Check if your IP is banned
viewtopic.php?t=7286
Icky Projects
Re: Icky Projects
Just needs a pile of boxes and a cat next, then all set
Re: Icky Projects
Not Atari but house rewiring. I just took a look at the front door bell, oh boy. It still works too.
Re: Icky Projects
Does "Eeeek* cover it?Icky wrote: Sat Jan 08, 2022 6:40 pm Not Atari but house rewiring. I just took a look at the front door bell, oh boy. It still works too.
Re: Icky Projects
I am in a little quandary. My mind is battling with don't touch it and go on sort it out. This is probably a bit of a debate as the house is listed but this looks too dangerous to leave in situ. Am currently trying to figure out the date of this stuff. It's got to be <1970srubber_jonnie wrote: Sat Jan 08, 2022 8:57 pmDoes "Eeeek* cover it?Icky wrote: Sat Jan 08, 2022 6:40 pm Not Atari but house rewiring. I just took a look at the front door bell, oh boy. It still works too.
Re: Icky Projects
Health and safety tags should go on that maybe hazmat
Tom
Tom
Re: Icky Projects
I'm thinking some of it may be 60s maybe even older, but I'd be in a quandary too thinking about what to do with it.Icky wrote: Sat Jan 08, 2022 9:06 pmI am in a little quandary. My mind is battling with don't touch it and go on sort it out. This is probably a bit of a debate as the house is listed but this looks too dangerous to leave in situ. Am currently trying to figure out the date of this stuff. Its got to be <1970s
Re: Icky Projects
Too true @Tomswork.
My current thinking is to tidy up the wires and the terminal blocks only preserving everything and only change the modern switch to a fused one as I don’t think that line is fused other than the RCD at the consumer unit.rubber_jonnie wrote: Sat Jan 08, 2022 10:48 pm I'm thinking some of it may be 60s maybe even older, but I'd be in a quandary too thinking about what to do with it.
Re: Icky Projects
Looks 1940s/50s to me.Icky wrote: Sat Jan 08, 2022 9:06 pmI am in a little quandary. My mind is battling with don't touch it and go on sort it out. This is probably a bit of a debate as the house is listed but this looks too dangerous to leave in situ. Am currently trying to figure out the date of this stuff. Its got to be <1970s
What level of listing does the building have? If it's Grade I then you have to get permission to do almost anything.
Re: Icky Projects
It’s Grade II. I could not cope with a Grade I.stephen_usher wrote: Sat Jan 08, 2022 11:32 pm Looks 1940s/50s to me.
Re: Icky Projects
Ahh knock the whole thing down , all but one wall and call it a refurb job. That's what they did with out leasure center
