part of the image is pretty good though, and my DACs are constructed in a similar way to the ST's internal ones (R-2R ladder plus a BJT). So hopefully it would still look crisp after passing through the original ones.
